Post new topic Reply to topic  [ 8 posts ]
PostPosted: Wed Jun 13, 2012 7:30 am
Been dialing in my new Madone ('12 6.9SSL) since I built it up a couple weeks ago. It's almost perfect but the rear shifting was just a little off. Nothing major, just some extra noise and the shifting wasn't as crisp/consistent as it should be. So, I checked and rechecked the cable tension, housing lengths (have gone up/down with bar height a bit), limit screw and "b" screw adjustments, wheel true, etc. and the setup is spot-on.
Hadn't checked the derailleur hanger alignment b/c the shifting was alright and I'd spaced on it, so checked the hanger bolts then threw the ol' alignment tool on there and found the hanger was waaay off. I've aligned hangers for years and broken a few (like all mechanics), and through trial and error have developed a decent sense for how much force you can/should apply. I'm especially careful with aluminum hangers on carbon frames as they can only be straightened a tiny amount before weakening and snapping. Anyhow, I figured the Madone hanger was a brittle aluminum number and tho' I didn't have a spare on hand, threw caution to the wind and for the hell of it did a very tiny (think 2-3 NM) torqueing with my tool - not enough to do much, if anything, to most hangers I've had. Surprisingly, the hanger came all the way into perfect true with this one small action. I checked it several times at 12-3-6-9 and it's perfect. The shifting seems flawless now, as well, at least on the stand (will ride it on the road tomorrow).
The hanger appears to be painted or clear-coated and, while I assume it's aluminum, I recall recent discussion about Trek experimenting with steel hangers on Madones for ease of alignment. Lots of flame-throwing on the boards about how that'd result in broken frames, defeats the purpose of a hanger, etc. However, I'm very curious to know what this hanger is made out of. Feels like steel. Maybe it's a softer aluminum compound that is designed to break but is soft enough to be adjustable? All I can say is it's way softer than the hard aluminum hangers I've had on my last 4 or 5 race bikes (e.g., Super6 hangers that'd snap if you looked too hard at them).
Cheers!
PostPosted: Wed Jun 13, 2012 10:30 am
Stick a magnet near it. If it's steel it'll stick. If it's aluminum it won't.
PostPosted: Wed Jun 13, 2012 10:36 am
I'm pretty sure the hanger is aluminum, I have the same frame and I watched my mechanic adjust it easily. The steel hangers were only given to pro teams to give crisper shifting, I believe.
PostPosted: Wed Jun 13, 2012 10:41 am
Dont forget Titanium and stainless steel are non magnetic but a S/S hanger never !
Barrie
PostPosted: Wed Jun 13, 2012 11:03 am
take it off, weight it, then measure the weight of water it displaces from a glass. Calculate density and voila. ;) A bit easier solution is to ask Trek. :)
PostPosted: Wed Jun 13, 2012 1:11 pm
Or, just take it off and feel it...
PostPosted: Wed Jun 13, 2012 3:57 pm
Duh, Magnet, great idea (prefer not to take hangers on/off once aligned as tiny bolts are easy to start rounding even when careful). Did it, no stick. So, aluminum as we all suspected. Still, darn thing is quite malleable, at least relative to most alu hangers. Anyone know if Trek designed this in as a compromise between normal alu and steel? Thanks, all.
PostPosted: Thu Jun 14, 2012 6:01 pm
The Steel hangers were a team-only part Trek fabricated for the pros, who could care less about trashing frames. I don't believe any bikes were sold publicly with those bits.
Users browsing this forum: andyman, ferrarista, Google [Bot], Google Adsense [Bot], HammerTime2, jmilliron, Valy and 62 guests
There are no new unread posts for this topic. 2012 Trek Madone 3.1 vs 2013 Trek Madone 4.7
dew4rd
11
2741
Thu Dec 20, 2012 2:23 am
NGMN View the latest post
There are no new unread posts for this topic. Where to find derailleur hanger for generic bikes
PoorCyclist
Thu Mar 21, 2013 12:09 am
kode54 View the latest post
There are no new unread posts for this topic. Attachment(s) Front derailleur hanger specific to frame?
Rideuphill
Thu Dec 13, 2012 5:30 pm
Rideuphill View the latest post
There are no new unread posts for this topic. Attachment(s) Trek Madone
frisbie17
Sun Sep 30, 2012 9:28 pm
GT56 View the latest post
There are no new unread posts for this topic. Trek madone 6.2
CeCa
Mon Apr 15, 2013 3:40 pm
FIJIGabe View the latest post
It is currently Wed Jun 19, 2013 11:26 pm
