Post new topic Reply to topic  [ 6 posts ]
PostPosted: Sat Jun 16, 2012 9:56 pm
Hi all,
Looking for a new stem with a 26mm bar clamp. Finding it quite difficult to track a light sensibly priced one down. Is the Deda Newton 26 or KCNC stems the best option? I'm a light rider. I'm in the UK
Thanks, Tim
PostPosted: Sat Jun 16, 2012 10:26 pm
Search for the Syntace F99 on German Ebay.
Lately they've been going for about €25. Brandnew.
PostPosted: Sat Jun 16, 2012 10:42 pm
The Cincelli Vai is about 160g and comes in 26.0mm calpm size. Only 110 and 120mm length in this clamp size though. Also quite cheap.
www.thecycleclinic.co.uk
PostPosted: Sat Jun 16, 2012 11:44 pm
The Syntace stems had a fault that saw them crack, do you know if those are OK?
Cheers, Tim
PostPosted: Sun Jun 17, 2012 2:35 am
IIRC, the Syntace issue was from ages ago and corrected. Unless you find an older stem on that auction website I would not be concerned.
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Tue Jun 19, 2012 7:01 am
Cheers, Tim
They had a recall on F99 stems several (at least 3) years ago. I bought a used stem on ebay around then, or maybe even 4 years ago. I looked at the recall info on their website, and saw my stem was affected (based on some identifying number - date?? on the stem). Anyway, I contacted them, and they replaced the stem immediately with no questions asked. Didn't ask if I was original owner or anything. All I had to do (based on their emailed instructions) was to cut the stem and email them a photo that showed the batch (or whatever) number and that it was cut.
There's been no problems with Syntace stems that I've read about since then. I'm very happy with mine for what it's worth. It's right around 100 grams for a 105mm stem with the standard bolts. I think you could lose another 5 or 10 grams with ti bolts (which I had and kept from the original stem!), but I happen to think the black ones look better (a travesty on ww I know!). They are a very large bang/buck ratio.
Users browsing this forum: adhumston, bumpkin, capnc, cesemo, Google Adsense [Bot], konky, Majestic-12 [Bot], timj and 60 guests
There are no new unread posts for this topic. Deda Vincente Carbon stem
tabmaster
10
697
Mon Jan 07, 2013 1:19 pm
tabmaster View the latest post
There are no new unread posts for this topic. Best way to go about custom colors on a Deda Zero 100 stem
savechief
Thu Jun 28, 2012 9:32 am
shinyboy View the latest post
There are no new unread posts for this topic. Attachment(s) spot the diff between these 2 deda 35mm stem
project3
13
1341
Sun Sep 30, 2012 8:32 pm
artray View the latest post
There are no new unread posts for this topic. Deda or 3T
fifarafa
11
1196
Tue Apr 30, 2013 12:39 am
project3 View the latest post
There are no new unread posts for this topic. Deda Ran - anyone seen one in the flesh yet?
fivethirtyonepm
Tue Oct 02, 2012 9:41 pm
borja View the latest post
It is currently Thu May 23, 2013 4:46 pm
