Post new topic Reply to topic  [ 3 posts ]
 Post subject: Wired SRM Tarmac SL4
PostPosted: Wed Jun 20, 2012 4:23 pm
Anybody have any experience with a wired cannondale SRM install on an SL4 SWorks Tarmac? I'm thinking about picking one up and was curious as to whether there was anything special I needed spindle-wise for the install.
 Post subject: Re: Wired SRM Tarmac SL4
PostPosted: Wed Jun 20, 2012 4:55 pm
I'm currently running a wireless Hollowgram SRM on my SL4, and you'll need the special SRM spindle, which is a tad longer to compensate for the SRM spider.
"black on black, is a crime"
PostPosted: Wed Jun 20, 2012 6:51 pm
You may need extra room on the drive side to fit the SRM electronics. There is a two stage solution to this problem. The SRM specific spindle moves the setup ~1mm to the right and the SRM specific dust shield moves the setup another ~1mm to the right. You can use either or both, depending on your frame's clearance needs.
If you already have a "normal" spindle and need just 1mm of space, get the dust shield as it's only $15. If you don't have a spindle yet, get the SRM version as buying the normal spindle and then discovering you need more room would be expensive.
Users browsing this forum: Bing [Bot], Google Adsense [Bot], HakeemT, upper90, Yahoo [Bot] and 46 guests
There are no new unread posts for this topic. Canondale evo vs Tarmac
steel515
13
2305
Thu Mar 07, 2013 4:29 pm
KWalker View the latest post
There are no new unread posts for this topic. What Size Sworks Tarmac SL4
CharlieCrit
Thu Mar 14, 2013 4:33 pm
sawyer View the latest post
There are no new unread posts for this topic. Attachment(s) Specialized Tarmac Elite SL2 C2
av520
Sun Aug 19, 2012 6:22 pm
av520 View the latest post
There are no new unread posts for this topic. Decide my new bike. Tarmac?
seve88
Fri Jan 11, 2013 9:22 pm
js View the latest post
There are no new unread posts for this topic. Next step up from S-Works Tarmac?
qeaou
Sun Oct 28, 2012 12:53 pm
Spindoctor View the latest post
It is currently Thu Jun 20, 2013 6:38 am
