Post new topic Reply to topic  [ 6 posts ]
PostPosted: Thu Jun 21, 2012 4:38 am
Hello, I am out of ideas, under load/standing on pedals while in big ring and either 21 or 23(11-23 cassette), the rear creaks driving me nuts. I have inspected my fulcrum racing 1 wheel set, that's all good. Did any one else had this problem, I can't find where it's coming from, sounds like its the rear Hugh, please advice. Thx
PostPosted: Thu Jun 21, 2012 4:57 am
if its only in the 21 and 23, it's either that your cassette lockring is not tight enough, or (most likely) the rivets holding those cogs to their aluminum spider are creaking. if it's the rivets, i'd clean them very well with a degreaser like Clean Streak, blow dry them, then apply a wicking loctite to the rivet/spider joints. wicking loctites are generally for threads and not cylinder retaining, but it's worked on 2piece centerlock rotors for me so i feel itll work on a cassette.
PostPosted: Thu Jun 21, 2012 10:38 am
Also try cleaning and regreasing freehub pawls. This can be a source. A.
PostPosted: Thu Jun 21, 2012 2:50 pm
egreasing freehub pawls was the first thing I did, thanks
PostPosted: Thu Jun 21, 2012 6:55 pm
It does not often get mentioned, but cassettes can make creaky noises. Remove, clean off all the mating surfaces, reassemble with a light rub of oil, tighten properly, and see if that cures it.
Skewers are another source, and in the lowest gear are seeing the highest torque.
dangerous curves ahead
PostPosted: Thu Jun 21, 2012 10:11 pm
Kind of on a limb.. creaks often sound like they are coming from other places that aren't and only happen at certain times.. did you regrease your BB cups ? I had a nasty creak on my aluminum Prince SL... tried everything then tried the BB cups and problem solved..
Also ghost noises..on my Cannondale I had a banging noise.. thought it was valve stems... turned out it was the seatpost.. installed some carbon compound and it shut up...
Users browsing this forum: astranoc, Bing [Bot], Google [Bot], ipaul, KLabs, rijndael and 44 guests
There are no new unread posts for this topic. Campy Chorus 11 speed group/break pads advice
digitalnorbs
10
328
Tue Jan 15, 2013 8:51 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Chorus 10 Speed QS front derailleur with 11 Speed Record
rhyslewisdavies
Mon Jun 04, 2012 10:48 pm
rhyslewisdavies View the latest post
There are no new unread posts for this topic. 11 speed chorus front derailed set up
digitalnorbs
Sun Jul 01, 2012 1:41 pm
DaveS View the latest post
There are no new unread posts for this topic. Sram Red front derailleur(non yaw) with Chorus 10 speed shif
digiadaamore
Wed May 15, 2013 10:19 pm
dereksmalls View the latest post
There are no new unread posts for this topic. Compatibility Cable Set with Campy Chorus 10s QS levers
kojtl1000
Mon May 06, 2013 5:58 pm
bikerjulio View the latest post
It is currently Sun May 26, 2013 12:47 am
