It is currently Wed Jan 17, 2018 12:25 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sat Jun 23, 2012 6:26 pm
Hi WW :)
I'm going to start my first weight weenie project and has purchased a Cannondale Optimo CAAD7 from 2004 with BSA BB (1290g).
It will be a long project because the economy is tight.
The first purchase will be a fork, I have long searched for a full carbon Slice fork on Ebay, but without success. Can you guys recommend a fork that fits on my dale?
thoughts on weight: 300-400g
First post :D
Cheers
Lopro - Denmark
PostPosted: Sat Jun 23, 2012 7:46 pm
For a tight budget I would go with this. Would be a perfect fit for the Cannondale 371 axle to crown(according to an email I got back from Pedal Force) with 45mm offset.Image
Another good option, but more money would be one of the Ritchey forks.
If going with the Ritchey get the 43mm offset to make up for the shorter fork(367 Axle to crown) and consequently steeper head tube angle and lower bottom bracket.
PostPosted: Sat Jun 23, 2012 9:17 pm
CAAD forks are 362mm axle to crown. 45mm rake. See thread. http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=88574&p=766407&hilit=CAAD+axle+to+crown#p766407
--Max.
PostPosted: Sat Jun 23, 2012 9:33 pm
Not sure of the caad 7 S&R numbers, but going by current S&R for the Caads(9 and 10) 362 is a mathematically impossible. They are 371-372.
PostPosted: Sat Jun 23, 2012 9:51 pm
Thanks, I will take a look at that. My fork is btw approximately 371mm axle center to crown.
I've looked at Controltech Lightning Forks 325g for 235€, 370mm , offset 43mm.. any thoughts ?
http://www.chainreactioncycles.com/Mode ... elID=21555
PostPosted: Sat Jun 23, 2012 10:10 pm
I weigh 82 kg btw, /181 lbs
PostPosted: Sun Jun 24, 2012 3:13 am
Cannondale fork for those bikes are around 367mm.
You can find some used Cannondale Premium forks around.
PostPosted: Mon Jun 25, 2012 4:45 am
If you can find one, I used a Reynolds Ouzo Pro fork on my CAAD7 for several years and it worked great. I don't remmber the details, but I believe it was very close in leg length, but a couple degrees off the stock rake, but I never noticed that.
PostPosted: Wed Jun 27, 2012 10:48 pm
Not really a budget option but a second hand enve/edge fork is fantastic on these frames.
Quiet a few guys have run Easton forks on CAAD frames.
Sent from my iPad using Tapatalk HD
Caad9 BBQ Durace7800 build
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=82445#p721875
PostPosted: Fri Jun 29, 2012 1:29 pm
Thanks for yours feedback so far :thumbup:
I have been offered an Controltech Lightning Full Carbon Road For for almost no money. aprox 330g
• Crown race: 30mm, 45mm crown for integrated headset
• Steerer: 1-1/8”
http://www.chainreactioncycles.com/Mode ... elID=21555" onclick="window.open(this.href);return false;
But will i fit on my dale?
PostPosted: Fri Jun 29, 2012 4:14 pm
Yes it will fit. Any 1 1/8 fork will. The only concern(not to 99.999% of people though :wink: ) is the length and how it will effect the steering. Worse case scenario the new fork will be up to 5mm shorter or longer. Using the same offset as the original a fork 5mm shorter will steepen your head tube by approximately 2.5 degrees, drop your BB by about 1.75mm and decrease your trail by about 2.5 mm. All of that would make your bike turn a wee bit faster. Reverse those approximates for a fork 5mm longer making for a wee bit slower turning bike. Cannondales geometry is really vanilla, so a change in fork length isn't going to turn it into a poor riding bike.
There are no new unread posts for this topic. Look HSC 5SL fork in a CAAD7 frame
hoojammyflip
Sun Mar 19, 2017 10:14 am
hoojammyflip View the latest post
There are no new unread posts for this topic. Fork length Ridley Helium SLX fork?
Beaver
Mon Jul 17, 2017 5:31 pm
Beaver View the latest post
There are no new unread posts for this topic. Cervelo s3 fork
trilocus
Mon Jul 31, 2017 1:57 pm
kookie View the latest post
There are no new unread posts for this topic. Attachment(s) PLEASE HELP!!!! FORK ISSUES!!!!
2phat2slow
Thu Oct 19, 2017 6:32 am
anquetil View the latest post
2phat2slow
Thu Oct 19, 2017 8:15 am
Stolichnaya View the latest post
Users browsing this forum: Bing [Bot], coriordan, Greatestalltime, wingguy and 49 guests
cron
