Post new topic Reply to topic  [ 10 posts ]
PostPosted: Mon Jun 18, 2012 4:48 pm
Is there any way to setup a Vittoria Corsa Evo CX tubie with removable valve cores?
They have that removable valve STEM that appear to have different threads at the base of the tubie than the regular presta threads. I added a Vittoria extension between the tubie and red valve stem prior to initial mounting.
I would like to change this setup so I can get some Stan's in the tire, but need removable cores. Because the threads at the base of the tubie are different I'm not seeing an obvious way to do this. If someone has done this, can you point me in the direction of the proper parts to purchase?
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
2011 Specialized Crux, Alloy
2009 Specialized Roubaix Pro SL SRAM Red
1980 Palo Alto custom build
PostPosted: Mon Jun 18, 2012 5:01 pm
Not sure if I am getting it,
but the red valve is removeable;
the presta part on top of the red valve is removeable;
So you can extend them or put on another (longer or shorter) valve.
Bianchi EV3, Master Olympic, Pinarello Asolo
PostPosted: Mon Jun 18, 2012 5:16 pm
The valve core on the red valve stem is not removable.
PostPosted: Mon Jun 18, 2012 5:50 pm
de zwarten - yes, that is the exact setup I have.
duke249 - exactly. That is the problem! :-(
PostPosted: Mon Jun 18, 2012 6:38 pm
Kinda crappy when you think about it. Everything in cycling is going to proprietary integration, including tubular tires! The only way to do it is to install the stans when the tire is off the rim, install the valve stem and then install the tire. For as nice as Vittorias are, the hassle of dealing with these valve stems is not worth it compared to a tire with a removable valve core and the silver Vittoria valve extenders.
PostPosted: Mon Jun 18, 2012 6:41 pm
a note on the silver Vittoria valve extenders: If you do use these, BE SURE to take the little black wrench in your saddle bag so when you get a flat and need to do a roadside change, you can remove the valve extender from the flat tire and install it on your spare. And also make sure your spare has a removable valve core.
PostPosted: Mon Jun 18, 2012 6:45 pm
I use these.
"Nothing compares to the simple pleasure of a bike ride"
Scale 30
Schenk 007
My blog
PostPosted: Mon Jun 18, 2012 7:18 pm
you can use the continental valve extenders with the removable core by just flipping them the other way
PostPosted: Mon Jun 18, 2012 9:08 pm
rainerhq wrote:
I use these.
That is the solution I am looking for. Thank you!
PostPosted: Mon Jun 18, 2012 10:22 pm
Tubbie Guru
Hi,
So Maxxis modular valve system is the same as Vittoria's then?
I take it the Maxxis extenders screw right onto the stub of the Vitto tub and also sport a removable core? Neat. 8)
Ciao, ;)
Users browsing this forum: climberevan, KWalker, Mario Jr., VMac and 48 guests
There are no new unread posts for this topic. Vittoria Open Corsa EVO Slick or Veloflex Corsa 22
btompkins0112
Fri Apr 19, 2013 6:08 am
markyboy View the latest post
There are no new unread posts for this topic. Difference between Vittoria Corsa CX III and Corsa Evo CX
mgordon
15
1891
Mon Apr 29, 2013 11:27 pm
fdegrove View the latest post
There are no new unread posts for this topic. Vittoria Corsa Evo SC opinions
wassertreter
Fri Jul 06, 2012 11:18 am
There are no new unread posts for this topic. Weight difference w/Vittoria Open Corsa CX 25 vs 23?
jz4nyc
7
552
Tue Dec 18, 2012 11:55 pm
jz4nyc View the latest post
There are no new unread posts for this topic. Michelin pro race 4 vs Vittoria Open Corsa SL
andyhunter
Mon Apr 08, 2013 10:03 pm
Irish View the latest post
It is currently Sat May 25, 2013 4:44 pm
Vittoria Open Corsa Evo CX 700x23C black
