Post new topic Reply to topic  [ 30 posts ]
Go to page 1, 2  Next
PostPosted: Mon Jun 25, 2012 2:20 pm
Hi All
Can anyone help with advice?
I am on my THIRD Record 10 Sp Front Derailleur (the crappy carbon one) that has (AGAIN) broken at the back-end, that stupid little piece that slides/screws onto the back of the cage.... they keep breaking - this time when chain slid off the front ring, pop! Another 150 bucks down the [beep] drain....
These Derailleurs ABOSULUTLEY SUCK
Has anyone found a fix? Campy won't supply the 5 cent piece to me and says I have to buy a WHOLE NEW Der.!
WTF?
So for those who have experienced it, is there a trick to repairing these?
OR should I just look for an older gen. all-metal part and buy that instead? If so, what is compatible w 10 sp QS Ultra? I think 2008 Record was metal? Or at least Chorus was? What about a triple? would that work jus as well?
I am running a Compact front w 11-25 rear cassette
Thanks
Little bit of profanity removed.
PostPosted: Mon Jun 25, 2012 2:48 pm
This is a new breaking issue for me. I have been using the carbon 10 spd FDs for a while and never had that issue, even with the ones that are bolt tuned. I also have some older all alu 10 spd Campy FD's and the carbon ones have proven to be none less durable.
Send a picture of your set up and broken FD if you can.
Are you using a chain catcher on your frame? Sounds like it might be good idea for you.
PostPosted: Mon Jun 25, 2012 3:16 pm
Here you go
no chian catch but maybe need it, chain fell off the front and slid down the crank arm and then pop... its my 3rd to break (other one in a crash and the other during a hard-shift uphill under power - not an ideal shift maybe but should never have broken, really c'mon its Campy Record if it can't support a shift uphill then thats a sad statement)
Guy at the bike shop says he's seen this too and recommends getting an older gen metal front der. but wasn;t sure what years/models would be optimal.
thanks for any advice on repairs or replacement
PostPosted: Mon Jun 25, 2012 3:22 pm
... and ok crash - I understand things break, but Campy won't supply a replacement for that little metal end piece that would just slide on and get screwed-in, seems like an easy no-cost part to replace if supplied by them but they just won;t do it! I thought that was the whole advantage of Campy that you could repair parts instead of replace them for stupid little things like this....
PostPosted: Mon Jun 25, 2012 4:17 pm
Sounds like the issue is not with the quality of the der but rather linked to both the mechanical adjustment of your frt der and your riding habits. Specifically, if your chain is falling off the big ring then you simply have your limit screw set incorrectly...easy fix if adjustment is done correctly. Second, and more importantly, if you are shifting under load (as you describe) going uphill (really?), then really you shouldn't be surprised what has resulted. As for a fix, I suspect you could McGyver one of these out of plastic with a sharp x-acto knife and some epoxy.
EM3
________________
My 2011 Cervelo R5
PostPosted: Mon Jun 25, 2012 4:58 pm
gitsome wrote:
no chian catch but maybe need it, chain fell off the front and slid down the crank arm and then pop... its my 3rd to break (other one in a crash and the other during a hard-shift uphill under power - not an ideal shift maybe but should never have broken, really )
You don't know what you're doing.
PostPosted: Mon Jun 25, 2012 5:50 pm
beeeeeeeep
Gitsome has received a warning for this very post.
PostPosted: Mon Jun 25, 2012 5:56 pm
I had this problem when I was running record 10speed and had a chain suck. It fractured the composite side. My solution was an 11speed Athena. Shifted fine with no tiny adapter part.
PostPosted: Mon Jun 25, 2012 6:04 pm
Thanks - I love how some people here are so moralistic about replying wout hesitation it really shows limited intelligence - just bc I did not spend 15 mins decribing WHY I might have had to shift under duress does not mean I don't know what I'm doing, perhaps it was a breakaway to catch, perhaps I knocked a downshift by accident due to exhaustion, perhaps all of the above - or perhaps I just don't know how to ride a bicycle and should not dare bother posting for fear if judgement by shrivelled testicles like valbrona.
And half of my point, regardless of how and why something like thid happend, is wondering why its not readily replaceable and how to improvise a solution.
Thanks to the rest, I am reminded why so many quit posting WW
PostPosted: Mon Jun 25, 2012 8:29 pm
Hopefully you'll join that crowd. Hope you have a good day.
PostPosted: Mon Jun 25, 2012 8:44 pm
Administrator
I was going to post that I never had this problem with my campagnolo front der. and that it probably is due to mal alignment of the derailleur. But, I think I'm not going to tell after reading the aggressive tone of the OP.
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Tue Jun 26, 2012 12:19 am
To answer your question as to why campagnolo doesn't offer that little plastic piece is obvious. That piece is bonded to the carbon cage so obviously they don't want to have problems with customers that will install it incorrectly and complain to Campagnolo about it.
Thats why you have to buy the whole cage part. This is one of the reasons why I don't use front derailleur with carbon cage.
At the price it costs replacing the cage, might as well go with a full front derailleur. The cages are swapable so you can get a full alu chorus cage and install it on you record derailleur. I've done it several times. I have a front super record derailleur with a chorus 10s cage installed on it to run on my 10s record groupo.
I also suggest you adjust carefully your front derailleur and also try to shift less in power especially going uphill. install a chain catcher just to be safe. With an aluminum cage you won't break it thats for sure.
Salice sunglasses for sale PM me for info
PostPosted: Tue Jun 26, 2012 1:09 am
Yes Im searching out an alu chorus derailleur now, that seems the best answer. To the rest who replied with nothing constructive, you know what you can do. I have spoken with more than one ex-pro who has informed me the all use the chorus for the same reason unless sponsored to do otherwise, so its not my ability, its a badly designed part. I guess the rest dont push hard enough to find out. I will leave it at that.
PostPosted: Tue Jun 26, 2012 3:17 am
If you can't handle the bit of push back that some of us provided, given our reaction to how your original rant was worded, then next time try a bit of honesty and humility. Perhaps you could have just asked, "Does anyone know where I could find X replacement part for this Campagnolo frt der?" Instead you ranted about how Campagnolo carbon frt ders suck and a few sentences later described evidence linked to user error that contradicted your claims of a design flaw.
To be consistent with the etiquette of this form, some of us simply chimed in to correct your claims about design flaw and point out that the apparent flaws were actually linked to your riding style and mechanical abilities...the Campagnolo frt der was simply the collateral damage of your choices.
The only flaw I have witnessed and heard about on this forum regarding Campagnolo frt ders is cosmetic, linked to carbon peeling from the front plate. Also, I do recall a famous Belgian being sidelined last year in the Forest of Arenberg when his chain found its way out from between the cages of the frt dear and then he was unable to thread the chain back on the big chainring (see: http://cimacoppirides.files.wordpress.c ... mchain.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; ). The only way the chain could have found its way out of the cage was if the same tab you describe broke off, HOWEVER, Boonen's post-race report indicated that he experienced chain drop and he had to yank the chain to get it unstuck from between his chainrings and chain catcher or threaded back onto small chainring from behind the chain catcher (reports are unclear). I suspect his chain yanking perhaps resulted in a broken frt der tab when the chain was finally liberated, but we will never know exactly.
I suspect that if there was a real design flaw in Campagnolo's frt carbon ders we would have heard about it here and also seen component workarounds in the pro ranks...I am referring to "real" pros here. Just like we see pros opting for the retrofitted steel cage Sram Red front ders instead of the OEM carbon cage model, we would see all Campagnolo Record/Super Record equipped pro teams opting for equipment modifications as well...we simply do not see that because it is not a design flaw.
Lastly, I still think that my constructive suggestion to fashion a tab out of plastic and epoxy is a do-able solution.
Good luck.
EM3
________________
My 2011 Cervelo R5
PostPosted: Tue Jun 26, 2012 3:35 am
And there's the key point...you're on your third derailleur and still haven't learnt that it's not the fault of the part... :roll:
"It never gets easier, you just go faster..." - Greg Lemond
"Because technology alone is a poor substitute for experience." - Richard Sachs
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], Leviathan and 57 guests
There are no new unread posts for this topic. Attachment(s) Campagnolo Record front derailleur part
tojnom
Mon Aug 20, 2012 9:21 pm
tojnom View the latest post
There are no new unread posts for this topic. Chorus 10 Speed QS front derailleur with 11 Speed Record
rhyslewisdavies
Mon Jun 04, 2012 10:48 pm
rhyslewisdavies View the latest post
There are no new unread posts for this topic. Super Record EPS vs Record EPS, worth it?
Ufgators
10
1100
Thu Aug 30, 2012 10:58 pm
dereksmalls View the latest post
There are no new unread posts for this topic. Any changes for Record/Super Record EPS for 2013?
Ufgators
Sun Aug 26, 2012 9:14 pm
ultimobici View the latest post
This topic is locked, you cannot edit posts or make further replies. 2010 super record 11 vs 2012 super record 11
Rumshcawheely
Sun Feb 24, 2013 2:21 am
milroy View the latest post
It is currently Sat May 25, 2013 6:47 pm
