Post new topic Reply to topic  [ 22 posts ]
Go to page Previous  1, 2
PostPosted: Wed Jun 27, 2012 4:11 pm
Is there a reason, other than trying to sell expensive chain tools and throwing business to Camoy Pro Shops for chain installation, that Campagnolo does not offer a "missing" link type thing? Does a Campagnolo 11 speed chain installed per Campagnolo's directions perform better or is it more reliable or durable than a Campagnolo chain using a missing link?
PostPosted: Thu Jun 28, 2012 12:12 am
Tubbie Guru
Hi,
boysa wrote:
Sjoerd,
As I mentioned, I use the 11s link and find it to be very reusable. It is the same as the 10s link, really. The only difference is I need the pliers to remove it where I used to be able to break the 10s link apart by hand. BTW, I am referring to the KMC Missing Links.
I filed away a little on the inside of each half of the link where the pins snap into the holes and it now opens up by hand as per the 10S version.
If you think about it, it being non-reusable does not make much sense as it's technically identical to the 10S version but except for a much tighter fit around the pins.
10S C-links work as well but are way too wide and can be a source of noise.
Ciao, ;)
PostPosted: Tue Jul 17, 2012 5:39 pm
I'm use 11 KMC missing link and remove it every week for cleaning chain, no problem at all.
PostPosted: Tue Jul 17, 2012 6:02 pm
For years I have been re-using quick links but some months back my 11 speed KMC "which I had re-used 2-3 times" came lose.
Luckily I was out by myself and not really pushing it, link just unhinged and chain fell to the ground.
Lesson learned - don't re-use the links.
Blog: http://glorycycles.blogspot.com/" onclick="window.open(this.href);return false;
Flickr: http://www.flickr.com/photos/glorycycles/" onclick="window.open(this.href);return false;
PostPosted: Tue Jul 17, 2012 10:55 pm
Tubbie Guru
Hi,
Surely that can only happen if the link wasn't fully closed or not properly closed in the first place?
Ciao, ;)
PostPosted: Tue Jul 17, 2012 11:16 pm
I don't think so, i had been riding the bike for a few weeks since the chain was installed. I might have had it in and out of my car but whatever happened did happen and it could have been at the wrong time. Given the cost I have decided it's best to not reuse the links. Use them once and discard. Life it too short to be off the bike nursing injury.
Quote deleted, PP
PostPosted: Wed Jul 18, 2012 11:13 am
cwdzoot, when you say you reused the link, was that with different chains or just on the same chain?
Also, had any part of the link failed or did it just come apart (assuming you found it)?
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], caballero, dgran, Google [Bot], Google Adsense [Bot], martroy, MiSzA (PL), mnmasotto, rbrtwyn, shoopdawoop and 67 guests
There are no new unread posts for this topic. Wippermann Connex Link for Campy 10 Speed
goldmine848
10
493
Sun Aug 26, 2012 11:15 pm
DaveS View the latest post
There are no new unread posts for this topic. Shimano 10 speed + Campagnolo 10 speed cassette
rhyslewisdavies
Tue Jan 15, 2013 12:10 am
bm0p700f View the latest post
There are no new unread posts for this topic. Campagnolo 10 speed shifters on 11 speed derailleurs
LittleSprinter
13
1237
Wed Dec 26, 2012 12:54 am
There are no new unread posts for this topic. Upgrading Campagnolo 10 speed to 11 speed
shn750
Fri Sep 28, 2012 3:05 am
Cheetahmk7 View the latest post
There are no new unread posts for this topic. Best value / performance Campagnolo 11 speed
Flint
15
980
Tue Jan 01, 2013 3:06 pm
tommasini View the latest post
It is currently Thu May 23, 2013 2:10 pm
