Need your help with the correct chainset for a pressfit BB
WasFab
by WasFab
Which Shimano or (FSA) chainset will fit a pressfit bottom bracket which is not a BB30. ( I know FSA Mega is external so will never go with pressfit or 30 BB) With my little understanding I guess that any Shimano will go to pressfit type like all the pressfit bike as Scott, TCR, Wilier Cento, ect... But I need to be sure.
Your help is needed.
carbon337
by carbon337
Any, just get the correct bb86 or bb90 bottom bracket. I have a fsa Bb86 in mine with a 6700 crankset.
All fsa and all shimano will work, most SRAM except bb30 too.
WasFab
by WasFab
Thanks that's what I thought. Also do you know if it is the same rule for Rotor?
WasFab
by WasFab
carbon337 wrote:Any, just get the correct bb86 or bb90 bottom bracket. I have a fsa Bb86 in mine with a 6700 crankset.
Would you know to tell if it will work as well with the Ultegra 6600 and 6600 SL chainset?
Thanks
I am here: http://tapatalk.com/map.php?qhn342
Machinenoise
by Machinenoise
Rotor 3d is 24mm spindle, 3d+ is 30mm. if its not press fit the you can use their enlarged external bearings to fit the 3d+.
but the 3d will fit in a BB86
WasFab
by WasFab
I have better question which might help me to get what I am looking for
Which bottom bracket press fit type (if exist) is needed for a FSA chainset to be installed on BB90 shell?
I know FSA has a pressfit BB386 but I guess it is a different frame's shell than BB90 frame's shell.
I am here: http://tapatalk.com/map.php?ixt0vu
thisisatest
by thisisatest
as long as it's their k-force light or sl-k light crank, this is what you need
http://www.fullspeedahead.com/products/79/BB-AL90
or the ceramic version
http://www.fullspeedahead.com/products/78/BB-CF90C
WasFab
by WasFab
thisisatest wrote:as long as it's their k-force light or sl-k light crank, this is what you need
Thanks for that it's very helpful. That means inside my frame shell which is computable SM BB91 from Shimano I can install these bearings you suggested if I want to use the K Force or SL-K Light from FSA, is that correct?
I am here: http://tapatalk.com/map.php?11mi4p
WasFab
by WasFab
also I read in the competitive cyclist that the BB AL90 version only with works with the gossamer cranks but not with their carbon cranks as the k-force and the SL-k is carbon. Any suggestion?
Here is the link http://www.competitivecyclist.com/product-components/2012-FSA-BB-AL90-Bottom-Bracket-Assembly---BB90-6725.19.1.html
I am here: http://tapatalk.com/map.php?0wzixv
