Post new topic Reply to topic  [ 6 posts ]
 Post subject: Campagnolo Chainrings
PostPosted: Tue Jun 19, 2012 3:19 am
Hi,
I currently have a Chorus 50/34 Compact. The crank is a chorus CT Ultra Torque crank. I was wondering what kind of chainrings I would need to make it a standard 53/39 crankset? Are there any compatibility issues with these chainrings?
Thanks for any help!
PostPosted: Tue Jun 19, 2012 5:23 am
It's probably easier to just swap out the crank and sell your compact. There's lots of demand for compacts so it should move fairly easily. I checked a couple of on line sites and didn't see 53 or 39 toth rings for Campy compact. Check your derailleur too. If it's a special compact one, it might not work very well with the regular rings.
PostPosted: Tue Jun 19, 2012 7:47 am
I think TA-specialties, Stronglight or Miche will have chainrings, which ones fit may vary with the year of manufacture of your cranks.
Some options, depending on your cranks. I have only used TA-Specialties on Shimano cranks but that worked fine. As C50jim said it may be a better choice to sell your compacts and buy a 53/39 if you aresure that is what you want.
http://www.bike24.com/1.php?content=8;n ... gc=122:435
http://www.starbike.com/p/Specialites-T ... CT-3671-en
http://www.starbike.com/p/Specialites-T ... CT-2996-en
PostPosted: Tue Jun 19, 2012 12:10 pm
Dont think it's possible to put 11 speed Campy rings in that configuration onto a compact.
PostPosted: Tue Jun 19, 2012 12:48 pm
I read somewhere that Campy will be offering semi compact 52/36 rings with a 110 BCD at some point. Miche already do so they might also fit, as mentioned above. They might flex a bit though.
PostPosted: Tue Jun 19, 2012 8:20 pm
Just buy some TA Specialites Nerius 11 chainrings:
http://www.specialites-ta.com/gb/plateau-nerius11.html
They have both a 39T inner and 53T outer in the compact 110mm bolt pattern. But you're probably going to also need these if you have a 2011/2012 Chorus crankset that has a threaded inner ring rather than separate chainring nuts:
http://www.specialites-ta.com/gb/visserie-utc3.html
Lots of good information about using aftermarket chainrings with the 2011/2012 threaded inner chainring in this thread (jump straight to page 3 for the conclusion):
viewtopic.php?f=3&t=96114
Users browsing this forum: airwise, Bing [Bot], ghisallo2003, Google [Bot], motch, thprice and 41 guests
There are no new unread posts for this topic. Carbon Ti chainrings
konky
Sun Nov 04, 2012 2:36 am
Gold Knight View the latest post
There are no new unread posts for this topic. Osymmetric chainrings
expan
Fri Apr 12, 2013 8:18 am
CarpetFibre View the latest post
There are no new unread posts for this topic. What chainrings / crank are these
jcumpstay
10
437
Fri Apr 05, 2013 3:28 pm
superb View the latest post
There are no new unread posts for this topic. Chainrings: Stronglight CT2 v TA
MileHighMark
Mon Apr 08, 2013 5:22 pm
MileHighMark View the latest post
There are no new unread posts for this topic. Has anyone tried doval chainrings?
Brandonnie
7
1560
Mon Jan 21, 2013 5:33 pm
Kasparz View the latest post
It is currently Wed Jun 19, 2013 9:34 am
