Post new topic Reply to topic  [ 13 posts ]
PostPosted: Fri Jun 22, 2012 6:44 am
http://www.bikeradar.com/news/article/r ... els-34307/
i like the wheels... wonder how much the 58 rim weighs.
PostPosted: Fri Jun 22, 2012 7:40 am
Interestingly the new "step hook" is on the opposite side of the old "swirl lip".
Bikes: Raceur, Beateur
PostPosted: Fri Jun 22, 2012 7:47 am
According to one of their representative that i have met, they are not focusing on weight on the AERO version but more on the Aero effect of the wheels, so they will not be the lightest.....
My Builds so far... C50,EPS Erik Zabel, C59 Di2.
PostPosted: Fri Jun 22, 2012 8:43 am
-nm-
Exp001
PostPosted: Fri Jun 22, 2012 3:15 pm
I think they look sweet!
PostPosted: Fri Jun 22, 2012 5:58 pm
That sucks... it would be nice if someone made a light aero wheel. everything in the 60mm range is over 500g per rim.
does anyone know if these are tubeless compatible? not mentioned in the article.
PostPosted: Fri Jun 22, 2012 7:32 pm
Not tubeless ready but with some stans tape or some of the american classic tape it can be rune tubeless. As well as every other carbon clincher.
PostPosted: Fri Jun 22, 2012 11:56 pm
thanks for the info... would that mean i would have to run sealant or just the tape? if i have to deal with sealant, i would just say no and run standard clincher.
PostPosted: Sat Jun 23, 2012 12:27 am
Huh? The sealant you are referring to (specifically Stans Notube Sealant) has two purposes. Purpose 1 is to coat the inside of non tubeless tires and allow them to be used as tubeless tires. Purpose 2 is to seal up punctures in tubeless tires, tubulars, and I suppose inner tubes too. Purpose 1 is kind of superfulous since various companies make tubeless ready tires. You can run them tubeless without any extra sealant. The tire is made with an air proof casing to prevent any air from going through the tire casing. Just mount the tubeless ready tire without sealant on a rim/wheel that is tubeless ready. Either the rim has no spoke holes or the rim has a sealant strip to cover the spoke holes. The sealant in Purpose 1 coats the casing of the tire and prevents air from passing through the tire casing. The sealant does not and cannot seal the spoke holes in the rim. Sealant and rim strip serve two different purposes. They prevent the air from leaving the tire/wheel in two different spots. The tire casing and the spoke holes.
PostPosted: Sat Jun 23, 2012 4:44 am
understood, thanks for explanation. i asked, if i have to run sealant or just the tape (maybe i should have said sealant and tape or is tape good enough) - i know i have to run the tape anyway to cover the holes. i was curious if i could run hutch full tubeless tires with just tape, as i do not care about messing around with sealant.
PostPosted: Sat Jun 23, 2012 3:33 pm
Oh nice... okay, so on one hand we have Bontrager making Aero R4 tires that have a "Aero Wing" that fills that gap between the tire and brake track... and now we got Reynolds making a "Step Hook" that has a deeper groove cut into that area to make it more "aero".
Each company says it's the fastest and most aero... who do we believe, when we have contradicting designs?
Not only that... but Reynolds have contradicted itself in designing their "fastest" wheels. Last year, we get the RZR, which are super thin, V shaped rims, and others rims with a "Swirl Lip Generator on the inside spoke area of the rim. Not we get the opposite, with really FAT rims with a groove in a totally different place.
Is this not evidence enough that all these little tricks are just for marketing a new product on the market and won't make any of us faster? It's all just to keep us wanting the newest, "fastest" parts.
PostPosted: Sun Jun 24, 2012 3:56 am
+1 :thumbup:
PostPosted: Sun Jun 24, 2012 4:21 am
Great point. Well, I guess it really comes down to wind tunnel testing. I can try to dig up some different stuff that you may be interested in. I believe Rouse Artisanales may be the place to start.
http://www.zencyclery.com
http://www.wheelbuilder.org
Users browsing this forum: Google Adsense [Bot], HammerTime2, jbf, Majestic-12 [Bot] and 51 guests
There are no new unread posts for this topic. Reynolds and Enve Carbon Clincher Rim questions
boneman
11
1781
Fri Dec 21, 2012 11:47 pm
ob1knob View the latest post
There are no new unread posts for this topic. Attachment(s) 2013 TREK - AERO for Everyone
[ Go to page: 1 ... 5, 6, 7 ]
spartan
90
14797
Tue Nov 20, 2012 2:26 am
hornedfrog View the latest post
There are no new unread posts for this topic. 2013 Tour Mag TT aero test
spartan
13
627
Sat May 25, 2013 3:14 pm
WMW View the latest post
There are no new unread posts for this topic. 2013 ZIPP 404 Firecrest Tubular vs Clincher
tinozee
23
2422
Wed Feb 13, 2013 4:21 pm
sawyer View the latest post
There are no new unread posts for this topic. Cervelo S3 slc sl 08 vs Madone 6.2 2013 ? Wich is more aero
CeCa
Sat Apr 27, 2013 9:00 pm
wingguy View the latest post
It is currently Sun May 26, 2013 3:29 am
