Post new topic Reply to topic  [ 40 posts ]
Go to page Previous  1, 2, 3
PostPosted: Sat Aug 18, 2012 12:37 am
Alibongo:
What did you use for the BB? I would like to go to a Rotor 3D+ crank with a Power2 max spider. The BB for that crank does not have a sleeve between the bearings and I am afraid the EPS wiring could get damaged by the cranks shaft. Not sure what to do.
"It's all about the Tempo"
PostPosted: Sat Sep 01, 2012 3:08 am
Everything I'm reading says that the new Dogma sticks with an Italian threaded BB, but what is this:
Anyone who's ridden one care to chime in?
PostPosted: Sun Sep 09, 2012 3:15 am
Whats what?
All Campagnolo UT Cranks use that outboard cup...
PostPosted: Sun Sep 09, 2012 3:19 am
I just don't see any splines for the BB tool on the cup, I could be missing it though. Look at the shimano one here http://www.pinarello.com/eng/dogma65_carbon_850.php if you zoom in and rotate the bike to the non-drive size diagonal, it doesnt look like there are any splines there either.
PostPosted: Sun Sep 09, 2012 3:20 am
that's a pressfit cup. no notches for a wrench required when threading something in. this goes hand-in-hand with what i thought i saw sometime last year- a dogma2 with SHIMANO BB30 CRANKS. but i couldve been wrong, and that's for another topic.
edit: with mgordon's link, you can see that pinarello states the "bbracket" is "Most Croxover", whatever that is, but its probably some adaptable system.
edit:edit: it appears they all are called "most croxover", although only the dogma65.1 (and dogma2) are the ones that definitely have the press-in cups.
PostPosted: Sun Sep 09, 2012 4:32 am
Just looked on the wrenchscience and competitive cyclist websites.... wrench science says its a pressfit, which is evident from the picture above.. compcyclist says its Italian thread.. I guess they just did a copy paste from the regular dogma on the specs....
PostPosted: Sun Sep 09, 2012 4:36 am
Im not liking this whole pressing cups into a frame deal... Ive heard nothing about creaks everywhere.. it was really noted with the Campy cups on a Ti frame... maybe the carbon with Loctite is more forgiving....
I know on my EVO I have for sale, its made my 2010 SRM useless because of the pressfit30 cup lip not being able to clear the powermeter back plate....
Since Im a campy only guy, the only option is a pressfit cup and Campy SRM... can you say $$$$
Just can't justify it.. especially with how light and stiff Hollowgram cranks are..
PostPosted: Sun Sep 09, 2012 4:43 am
@pariscarbon,
you may be in luck, as the new spindles that are coming with sisl2 cranks are a little bit (but not a lot) longer. they may have a different taper on the splines, i will find out tomorrow...
PostPosted: Sun Sep 09, 2012 5:40 am
Wrenchscience actually says both:
"Features:
Bottom Bracket: Press fit"
and
"The Dogma 65.1 will carry over ... the Italian bottom bracket..."
PostPosted: Sun Sep 09, 2012 5:41 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: addictR1, Bing [Bot], bratz, Google [Bot], kya, TiG, timj and 52 guests
There are no new unread posts for this topic. 2013 Pinarello Dogma 65.1 Think 2 Replica
tlow
29
5483
Fri Feb 08, 2013 2:29 pm
kgt View the latest post
There are no new unread posts for this topic. Dogma 65.1; Look 695 or Colnago C59
hdeprins
26
2399
Sat Apr 13, 2013 12:46 pm
Edo View the latest post
There are no new unread posts for this topic. Attachment(s) Dogma 2 65.1k weight?
[ Go to page: 1, 2, 3, 4 ]
Donn12
54
4923
Sat Mar 23, 2013 3:04 pm
HammerTime2 View the latest post
There are no new unread posts for this topic. Dogma 65.1 sizing help.
Sparks
9
1244
Sat Dec 29, 2012 10:55 pm
Geoff View the latest post
There are no new unread posts for this topic. Pinarello Dogma ?'s
upside
Fri Mar 08, 2013 10:54 pm
upside View the latest post
It is currently Wed May 22, 2013 7:41 am
