Post new topic Reply to topic  [ 19 posts ]
Go to page 1, 2  Next
PostPosted: Wed Jun 27, 2012 5:20 am
I'm looking to lower my stem on my CAAD10 since it already sits on top of the headset.
So, I'm trying to find a headset to replace the high tange seiki on the stock CAAD10. I was wondering what are some good options. I see people using Cane Creek, and some others, so I was just looking for some input, and what specs/or specific models I should be looking at.
Also, I know that the stock CAAD10 stem is +/- 6 degrees, but what is the length of the stock CAAD10 stem on a 58cm frame?
Thanks for the help in advance.
PostPosted: Wed Jun 27, 2012 5:29 am
http://slamthatstem.com/
PostPosted: Wed Jun 27, 2012 5:33 am
Well, of course. That would be very useful if it wasn't sold out. What other options do I have?
PostPosted: Wed Jun 27, 2012 5:44 am
sorry, didnt know it was sold out. i'd offer to send you one of the two that i have, if i was a responsible person with follow-through.
PostPosted: Wed Jun 27, 2012 5:51 am
Your best option would be to go to your local bike shop and ask them if they have a low headset top cap which you can swap with your own (or buy, should only be a couple of $'s).
You can look online but top caps can be a pain to find because they fall into the spare parts category and quite often you have to contact eg: cane creek, fsa directly.
Plus, seen as they are only worth a couple of $'s you would be paying a lot more for the postage.
PostPosted: Wed Jun 27, 2012 5:54 am
All right, thank you guys for the help.
Now, does anyone know the stem length?
PostPosted: Wed Jun 27, 2012 6:06 am
Just checked the website it doesn't give that spec. You can easily figure it out by measuring from the center of the steer tube (I use the top cap bolt as reference), to the center of your handlebar.
-Zane
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Wed Jun 27, 2012 4:16 pm
I have a 58cm CAAD10 and the stock stem is 110mm.
For headset I got the Cane Creek 40.IS42 short. It's 9mm and much shorter than the stock one which is huge at ~25mm I think. THe cover is nice because it has a nice tight seal to keep sweat and water out. It comes with a new top bearing.
PostPosted: Thu Jun 28, 2012 3:12 am
what about the veloflyte one?
http://www.veloflyte.com/carbon_fiber_integrated_headset_upper_dust_shield
PostPosted: Thu Jun 28, 2012 6:32 am
NWSAlpine, yes that was the cane creek I was looking at getting. And thanks for verifying the stem length. I guess I'll head to some bike shops this weekend and see if they have low headset top caps and I'll get one. If not, I guess I'll spend on a completely new headset.
thisisatest, I don't really know about any of the veloflyte ones. I'm not yet interested in slamming my stem, since that would be a bit too low, I just need to drop it a bit more, so I'm mainly looking at the ~10mm range. However, I might eventually get lower so those might become a consideration.
PostPosted: Thu Jun 28, 2012 6:51 am
I replaced mine with the cane creek version. Couldn't get just top cover, had to get the whole top portion of the headset which is sold separately.
Used a spacer at first as shown below, the spacer's gone now and the bike is fully slammed.
My stem is an 8 deg Deda. If you still want to go lower, there's always 10 and 17 deg versions from other brands.
PostPosted: Thu Jun 28, 2012 6:54 am
edroc73rp
Looks really nice! You're using this one http://www.universalcycles.com/shopping/product_details.php?id=39514 , in the short version correct?
PostPosted: Thu Jun 28, 2012 8:49 am
You can also consider this one http://www.universalcycles.com/shopping ... p?id=27941
It has 1.25 bearings for the bottom which is useable for the CAAD10 and you can set it aside as a spare. The spacer at he top is 10mm. I use this for my Evo.
PostPosted: Thu Jun 28, 2012 6:46 pm
Looks the same as I did but I kept the small spacer above the cap. Although it is only sold as a top cap and bearing it's not too expensive (~30 on ebay) compared to some of the carbon caps that are 20-30 anyways.
I love how tight the fit is with the cane creek though.
PostPosted: Tue Jul 17, 2012 7:07 am
SLAM THAT STEM COVERS ARE BACKKKK!!!!
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], etownfwd, HammerTime2, Kayrehn, MixMastaPJ and 59 guests
There are no new unread posts for this topic. Headset tightens when I tighten stem bolts
polar8
Thu May 02, 2013 3:52 pm
eric View the latest post
There are no new unread posts for this topic. Cannondale Evo Headset and Fork question
apLe
Wed Jan 09, 2013 3:37 am
timzcat View the latest post
There are no new unread posts for this topic. lowest external headset question/help
artray
Wed Sep 12, 2012 5:08 pm
artray View the latest post
There are no new unread posts for this topic. 2013 Colnago C59 headset question
Rich.H
Thu Oct 11, 2012 8:21 pm
paulandmonster View the latest post
There are no new unread posts for this topic. Attachment(s) Question about installing a Press-Fit Headset & fork
addictR1
14
812
Tue Jun 19, 2012 12:56 am
Ruds View the latest post
It is currently Wed May 22, 2013 4:37 pm
