Post new topic Reply to topic  [ 13 posts ]
PostPosted: Thu Jun 21, 2012 2:38 am
Looking for opinions/suggestions for handlebars that work well Campy ergo shifters. I know it is a personal choice but just curious what others like and dislike.
Thanks
PostPosted: Thu Jun 21, 2012 2:57 am
I have four bikes using 9 and 10 speed Campagnolo Ergo levers. I use TTT Morphe bars on all of them. These are anatomic bars with a fairly shallow drop. The tops of the bars behind the Ergo levers is flat and goes straight out. It does not angle down before reaching the Ergo levers. The Ergo levers are mounted horizontal at the ends of the bars. As far forward as you can get them. I have about 5 inches of flat space to place my hands. About 2 inches of the Ergo and about 3 inches of the bars. This long flat horizontal space is key. You need space to place your hands on the Ergo levers and the bars right behind it. I would recommend finding bars that have a long flat horizontal space right behind where the Ergo/STI levers go. Look for bars that start their downward angle where you mount the levers. Not bars that start angling down back where the bars turn to the front.
PostPosted: Thu Jun 21, 2012 4:06 am
Deda Newton.
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Thu Jun 21, 2012 4:28 am
I have Deda Zero 100 and FSA K Force compact and wing pro compact. All give me the ability to have a flat section just behind the shifters which is comfortable for my hands. That's what I like. I've also come to like the slightly flat tops.
PostPosted: Thu Jun 21, 2012 5:02 am
take a look at the Zipp Contour SL short and shallow. Most likely all short and shallow zipp bars will do but I have those. You have a nice flat transition to the hoods and the levers are still a very easy reach from the drops. You can see a picture of it in the thread in my sig.
My Lynskey R420 with Chorus 11
NEW Developments! If you are interested in a Weight Weenies kit please respond to the thread. I want to make the order happen before long.
PostPosted: Thu Jun 21, 2012 3:37 pm
Pro Vibe 7S, prefer the round bend version. Deda Newtons mentioned above also good. Lastly, I have a set of Ritchey Evolutions that have worked well for 3 years.
PostPosted: Thu Jun 21, 2012 5:54 pm
Really liking my Easton EC90-slx3 carbon bars with my C11 shifters. 125 drop, 75 reach, nice flats. Spend a lot more time comfortably in the drops now, both straight down near the ends of the drops and also reaaching deep into the drops. Have a nice climbing position on the bars themselves, can ride on the flats before the hoods, deep onto the hoods, , hands wrapped around the hoods w/forearms on the flats -- what's not to like? :thumbup:
Oh, and I have relatively large hands and go 183cm so short/shallow bars are not just for small riders.
PostPosted: Fri Jun 22, 2012 9:47 pm
Easton SLX3
PostPosted: Sat Jun 23, 2012 12:01 am
3T ergonova
PostPosted: Thu Jun 28, 2012 4:47 pm
The Deda RHM shape (Presa, 35, Zero100 a.o.) works fine for me.
Bianchi-Campagnolo
PostPosted: Tue Jul 17, 2012 4:37 pm
deda presa
PostPosted: Tue Jul 17, 2012 4:41 pm
3T Ergonova. IME it runs them really well and is my favorite bar for them.
PostPosted: Tue Jul 17, 2012 5:46 pm
another vote for deda, I have SR 11 on alanera with the RHM and it works great... I also use em on a set of FSA plasma's but the reach to the thumb shifter while in the drops is a touch trickier.
Users browsing this forum: Bing [Bot], carbon337 and 53 guests
There are no new unread posts for this topic. Does my 10s Campy ergo lever need a rebuild?
JBV
7
576
Thu Jan 03, 2013 5:28 pm
There are no new unread posts for this topic. Rattly Campy Shifters
abefroman
Fri Aug 24, 2012 2:02 am
boolinwall View the latest post
There are no new unread posts for this topic. Attachment(s) pro vibe traditional bend, with campy 11sp shifters
digitalnorbs
10
1376
Wed Jul 04, 2012 3:28 am
digitalnorbs View the latest post
There are no new unread posts for this topic. Sidi Ergo 3 Vented Sole
tohd1978
7
931
Sat Jul 14, 2012 3:37 pm
sugarkane View the latest post
There are no new unread posts for this topic. What's on his handlebars?
dvincere
Fri Apr 26, 2013 11:43 pm
dvincere View the latest post
It is currently Sat May 25, 2013 10:26 pm
