It is currently Wed Jan 17, 2018 9:21 pm
Post new topic  Reply to topic  [ 14 posts ]
 Post subject: flexy bars
PostPosted: Tue Jun 19, 2012 8:33 pm
Hi.I put fsa k-light nano carbon bars on my Bianchi infinito and found when descending ventoux recently,with a very windy decent,coupled with xentis squad4.2s , that the wobble or oscillation that kept happening was very scary.the combination in normal conditions,eg no wind,was great.
The question is this.i know the wheels are far from perfect for the purpose but the bars seem very flexy, does anyone have any experience of the bars and if so, how do you find them?
Cheers.
 Post subject: Speed Wobble
PostPosted: Tue Jun 19, 2012 9:04 pm
Are you sure it was the bars? In other words, do you have a lot of experience at speed in gusty winds with the exact same setup EXCEPT that bars were different and never had a speed wobble issue? I ask because speed wobble issues are notoriously difficult to diagnose, because the bike/rider unit gets into a harmonic state where the wobble "builds" on itself, increasing in severity, as opposed to when the bike wobbles for a moment (perhaps even imperceptibly) and then recovers and acts normally. You may have "felt" the wobble in your bars (because it was the bars that were violently shaking your hands), but even bars that are "flexy" don't necessarily mean you will get a speed wobble riding them (though you certainly may) - it really could be anything from your wheels, frame, fork, headset, bars, and in many cases, riding position.
Here is a video of my last speed wobble - was only at 33 MPH but still not a lot of fun: https://vimeo.com/42816611. (wobble starts at about :40)
EVO Hi-Mod | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 3/5
P5 | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 7
T1 | Power2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
SuperX Hi-Mod Disc | Sram Red | Power2Max NG
 Post subject: Re: flexy bars
PostPosted: Tue Jun 19, 2012 9:17 pm
hi.your wobble looks very much the same.i take your various points but i did the same decent in non windy conditions and the bike descended like a dream. I'm hoping that changing the bars will do the trick as it's the cheapest option.taking one bit of flex out the equation might work???!!!!
PostPosted: Tue Jun 19, 2012 10:24 pm
also the wobble was very evident at very low speed in very high cross winds at the top.so it's not just a speed thing although the wobble at 45 mph was quite horrific!!!!!
PostPosted: Wed Jun 20, 2012 3:53 am
speed wobbles or "shimmy" is a harmonics situation, as you seem to be aware of. with that, changing almost anything in the bike/rider/road system to one that is noticeably different (size, stiffness, position, etc) will likely move the speed wobble. keep in mind that you could make things worse, or merely change the speed/conditions of its happening.
if youve never had this happen until you installed this bar, i'd change the bar as it seems the most sure-fire way of getting rid of the problem. but as i mentioned, you could go with a FLEXIER bar and it may also improve. you could also just try lowering the stem on your steerer with your current setup..
PostPosted: Wed Jun 20, 2012 4:05 am
Speed wobble at 45MPH? That's really scary stuff. Glad to know you are OK - that could have ended badly.
No reason not to swap out the bars and see if that helps. If not, you will want to systematically change one variable at a time on your bike until it goes away and you regain confidence on your bike.
PostPosted: Wed Jun 20, 2012 4:11 am
Small chance changing bars will help. Changing wheels (sorry) is a better bet. Some frames in some sizes with certain setups can be a problem.
wheelsONfire wrote:
When we ride disc brakes the whole deal of braking is just like a leaving a fart. It happens and then it's over. Nothing planned and nothing to get nervous for.
PostPosted: Wed Jun 20, 2012 4:26 am
Put your knee up against your top tube.
Wobble stops.
PostPosted: Wed Jun 20, 2012 6:16 am
Anecdote without any value :lol:
Five years ago I saw a Cannondale in the peleton develop a wobble. I could swear I saw the whole frame ripple, which is quite frankly impossible, so the wobble must have oscilated quite badly to give that impression. As if he were Moses the peleton split around him, everyone dove for safety :lol:
PostPosted: Wed Jun 20, 2012 7:20 am
the whole bike is new so set up is as is.the bars are more flexi than i'd like so i'll change them and wait for it to happen again[or not] although i can't see me on a decent like ventoux to test it for a while unfortunately.
PostPosted: Wed Jun 20, 2012 8:25 am
Why don't you post a few pictures of your bike and the current set up for us to review.
PostPosted: Wed Jun 20, 2012 10:12 am
The piks are on the forum somewhere.
Sent from my GT-I9100 using Tapatalk 2
PostPosted: Wed Jun 20, 2012 10:16 am
If you look up...'infinito in Italian colours' ....
PostPosted: Wed Jun 20, 2012 8:16 pm
tbh if it's the only time it's happened, i'd guess it was due to the wind
i had something that sounds similar on a road i've ridden many times before/since, the only difference that day was a strong crosswind, which was really unusual for the area
it started after a slight change in road direction (so wind angle changed too) and though scary wasn't a fullblown wobble, just felt like the front wheel was being shaken side to side, the bike itself seemed stable and both knees hard on the top tube didn't stop the wobble which surprised me, i was going over 70kph and it only stopped after i slowed to about 40kph
in retrospect i think maybe it was the same phenomenon that can affect chimneys etc. where a vortex breaks off alternate sides and drives an oscillation, but here it was the wheel doing it (deep rim)
There are no new unread posts for this topic. My 3t Bars Toast?
sethjs
7
1247
Mon Apr 10, 2017 6:07 am
sethjs View the latest post
There are no new unread posts for this topic. TT Bars on Madone 9
CanadianBiker
Mon Sep 11, 2017 2:50 pm
Fisherfreerider View the latest post
There are no new unread posts for this topic. Looking for clip on aero bars
DeLuz
Tue Jul 11, 2017 9:16 pm
jeanjacques View the latest post
There are no new unread posts for this topic. 3K bars with internal cabling
beanbiken
Fri Jun 30, 2017 6:52 am
beanbiken View the latest post
There are no new unread posts for this topic. Attachment(s) PRO Vibe Aero bars
Schulbub
37
7281
Wed Nov 15, 2017 4:27 am
TonyM View the latest post
Users browsing this forum: bfno, Google [Bot], vladi78 and 46 guests
