Post new topic Reply to topic  [ 15 posts ]
PostPosted: Sat Jun 16, 2012 9:58 am
hi all, i have a question i'm hoping you can help me on.
when i got my addict R1 frameset, it came with Ritchey WCS Logic Zero Press-Fit Headset (not assembled).
when i tried to install the press-fit onto the frame, it seemed too tight and wouldn't go in right.
so, not sure if i can use some fine sand paper to widen it so the press fit will go in? or should i try to press it in? (which i don't think should be the right answer in case it'll crack the carbon?)
any suggestions?
also, on my fork, shouldn't there be a crown race installed onto the fork? when i had my alum CF fork, there was one that was installed on.
PostPosted: Sat Jun 16, 2012 1:10 pm
can't help on the specifics of your frame/fork, but headsets and crown races can take a lot of force to fit/remove, if you do not have the correct tools it can be a struggle or risky to try it, you want to keep forces on-axis and evenly applied
unless someone else can give you a definitive answer, i'd contact scott direct and ask them if the frame or forks need any prep before fitting the headset
http://www.scott-sports.com/us/en/company/contact/form/
if the crown race is missing, it looks like you can get them separately, for instance...
http://www.google.com/search?q=RITCHEY% ... v&tbm=shop
PostPosted: Sat Jun 16, 2012 1:12 pm
not being familiar with this headset I looked at the Ritchey site. very disappointing level of information there is no help.
my gut feel is that if you should be able to push that in by hand, I too would not want to be hammering on it.
normally the fork would need a "crown race" but since I'm not familiar with the Ritchey design, maybe they do it differently - the tech docs are no help.
if no one here helps there's a Ritchey rep string over on the RBR site. try there. http://forums.roadbikereview.com/ritchey/ritchey-rep-here-answer-all-your-questions-210005.html
dangerous curves ahead
PostPosted: Sat Jun 16, 2012 1:46 pm
Don't modify the frames or the cups. It's best to use a headset / BB bearing press as cups need to go in square.
The fit is tight but they'll go in easily with the right tool. Your LBS will have one.
You should have got a crown race with the headset. Again easy to fit with the right tool.
PostPosted: Sat Jun 16, 2012 5:02 pm
yea i noticed scott's contact form wasn't much help. i had emailed them before and never got a response. :( but thanks for the RBR site.. i'll ask them and see if there's some answer.
thanks to all that responded. at this point, i think it's better for me to buy a complete set than to tool around with these parts. which headset would you recommend that would have all the parts included and very lightweight? :)
PostPosted: Sat Jun 16, 2012 6:19 pm
Compatible lighter headsets-
KCNC Radiant R2
KCNC Morion M2
Extralite Scalhead
Tune Bubu
BTW a Ritchey crown race is commonly available as a spare part.
PostPosted: Sat Jun 16, 2012 7:18 pm
Hi
I have had a scott addict sl with the same headset .
A tip is put the shells in the freezer for about a day . ( tip from a dutch forum )
You stil have to use some pressure but not as much .Normally its not possible to push them in by hand and you will have to use a special tool ?
Instead of that special tool you can also use a threaded rot with some big washers and nuts .Its cheaper than the tool and works just as fine .
And the crown race . I made a cut in them on one side and they went on easy . And i never had a problem with them .
PostPosted: Sun Jun 17, 2012 1:24 am
Thanks for the tip. Trisports didn't send me the crown race.. Boo!!!
Anyway I went to sports basement and bought a crown race and they installed it for me and the press fit onto the frame too. All I paid was $15.. Woohoo. Now the rest I can start putting on tonight after I cut my fork.
PostPosted: Sun Jun 17, 2012 2:33 am
I would not do it this way.
Press fit is the best way.
PostPosted: Sun Jun 17, 2012 7:29 am
Say goodbye to any hope of warranty help if you cut a slot in your crown race.
If you're keen on doing this stuff at home, it's worth your money to buy the correct tools. An Addict is no place for jury-rigging.
PostPosted: Sun Jun 17, 2012 9:12 am
yup so I got it done at the LBS instead of 2nd guessing myself. :lol:
PostPosted: Mon Jun 18, 2012 6:20 am
It's pretty easy to install a crown race. They should be a tight interference fit. You can gently sand your fork steerer so that the race falls easily to within about 10 or 12 mm and then drive/press it home from there.
All you need is a piece of PVC pipe (~40 or 50 mm diameter. I dont remember). The pipe just has to be a bit longer than the steerer.
Slip it over the steerer, tip it over and tap it on the floor to drive the race home.
r o y g b i v
PostPosted: Mon Jun 18, 2012 8:00 am
Administrator
I think you should know that the Tune headsets come with the slot already cut into the crown race.
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Tue Jun 19, 2012 12:07 am
i think that's what my LBS did too..
PostPosted: Tue Jun 19, 2012 12:56 am
You can press the crown race on with your headset if you have enough spacers. I've done this numerous times now on oversized tapered forks because my old 1 1/8th crown race tool 'pipe' no longer fits. It works (in my opinion) far, far better than hitting a pipe with a hammer to seat it. If you have enough headset spacers you can do it with an uncut fork, if you've already cut the fork, even easier :thumbup:
Users browsing this forum: Google [Bot], Google Adsense [Bot], kulcha, MSN [Bot], roselend and 34 guests
There are no new unread posts for this topic. Installing Press fit BB 30 ...Help?
photocycler
Sun Feb 10, 2013 7:07 am
photocycler View the latest post
There are no new unread posts for this topic. Cannondale Evo Headset and Fork question
apLe
Wed Jan 09, 2013 3:37 am
timzcat View the latest post
There are no new unread posts for this topic. Fitting the proper fork and headset to a frame
LouisN
Fri Feb 22, 2013 2:30 am
michel2 View the latest post
There are no new unread posts for this topic. Easton EC90 fork headset cap screw/spring/washers necessary?
timj
Thu Aug 16, 2012 9:16 am
timj View the latest post
There are no new unread posts for this topic. 2013 Colnago C59 headset question
Rich.H
Thu Oct 11, 2012 8:21 pm
paulandmonster View the latest post
It is currently Wed May 22, 2013 7:13 am
