Post new topic Reply to topic  [ 4 posts ]
PostPosted: Wed Jun 13, 2012 1:14 pm
Are the DA7900 rear hub measurements the same as the Ultegra 6700? My spoke calculator only knows about the DA. Thanks.
Bikes: Raceur, Beateur
PostPosted: Wed Jun 13, 2012 5:14 pm
Dura ace hubs are significantly different from Ultegra and other levels. 6700 should be the same as 6600.
"http://www.shimano.com/publish/content/global_cycle/en/us/index/tech_support/tech_tips.download.-Par50rparsys-0034-downloadFile.html/07)%20Hub%20Specs.pdf"
PostPosted: Thu Jun 14, 2012 12:47 pm
I built my training wheels up with a 6700 rear hub and came up with these measurements -
Centre to NDS Flange - 34mm
Centre to DS Flange - 17mm
Spoke hole circle - 47mm (outer to outer, centre to centre would be 45mm)
Spoke hole diameter - 2.3mm
Weight - 354g
Hope that helps.
Alex
EDIT - Interesting that it's different. I'm wondering if I measured in a different way to Shimano as I measured centre to the near side of the flange. If you add the 3mm for flange width you get a similar result to the Shimano tech doc for 6600.
PostPosted: Tue Jun 19, 2012 5:20 pm
Ok thanks everyone. I found another place that had the FH-6700 same as the 6600 from the tech docs, so I went with that. Fingers crossed ...
Users browsing this forum: darnellrm, giant man, Google Adsense [Bot], Heritrix [Crawler], Kermithimself, rijndael, theremery and 61 guests
This topic is locked, you cannot edit posts or make further replies. Dura Ace Di2 from Ultegra Di2
DamoRider
Sun Jan 27, 2013 8:36 pm
DamoRider View the latest post
There are no new unread posts for this topic. Second hand Dura Ace Di2 v Ultegra Di2
Roark
11
1507
Mon Jul 09, 2012 8:37 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Dura Ace 7900 vs. Ultegra 6700c Carbon?
ScottGoBlue
Thu Nov 22, 2012 4:46 pm
maxxevv View the latest post
There are no new unread posts for this topic. Shimano Ultegra SL front and rear derailleur bolts size
cryfish0816
Mon Jun 11, 2012 10:27 am
cryfish0816 View the latest post
There are no new unread posts for this topic. 7900 dura ace rear mech
mec287
Fri Jan 18, 2013 3:03 pm
eric View the latest post
It is currently Mon May 20, 2013 12:55 pm
