It is currently Sat Sep 23, 2017 2:11 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Wed Jun 13, 2012 5:43 pm
1) buy RS80 wheelset
2) remove rear wheel hub and spokes
3) replace with powertap hub 20H and CX-rays.
4) == powertap wheelset with some nice rims.
Yeah I know it is only 20H, but will I be able to get as high tension as the original Shimano rear wheel to make it a durable set?
PostPosted: Wed Jun 13, 2012 6:16 pm
Seems like a lot of work. Are you trying to get a bargain ? Check Neuvation.com for good deals of powertap wheels.
PostPosted: Wed Jun 13, 2012 6:19 pm
And or just pick a rim and spokes and have your shop build it...
why buy a wheel and toss a hub...
charles@pezcyclingnews.com
PostPosted: Wed Jun 13, 2012 6:34 pm
Regardless of the tension, that is going to be a really soft wheel. Even in higher spoke counts Powertaps still build up soft (due to the flange spacing). I would say go 28 hole if your going to go through with this.
http://www.zencyclery.com
PostPosted: Wed Jun 13, 2012 6:40 pm
I am looking to use the new G3 hub which has a wider spacing, but not as wide original Shimano hub because of the J spokes.
PostPosted: Wed Jun 13, 2012 7:14 pm
Cheap powertaps at chainreactioncycles, sold out now but only 385 euro for a 20h Campagnolo Elite+ hub including joule computer is a killer deal of course.
PostPosted: Wed Jun 13, 2012 7:45 pm
Done that and its a great wheelset. I went for DA c50 wheels, in hindsight RS80 would have been more cost effective and virtually same weight, as a lot of the saving v's RS80 is in the rear hub. I deliberately went for dt comp spokes and it is plenty stiff enough (I'm 75kg). I went for the 2012 Pro Hub as the G3 does not support the yellow head unit.
All the Powertap deals at CRC have gone :(
I also have a RS80 c24 powertap pro+ wheelset, I think that has sapim cx-ray one side and it's fine.
I'm now planning a Stans Alpha + 2012 pro hub 20/24 hole wheelset. Should be sub 1,500g.
PostPosted: Wed Jun 13, 2012 7:47 pm
+ you will get >£50 for the ultegra hub or >£100 for the DA hub if you sell. My DA work of art hub is safe in a draw busy appreciating.
PostPosted: Wed Jun 13, 2012 7:54 pm
Why not just buy the RS80 rim? Ask you LBS to order you a spare rim (part number E-WHRIM2ARECC). If you want matching nipples, ask for Y-012 Z4076 (20x) for the red ones.
PostPosted: Wed Jun 13, 2012 8:02 pm
Just got some RS80 C24s from CRC at a deal, really choice wheelset......have the black nipples too (2012 model).
I think it is a great idea with the G3 hub.....keep us posted! :beerchug: :thumbup:
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Thu Jun 14, 2012 10:29 pm
After findng the right sources Looks like the final cost of the RS80 wheelset is $1600, the G3 and CX Ray.
but remember the G3 is $1299 MSRP..
Building a set of Zipp 101 would be $1850.
Another perspective a prebuilt QBP/Handspun Zipp 101 rear wheel only with G3 is around $1360
Both cases wheelbuilder.com doing the work for the rear wheel and the front wheel is a factory issed.
Wheelbuilder said they have experience building them before..
There are no new unread posts for this topic. Shimano cassette body for Mavic R-SYS SLR 2015 wheel
Tillquist
Tue Jun 27, 2017 6:26 am
Tillquist View the latest post
There are no new unread posts for this topic. Investing in BB30 PM a bad idea?
AW84
33
2381
Mon Aug 21, 2017 9:31 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Powertap Issues
greerso2004
Sun Jan 22, 2017 3:22 pm
greerso2004 View the latest post
There are no new unread posts for this topic. Powertap G3 lock nut
robsbc
Thu May 25, 2017 3:16 pm
fio View the latest post
There are no new unread posts for this topic. Powertap P1 Pedals
mattCSUK
Fri Feb 24, 2017 5:41 pm
Butcher View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], raggi, stang1 and 30 guests
