It is currently Wed Jan 17, 2018 12:27 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Wed Jun 13, 2012 5:08 pm
Hi everyone,
I've sent an e-mail to Pinarello but thought I'd ask here too. Does anyone know what inert gas was used whilst welding the Pinarello Dogmas from 2003? The magnesium/carbon ones. We've tried using Argon but the weld isn't great, our next option is Helium.
thanks
Xavier
PostPosted: Wed Jun 13, 2012 7:08 pm
I've welded magnesium before and used Argon with no issues.
Are you using a TIG. Are you cleaning it properly? What welding experience do you have?
PostPosted: Wed Jun 13, 2012 8:08 pm
It's not me, it's one of the engineers in our chemical engineering department (university)
Our next step is to use a pure magnesium rod I think
Xavier
PostPosted: Wed Jun 13, 2012 8:26 pm
If you're using rods then I think you're trying to stick weld. I don't stick weld but I think usually they embed gas within the rods.
I've only TIG welded magnesium. I don't see why you would attempt to weld anything like a bike frame with any other method.
MIG would be too messy and uncontrolled. Stick would be even messier.
PostPosted: Wed Jun 13, 2012 11:59 pm
TIG weld is a must. Are you trying to fix the frame?
PostPosted: Thu Jun 14, 2012 4:00 am
rod = filler
PostPosted: Thu Jun 14, 2012 7:18 am
Thanks everyone. It is a TIG weld yes, just for some reason was cracking around the edge of the weld. The frame was cracked on the chainstay near the BB. It only cost me £85 for the frameset so we're trying anything!
Xav
PostPosted: Thu Jun 14, 2012 7:54 am
I would make sure to clean the area thoroughly. Make sure any paint is gone.
Try fixing it with the torch only at first. Don't introduce filler metals yet. If you don't know the makeup or have the correct filler metal then you may just be compromising the weld.
I don't remember magnesium as being a hard metal to weld. I found it easy like stainless and def not as complicated as aluminum.
If you are cracking metal it may be too much heat. What you can do is equalize the temperature of the surrounding area with the torch before trying to fix your crack. In a sense you are warming the area prior to welding.
Also make sure you are blowing gas after you have stopped welding.
PostPosted: Thu Jun 14, 2012 1:40 pm
Thanks very much Podunk 8) fingers crossed it'll work!
Xav
PostPosted: Fri Jun 15, 2012 2:04 am
It may also be necessary to use a diffuser/shield to provide argon flushing to the area being repaired. As mentioned by podunk, try to fuse without fill rod first and be sure that your tungsten is cleaned and sharpened. if you are welding up to the BB, be sure that the paint is removed inside first. I remember a (real :oops: ) welder telling me that with magnesium it is very important that the metal be cleaned and welded immediately so as to avoid impurities in the weld.
Monkeyburger
...finding my inner Onoda-kun...
PostPosted: Fri Jun 15, 2012 3:00 am
I have never welded magnesium before but have found that back purging the weld is critical for best results with ti and stainless. Keep an extinguisher handy, MG is very reactive.
*edit*
Check THIS out. Looks like you need to use AC and 50/50 argon/helium mix.
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
There are no new unread posts for this topic. Attachment(s) Pinarello Dogma F8 Size 47 - Help!!!
TwinSpokes21
26
4521
Thu Jul 20, 2017 9:07 am
PinaF8 View the latest post
There are no new unread posts for this topic. Pinarello dogma upgrade ,
SNUGSHIP
10
1597
Mon Apr 24, 2017 4:52 pm
audiojan View the latest post
There are no new unread posts for this topic. Attachment(s) Pinarello DOGMA F8 + HED Stinger 4 clearance issues
xmashx
11
1462
Wed Mar 22, 2017 2:57 pm
xmashx View the latest post
There are no new unread posts for this topic. Pinarello Dogma F10 Disc - 820gr possible? Real world numbers or BS?
alcatraz
Sat Sep 02, 2017 5:44 am
maxxevv View the latest post
There are no new unread posts for this topic. Shamal C17 in Dogma 60.1
Daniel1975
Mon Mar 13, 2017 7:17 pm
Daniel1975 View the latest post
Users browsing this forum: Bing [Bot], Ettore, Greatestalltime, wingguy and 44 guests
cron
