Post new topic Reply to topic  [ 7 posts ]
PostPosted: Thu Jun 21, 2012 1:19 pm
Hello,
I was wondering if I change from a Campagnolo Chorus 12-27 to a 12-29 cassette, will the current chain length still be ok for the 12-29 or will I have to ad a link with the new chain ?
I will use the rear wheel with a SR11 compact and standard crank.
Thanks for any input.
Pfeiffer's Rennrad Camp and Cycling Coach
Independent HED Wheels/Powertap Dealer
PostPosted: Thu Jun 21, 2012 2:43 pm
Unlikely.
Unless the chain fitted was cut super short. Normally I cut my chain longest possible with out rubbing on R/Derailleur when in 39/11. This allows cassette swapping from 23 to 25.
PostPosted: Thu Jun 21, 2012 3:11 pm
I did cut the chain according to the Campagnolo manual that comes with the chain.
PostPosted: Thu Jun 21, 2012 6:26 pm
I think you will be fine. I run a 11-29, I buy a 11-25 and a 12-29 and make a hybrid. You size the chain based on the smallest cog. You will need to adjust what they call the "b screw" when going with the 29. The instructions are in the RD manual.
PostPosted: Thu Jun 21, 2012 6:44 pm
We can all theorize all we want, but what help is it? You'll only know for sure when you install the new cassette and try it. Then either add the links or buy a new chain if you need to. You obviously know how to fit a chain properly, but the definitive test for the old chain on the larger cassette would be the "big-big" method. I don't know what Campy instructions call for, but I'd use the big-big in this situation as it gives you the minimum length you can use safely.
My speculation: if your campy instructions are similar to the "small small" way of fitting a chain (which gives you the longest chain you can get away with), I'd guess your old chain will be long enough for the larger cassette. If your Campy instructions are the "big big" method, I don't think your old chain will be long enough.
PostPosted: Thu Jun 21, 2012 7:17 pm
As far I can remember I used the "Small Small" way. I will look it up when I come home since I still have the instructions at home. I did order a new chain with the cassette together to make sure I have what I need, should the one I'm using now be to short. It's always good to have spare components anyway.
PostPosted: Fri Jun 22, 2012 12:46 am
And a chain will certainly be used, never a waste to buy one just in case you need it.
Users browsing this forum: Exabot [Bot], Google Adsense [Bot], sanrensho, tonytourist and 47 guests
There are no new unread posts for this topic. cassette changes and chain length
audiophilitis
9
311
Fri Jun 07, 2013 12:38 am
eric View the latest post
There are no new unread posts for this topic. Cassette gearing and chain length
tinchy
Thu Apr 18, 2013 12:04 am
Svetty View the latest post
There are no new unread posts for this topic. Sram chain length
neverwasbeen
10
412
Mon Feb 25, 2013 5:34 am
deek View the latest post
There are no new unread posts for this topic. Stronglight CT2 10/11-spd chainring & 9-spd chain/cassette
FuelForThought
Sat Jul 21, 2012 11:24 pm
FuelForThought View the latest post
There are no new unread posts for this topic. Campagnolo chain with shimano cassette?
Boss93
Fri Mar 22, 2013 12:03 pm
mikipov View the latest post
It is currently Wed Jun 19, 2013 12:07 am
