RECORD 10 FRONT Der HELP!!!
PIPO
by PIPO
weeracerweenie wrote:drill through outer plate, build a alloy or carbon tube spacer, run a longer bolt through outer cage, tube spacer and into the inner plate, problem solved. Fixable if it happens again, light :o and easy...
I may have to try this on mine :beerchug:
Jamis Xenith SL
smokva
by smokva
To revive an old thread. Carbon cage of my old 2009 FD also broke. I replaced it with metal cage from Chorus derailleur. Changing process is nothing you can't do with pliers but you will need 4 hands.
Sent from my SM-G960F using Tapatalk
