Post new topic Reply to topic  [ 77 posts ]
Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Jun 23, 2012 5:21 am
Which brands should I look to for a light weight Ti frame in a large size (~60cm) for a 90kg rider?
I am a recreation rider but a major WW so it must be light! Is sub-1250g realistic? I am just growing tired of the aggressive geometry and harsh ride of my carbon machine.
So far the Lynskey Helix is at the top of my list. Others?
Thanks :thumbup:
PostPosted: Sat Jun 23, 2012 7:13 am
Moots, Eriksen & Firefly deserve consideration
PostPosted: Sat Jun 23, 2012 9:17 am
I'm not sure if you are going to be happy wirh a <1250gr Ti frame in size 60 when you weigh 90kg.
If you want comfort and light weight try the usual suspects, Like Specialized Roubaix or Cannondale Caad10 with a Canyon or Engage seatpost and 25mm (or 28mm) tires. Add a zipp sl bar and stem and you're good to go.
PostPosted: Sat Jun 23, 2012 10:52 am
Online
I would think the Moots RSL leads the Ti class on the weight scale, and I've never read a negative comment on it (or any Moots for that matter). It would easily be my first choice. As said above, Firefly and Erickson are strong candidates too. The upper Lynsky bikes should be suitably lightweight too.
I will also agree that at your weight, the lightest and stiffest option (in the right places) will be the Roubaix although its carbon (which I like). Its a superb bike too.
PostPosted: Sat Jun 23, 2012 11:30 am
Serotta, Indie Fab, Baum (you can get full custom with these also)
Current Harem: Sally (Serotta Nove - Ti/C), Peggie (Pegoretti Love #3 - Alu), Speedy Custom Baum (Corretto - Ti)* & Climbing Baum (Corretto - Ti)*
*Lady names just never came to me.
PostPosted: Sat Jun 23, 2012 12:20 pm
I have been on a Moots RSL the last 18 months. Weigh 210 or so. The best ride I have been on in a long time. The choice of wheels and tires makes a huge difference on the ride, racy and stiff, or more comfortable.
PostPosted: Sat Jun 23, 2012 12:24 pm
For the size frame you're looking at I don't think 1250 is realistic even with a helix or helix OS (that's med/large territory) just too much material required. The other manufactures listed would have the same limitations. As for the RSL it is indeed lighter than a standard Moots but based on the one i handeled at a LBS not really super light (around 1250ish for a 56).
PostPosted: Sat Jun 23, 2012 1:16 pm
My sz L Archon frame comes in around 1100g or so. You'd be close to 1250g on the XL. The frame is very stiff so maybe not what you are looking for if you want that classic Ti ride.
PostPosted: Sat Jun 23, 2012 3:43 pm
If thinking Lynskey, also look at the R440. Noticeably stiffer than the regullar Helix. I've never ridden a Helix OS so can't comment on that. Ask Jack or Mike at Lynskey. They're very helpful and easily accessible by web or phone. All this being said, I own two Lynskeys and am happy with them (R430 and ProCross). However, if the wait for custom (and possible slight cost increment) aren't factors for you, go with Firefly. Lynskey - great bike. Firefly - ultimate bike. They weren't around when I bought mine, plus I had some shop/team loyalty issues factoring into my purchases.
PostPosted: Sat Jun 23, 2012 8:13 pm
Try Titan Road Sport frames. The 54cm frames weighs ion at 1100g and is very nice. I know a few folk riding these and they are very happy with them.
Custom frame too or one of stock dimensions. I can supply them as well. The bloke who runs it will suply the frame although it can be built up I work with him on bike builds e.t.c.
www.thecycleclinic.co.uk
PostPosted: Sat Jun 23, 2012 8:33 pm
95 kilos and my choice is not ti but one of the new steels. 953 IMO is a better choice for a big rider. My Independent Fabracation is the best frame I've ever tried (hey it was built for my geometry and size). You weight goal for a frame is not going to happen unless your happy with a noodle at your weight. My IF is 6.85 kilos at the moment with no weight restricted parts but the frame is north of 1500 grams. I wanted a stiff ride, if you go lighter with ti at our size things get soft. 953 is stiffer then ti if weights are the same and is more scratch and dent resistant
WW Velocipedist Gargantuan
PostPosted: Sat Jun 23, 2012 10:33 pm
Just to add more data to the thread, my Lynskey R330 (medium) came in at 1480g. Sub 1250 might be tough, or noodley.
PostPosted: Sun Jun 24, 2012 12:41 am
Too light of a bike + too heavy of a rider = bike all over the place
If you really want a sub 1250 gr frame you may need to look into the Ti/carbon combos to get more choices and still end up with a setup that will have a chance of performing under your weight.
PostPosted: Sun Jun 24, 2012 1:01 am
A Baum Corretto, even in that size, will be around the 1250g mark for sure.
Less depending on how much butt they put in the tubing. Less again if you go a bare metal finish (which looks damn good!)
PostPosted: Sun Jun 24, 2012 1:09 am
Anyone who says Ti is not stiff enough at the OP weight has no idea what modern custom Ti frames are like.
I'd say get Baum, Seven or Moots all are custom. Get a nice set of stiff wheels too (almost as important as a stiff frame). Something built with Alchemy or Tune hubs at 28/28 spokes. You'll be very happy. Or get Carbon wheels.
Post new topic Reply to topic  [ 77 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Users browsing this forum: bman11, Google Adsense [Bot], jdott, sneakywhale and 68 guests
There are no new unread posts for this topic. Light weight daily semi-aero wheels for a light weight rider
dvincere
15
2607
Sun Jun 03, 2012 9:44 pm
numbers505 View the latest post
There are no new unread posts for this topic. Frame help - small rider
Martin.F
9
535
Tue Jun 19, 2012 2:16 pm
strobbekoen View the latest post
There are no new unread posts for this topic. Titanium frame needs a refresh
jedijeck
Thu Mar 28, 2013 3:46 pm
Flasher View the latest post
There are no new unread posts for this topic. Titanium/steel frame help
canbakay
22
1361
Thu Mar 14, 2013 12:23 am
maxxevv View the latest post
There are no new unread posts for this topic. Attachment(s) Looking for a Carbon/Titanium Frame
scotty
16
1290
Thu Feb 14, 2013 9:55 am
atakaoka View the latest post
It is currently Sun May 19, 2013 8:37 pm
