It is currently Mon Jan 23, 2017 3:55 am
Post new topic  Reply to topic  [ 82 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Tue Jun 26, 2012 10:58 pm
I'm also 100Kg ex Rugby front row build and average height, 5' 8". I have a litespeed Archon in M/L size, with the easton EA90SL fork.
With my light weight setup I'll typically notice wheel flex first. I'll notice Stem/steerer tube flex and BB flex when sprinting a step incline.
Stiffer wheels help, but are still a flexy component at my size.
PostPosted: Wed Jun 27, 2012 6:38 am
The Seven custom fit sheet gives you the option of selecting your build based on weight versus performance. Do bear that in mind.
I love Ti but would look to save weight elsewhere in the build and have a frame that is built for the purpose. I have s Sturdy Seven. The frame weighs over 1400g but with some Lightweights, bb30 and Hollowgrams, SRAM Red and a Ceradur cassette I'm down where most people's plastic rigs are without compromising stiffness.
Sure it's more expensive to do it that way but saving weight without losing performance always has been in my book..
PostPosted: Wed Jun 27, 2012 7:48 am
One addition -- even heavily butted tubing may not benefit larger size frames as much, because most butted tubes have a relatively "fixed" length of thin walled section in the middle, so on a larger sized frame, you tend to have more "thick walled" section in the longer tube, which partially defeat the purpose of butting. It will be quite expensive to have tubes butted individually to suit a particular size.
Another reason not to be fixated on weight of the frame.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
PostPosted: Fri Jun 29, 2012 6:44 am
Are you kidding? I find it very hard to believe high end companies such as Seven, Firefly, Moots, Baum etc would be using tubing with limited generic butting...
"It never gets easier, you just go faster..." - Greg Lemond
"I enjoy climbing...I enjoy seeing people disappear behind me." - Robert Millar
PostPosted: Fri Jun 29, 2012 8:35 am
Not sure where you get your info from elviento, but I know for Baum at least that is incorrect.
http://www.nicksquillari.com.au
PostPosted: Fri Jun 29, 2012 3:26 pm
Hey OP if you are still around
What you didn't like about your carbon bike, was that it is too light and too stiff for you, that is why it rides the way it does.
So, speccing a new bike primarily based on low weight and high stiffness is not going to solve your problems.
There are more comfortable carbon bikes you could find,
There are superior (and heavier) Titanium or steel alternatives.
Shave weight on wheels, allow a few more grams for a proper frame. If you want stiff and strong, I like Moots - straight tubes no butting. Skip the RSL that is more of what you dont like about your carbon bike (racy, light, stiff, ugly IMO).
Steel is real too, and dampens road chatter way better.
If you find an uber-light titanium clone of your carbon bike you will have exactly the same ride complaints.
PostPosted: Fri Jun 29, 2012 11:31 pm
+1 for Baum... 85kg, 182cm rider, peak power is 1786w. Never had an issue on my Baum Corretto. I rest assured knowing they have a great warrant system.
Baum Corretto - Custom built Ti Road Bike - 6.6kg
Baum Corretto - Custom built Ti Track Bike - NAHBS 2012 - 5.9kg
Baum Corretto - Custom built Ti Road Bike - Lightweight Obermayer Gold Ed 07/99
Colnago C50
1975 Richard Sachs track bike
PostPosted: Sat Jun 30, 2012 7:54 am
reggiebaseball wrote:
What you didn't like about your carbon bike, was that it is too light and too stiff for you, that is why it rides the way it does. ... So, speccing a new bike primarily based on low weight and high stiffness is not going to solve your problems. ... If you find an uber-light titanium clone of your carbon bike you will have exactly the same ride complaints.
Good post. I've tried carbon, alu, TI and steel, but I keep going back to steel and now ride that exclusively. My current ride comes in at 6.5kg with my lightest wheels and it rides on rails because of the geometry. For me it's about comfort and the ride delivers that. I found carbon in general to be too twitchy for me although maybe that was partly due to geometry.
PostPosted: Sat Jun 30, 2012 9:11 pm
I've really enjoyed this thread. I'm still 12 kg off the OP's weight, and am still more than content with my swift steel;have porkies ever enjoyed Ti bikes? Maybe one day. Is the 2lb weight diff worth it? My bike is 5 lb's lighter than my steels of old, and much stronger,which gives a satisfying lack of weight when I lift and ride it.
PostPosted: Mon Jul 02, 2012 9:43 am
I happened to stumble upon some info that seems to confirm this. From the horse's (the horse being Darren Baum himself) mouth: ... we do everything from start to finish - from butting the tubes to the paint. (There's a short bit on Baum in RBA's July issue.)
PostPosted: Sat Aug 25, 2012 10:14 pm
Tinea Pedis wrote:
I can assure the OP (and anyone else not reading the whole thread) that you could get a Corretto for that weight that will be more than stiff enough for him.
Also quite sure other brands would be able to come close too.
A big :thumbup: to everyone who has replied to my question. Sorry for the slow reply but I was away on vacation riding my bike!
I will try to answer a few of your comments and add more details to help narrow down my selection.
-A typical ride for me is on rolling or hilly roads where the average speed over ~50 miles would be no more than ~22mph. My technical skills are very good thanks to 25+ years of mounting biking (some amature racing) and DH'ing (Black Diamond terrain + freeride) but there is no danger of me winning the next local stage race!
-In terms of power output (Watts) I really don't know. I am not a sprinter but I can crank it up when required. Still, most of my riding is done while seated.
-I am a big time WW hence posting my Titanium frame question on this site! I also have a great appreciation for beautifully made products and bikes that are kind on the eyes. There is no question that I want a bike that looks stunning as well as one that rides well....and it has to be sub-14lbs but with the right mix of parts I could probably get there using a ~14XXg frame.
-There really isn't a firm budget for the frame/fork (already have the other bits) but it would be nice to keep it to $5k or less.
-My 'main' road bike is a couple of year old Scott Addict w/ISP. It is very light and plenty stiff but the overall geometry has never felt quite right and the ride can be unforgiving on rough roads or coarse pavement.
So where do I go from here?
I hadn't heard about Baum until now but they are at the top of my list! Is there any reason to think that any of the other brands could offer a better bike than Baum builds? The others that still have my attention are Lynskey (Helix OS or R440), Moots (Vamoots RSL) and Seven (Axiom SLX).
PostPosted: Sat Aug 25, 2012 10:19 pm
All the brands you are looking at are good. I do not think $5k will get you a Baum though.
PostPosted: Sat Aug 25, 2012 10:59 pm
Fair enough.
I can go beyond $5k if needed, plus I would order a raw Ti finish, not a fancy paint job.
PostPosted: Sun Aug 26, 2012 12:18 am
The AUD is high so it does not play in Baum's favor.
PostPosted: Sun Aug 26, 2012 12:35 am
i have a helix and a L4 custom, both are great
Im 6'7 90kg National TT medal winner so pretty powerfull and i have no issues with flex from either of them.
My custom lynskey TT'er is not bad either (-;
There are no new unread posts for this topic. Campagnolo 2015 UT / Italian threaded BB / Titanium frame - best practice
mriddle
16
1247
Sat Jul 30, 2016 1:54 pm
mriddle View the latest post
There are no new unread posts for this topic. PF30 alternative to Praxis for Campy Ultra Torque in titanium frame.
Cooperee
14
1066
Thu Sep 08, 2016 8:49 pm
Cooperee View the latest post
There are no new unread posts for this topic. "Finishes" on Titanium bikes... Is this what a Ti frame should look like up close?
McGilli
20
2416
Tue Aug 02, 2016 7:41 am
Wingnut View the latest post
There are no new unread posts for this topic. Large Bike Recommendations
JoeFlan
Sun May 08, 2016 9:30 pm
Treelegs View the latest post
There are no new unread posts for this topic. Large sram force shifter weight difference - how come?
alcatraz
9
635
Sun Oct 09, 2016 12:40 pm
alcatraz View the latest post
Users browsing this forum: eyedrop, Google [Bot] and 32 guests
