Post new topic Reply to topic  [ 35 posts ]
Go to page Previous  1, 2, 3
PostPosted: Thu Sep 13, 2012 3:36 pm
drmutley wrote:
ECT wrote:
This is quite incorrect... The needle bearings are EASILY replaceable in less than a few minutes, and for less than a few dollars... Unless the pedal has done alot of miles, it's not the needle bearings that usually cause the grainy feel when swapping out spindles. Having said that, given it costs about $6 for a needle bearing, and 2 cartridge bearings, it's would be wise just to spend a few minutes and replace the lot when putting in new spindles...
where can you find these? All is see is the $24 full bearing replacement kit on ebay (which isn't a bad price)
PostPosted: Fri Sep 14, 2012 3:08 am
drmutley wrote:
ECT wrote:
kya wrote:
Sorry for digging up a month old thread, but I've just replaced my spindles and got similar issues as someone else earlier in the thread.
I picked up a set of Ward Ti spindles and the left pedal/spindle works excellent. However, the right pedal is really quite tight and "gritty" with the Ti spindle installed. I've since switched it back and forth between the Ti and the stock cromo spindle several times, and the issue always goes away with the stock spindles. I've tried regreasing and I have a new set of bearings on the way, but I don't really expect the bearings to fix anything considering there's no issue with the stock spindles.
I've sent Ward an email, but haven't gotten a response yet. Any one have any ideas on what the issue might be/how to fix?
As I posted earlier, if you have many miles on the pedals it would be a good idea to replace the plastic body's, which house the non-replaceable needle bearings. When I replaced my Stainless spindles for Ti, I noticed notching in the stock spindles, and it became apparent that the needle bearings had seized. The replaceable cartridge bearings were fine, even after 20,000 miles.
kya wrote:
motorthings wrote:
i had the same experience, but got the new bearings, and it fixed the grainy feeling. i needed to replace the o-ring too on the same side, since the old one was stretchy and let too much grease out.
I never did receive a response from Ward, but I just tried the new bearings and it did indeed fix the issue. That makes absolutely no sense to me since the original bearings worked fine when I switched back to the stock spindles, but hey if it works, it works. Thanks for the tip on the bearings.
Just spend 3$ and replace the cartridge bearings... Will fix the problem (as u have seen)... Even with new pedals some of the cartridge bearings will be "mated" to the original spindle, resulting in a grainy feel when put in the ti spindle... Tolerances are precise hence why swapping spindles can result in the grainy feeling .....
I meant to say by the time you need to replace the needle bearings, the pedal body's themselves would probably need replacing, and would come pre-installed in a new set.
PostPosted: Fri Sep 14, 2012 3:13 am
odin99 wrote:
It wouldn't be hard to find that exact size bearing at a store specializing in bearings, or so I have heard from other people who have replaced them. I just used the stock Speedplay version, the mechanic who helped me replace mine threw them in for free. :D
PostPosted: Sat Sep 15, 2012 9:16 pm
Has anyone replaced the bowtie insert on a light action model? I want to make this upgrade; however, I am not sure if I need the zero or x model for light action. Any help would be great. Thanks
 Post subject: Speedplay Ti upgrades
PostPosted: Sun Sep 16, 2012 3:58 pm
I would think the zero BT is what u would be after...
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: Bing [Bot], Exabot [Bot], martroy, Omiar and 55 guests
There are no new unread posts for this topic. Jockey wheel upgrades
Guyeclipse
14
1394
Tue Aug 07, 2012 9:59 pm
Stockie View the latest post
There are no new unread posts for this topic. How much time can we save? Post all your silly aero upgrades
[ Go to page: 1, 2, 3, 4 ]
SWijland
58
4118
Wed Jul 11, 2012 4:44 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Look Keo vs Speedplay
thencameyou
21
1238
Thu Feb 07, 2013 12:44 am
shimmeD View the latest post
There are no new unread posts for this topic. Speedplay X1 and X2 pedals
tantra
Sun Sep 30, 2012 9:51 pm
ECT View the latest post
There are no new unread posts for this topic. Speedplay... play?
Valy
18
1190
Mon Sep 24, 2012 5:37 pm
Rick View the latest post
It is currently Wed Jun 19, 2013 1:33 pm
