Post new topic Reply to topic  [ 30 posts ]
Go to page Previous  1, 2
PostPosted: Tue Jun 26, 2012 8:03 am
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
PostPosted: Tue Jun 26, 2012 8:58 am
I had a similar issue with a Chorus 11 and was worse as it slipped between the inner ring and the chain stay. Try as I might I could not remove it without what I considered a large amount of force and hence damage. Basically had to break the chain. It was my fault as I did not adjust the FD correctly. As I did not want a similar issue and because of the clearances involved I put on a chain catcher. $5 and a few grams best investment yet and maybe even Pro
PostPosted: Tue Jun 26, 2012 3:26 pm
So a $150 derrailleur shouldn;t be expected to handle a shift uphill or a slipped chain?? Really? That's considered user error? Since when? Nobody has ever had to shift while going uphill? I know enough to ease-off on the pressure and expect the gears to do what gears do not snap like a piece of plastic.
If a $15 Dr from the cheapest bike can handle it I think a top of line model should be able to as well, it was certainly not an impossible shift, merely a less-than-ideal shift. And sometimes chains slide off rings, I am not an idiot for being unlucky enough to have this happen am I? Nor do I think its too much to ask for a dr to handle that. Front drs are not the most complicated things to build.
What I took offense to was the condescension with which my post was met, I have been riding for well over 20 years and do not think my post deserved the level of insult it received. I love how my reply got flaggged but not those who insulted my OP
Seems like some here are cruising for posts to put others down rather than add any constructive advice, not all, but some, and it gets really annoying. Its like a middle school class full of spoiled brats who do nothing but call each other names.
And yes, these Dr's de-laminate like crazy and I really dont care about that its mostly aesthetics, though one could complain that such high end parts should at least be able to maintain their integrity - I chalk that up to flexibility on the cage that delaminated the outer layer of carbon. As long as it works I dont care.
Whatever
PostPosted: Fri Jun 29, 2012 12:07 pm
drill through outer plate, build a alloy or carbon tube spacer, run a longer bolt through outer cage, tube spacer and into the inner plate, problem solved. Fixable if it happens again, light :o and easy...
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=100739
PostPosted: Fri Jun 29, 2012 1:09 pm
God what a pompous, judgmental, and arrogant mob.
r o y g b i v
PostPosted: Fri Jun 29, 2012 1:31 pm
Tubbie Guru
Hi,
Maybe people should read or reread the original post (with or without the removed prophanity) before passing on judgement themselves ?
Ciao, ;)
PostPosted: Fri Jun 29, 2012 1:41 pm
Wow is this entertaining :thumbup:
So what will happen when you use a steel cage but still misaligned front derailure and wedge the chain in the manner described? I suggest substantial damage could result that will still require replacement of costly parts. I mean something has got to give right? :noidea:
I spent years riding 10 speed Record and will admit to shift up a few times as like you rightly point out, stuff happens. I never had any issue however. I am forced to suggest as others that your adjustment is off or perhaps a bent tooth on the chainring. That said I did once get a request from a fellow WW for my old derailure as he had broken the cage on his front derailure. So I guess it does happen. That makes two cases I have heard about ever. My fellow WW never told me how he broke the piece but never reported further issues. Go to the wanted section here if you need spare parts on the cheap. I may still have an old one so PM me if you need one and I'll send it to you if I have it.
I will offer a bit of unsolicited advise. No need to get defensive when folks try to help. Your first post was seeking to blame someone (Campy) without even allowing the possibility that you or your mechanic could have some culpability with the problem. That attitude based on understandable frustration set you up for the replies that followed. No big deal. IMO all the advise you received was sound from a technical point. Fact is shifting any group, even the new electric groups while going uphill under load places a good deal of strain on the system. Bent teeth and broken chains and damaged derailure can still occasionally happen. Design flaw? well yes but one shared by every derailure system except those wonderful internal gear things we see on touring bikes. No sysem is perfect, sometimes we have to adapt to its limitations
:beerchug:
WW Velocipedist Gargantuan
PostPosted: Fri Apr 19, 2013 2:31 pm
Sorry for the necro, but my topic was deleted.
Have a similar issue and I'm just wondering if I can replace my Record 10 FD with a R/SR11 FD without shifting issue in amongst the rest of a Record 10 gruppo?
PostPosted: Fri Apr 19, 2013 10:27 pm
I've never had a problem with any front derailler, though I went Chorus as it seemed more durable than s/record. I very rarely use it anyway, spending 90% of my time in the 50. As a tubsie I love hills so never grind down to the 34, unless it's going to be required I do it in advance of the chain strain or battle it out. When I haven't I've just been lucky I guess.
PostPosted: Sat Apr 20, 2013 5:19 pm
You could, but because it's a narrower cage, setup will be a little more finicky and you will likely end up trimming more when riding.
I'd be using a 10-spd FD.
dangerous curves ahead
PostPosted: Sat Apr 20, 2013 5:36 pm
Perfect. Thanks! That was exactly what I needed to know and couldn't find. I figured it would work just fine, but the issue was whether or not the new design narrowed since the chain is a bit narrower. They could have left the FD width alone, or narrowed it to match (more likely, and this is indeed the case). The two options would seem to be to track down a 10SP FD or upgrade shifters, FD, RD and cassette to 11SP (lol, if only I could justify this).
Cheers!
PostPosted: Sat Apr 20, 2013 6:57 pm
Cheers!
Track down? They still make them.
PostPosted: Sat Apr 20, 2013 7:36 pm
I had this exact problem with my time trial bike last season. I have to admit that it was my fault as I had not adjusted the limit screw correctly (I was pretty sure I had). Solution: got a 10 speed chorus front mech & made sure it was correctly adjusted this time! I've gained about 5g in weight on the bike but it shifts better than the record one.
Paul.
If the grand tours are like classical music, kermesse racing is punkrock, Belgian style.
Colnago C50, Campag SR11
PostPosted: Sat Apr 20, 2013 11:07 pm
Tubbie Guru
Hi,
There's a good chance I may still have mint and boxed a 10S Record FD in the basement. If I do it must one that handles both regular and compact chainrings , you know the ones with the Mbrace system. A braze-on one.
Ciao, ;)
PostPosted: Sun Apr 21, 2013 3:12 pm
They do, if you want Veloce. I don't think they make all 10SP versions anymore as I'm having trouble finding a new one of what I'm looking for.
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], dem, Google Adsense [Bot], jeffbong, johanfl, Majestic-12 [Bot], Mario Jr., martroy, MattSoutherden, maxxevv, Rob1519 and 66 guests
There are no new unread posts for this topic. Attachment(s) Campagnolo Record front derailleur part
tojnom
Mon Aug 20, 2012 9:21 pm
tojnom View the latest post
There are no new unread posts for this topic. Chorus 10 Speed QS front derailleur with 11 Speed Record
rhyslewisdavies
Mon Jun 04, 2012 10:48 pm
rhyslewisdavies View the latest post
There are no new unread posts for this topic. Super Record EPS vs Record EPS, worth it?
Ufgators
10
1095
Thu Aug 30, 2012 10:58 pm
dereksmalls View the latest post
There are no new unread posts for this topic. Any changes for Record/Super Record EPS for 2013?
Ufgators
Sun Aug 26, 2012 9:14 pm
ultimobici View the latest post
This topic is locked, you cannot edit posts or make further replies. 2010 super record 11 vs 2012 super record 11
Rumshcawheely
Sun Feb 24, 2013 2:21 am
milroy View the latest post
It is currently Fri May 24, 2013 2:23 pm
