Post new topic Reply to topic  [ 15 posts ]
PostPosted: Wed Jun 13, 2012 5:22 am
Does anyone know how much weight can be saved by cutting the seat post? I'm interested in g/mm or g/cm. This could easily be determined by knowing the difference in weight between a 27.2 x 280 vs a 27.2 350 3t dorico team seatpost. Unfortunately, I can't seem to get weights online anywhere including the 3T website and weight weenies and I'm trying to determine if the risk of not being able to raise my saddle higher is worth the return. Thanks.
2011 Cervélo RS - SRAM Red
PostPosted: Wed Jun 13, 2012 7:17 am
Take your seatpost apart.
Weigh the carbon shaft.
Measure the carbon shaft.
Measure the distance you plan on cutting off.
Calculate potential weight savings.
Decide.
Exp001
PostPosted: Wed Jun 13, 2012 7:50 am
No point in carrying the extra weight... Chop it!!! :beerchug:
Then tell WW how much you saved!!
Follow me on twitter:- MrAliBongo
PostPosted: Wed Jun 13, 2012 10:35 am
I cut 4" of a carbon seat post ( I cant remember the make ) but it weighed 35g
Barrie
PostPosted: Wed Jun 13, 2012 1:33 pm
Cut it off. Weigh it. Then you'll know how much you saved :wink:
r o y g b i v
PostPosted: Wed Jun 13, 2012 1:47 pm
the only way to know for sure is to cut it and weigh it after. Grams/cm may vary along the length - my Syntace P6 post had a thinner wall at the very bottom end compared to the rest of the post.
I saved 39 grams by cutting around 9 cm from my post.
PostPosted: Wed Jun 13, 2012 2:53 pm
Just make sure you leave enough length so that it goes far enough into the seat tube to end at or below the lower junction with the top tube. If you want to save the maximum amount of weight you can cut it diagonally so that it is longer at the front when inserted.
Leave a centimeter of leeway to allow for possible height adjustment.
PostPosted: Thu Jun 14, 2012 12:20 am
Thanks for all of the good thoughts guys. I appreciate all of the responses. I'm also considering switching to the Doric since it doesn't seems as though I need a setback post (note that the saddle is all the way back for proper knee/spindle alignment):
So I'm also not terribly eagerto cut it without knowing all of the facts.
Decide.
It's not that easy with a Dorico Team. The head weighs much more than the shaft. The only true way to accurately calculate g/cm would be to know the difference in weight between the 350 and the 280.
I know for certainty, as a result of this (http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=69718), that the 350 weighs 235.8 grams. Does anyone know the weight of the 280?
I'm guessing about 35-50 grams of savings but I'm kind of obsessed with calculating it for some reason… OCD??
PostPosted: Thu Jun 14, 2012 1:49 am
Yes, it appears you need a zero setback post.....and possibly a bigger frame :noidea:
PostPosted: Thu Jun 14, 2012 2:13 am
I can see how you'd possibly conclude that. But I have really long legs and a short torso. The fit is perfect. With a 61 my ass slides off the nose. I have 64cm of reach. Impossible to achieve with a 61cm frame.
PostPosted: Thu Jun 14, 2012 2:19 am
Yeah, that's why I put the "no idea" icon.......either wrong frame or outlier body dimensions. Guess its the latter!! Good looking bike, btw!
PostPosted: Thu Jun 14, 2012 2:47 am
No worries. I didn't take any offense. And thanks! :)
PostPosted: Thu Jun 14, 2012 1:29 pm
If you really wanted to go to the trouble you could use a displacement measurement.
Measure the water volume displaced by the whole thing with the clamp and metal bits removed.
Then measure the water volume displaced by the shaft alone for the length you propose to remove.
The ratio of volume to volume will be the same as weight to weight.
r o y g b i v
PostPosted: Thu Jun 14, 2012 7:15 pm
If someone saddle is tipped that far forward from being level, it almost always means they need lower their saddle a few centimeters and level it out. Or secondly... you're riding the wrong saddle for your body type.
Anyway... with your saddle up that high, I probably would suggest not cutting much off. You want it to go quite far into the frame, otherwise you risk a broken post or even frame.
And you say you need a set-back post... yet it appears in the photo that your saddle is slammed almost all the way FORWARD! You mean a set-back post... to ride in reverse?
PostPosted: Thu Jun 14, 2012 8:48 pm
Thanks for the tips guys. I'll have to try the water displacement idea.
Regarding set-back/no set-back I see that I chose my words rather poorly. What I meant is that I may want to switch from a set-back (Dorico) to a zero set-back (Doric) hence my desire to not cut right now.
Thanks again!
Users browsing this forum: $mokeyJoe, Google [Bot], petepeterson, wassertreter and 55 guests
There are no new unread posts for this topic. Anybody has experience with "3T Dorico pro seatpost".?
loco2546
10
1796
Thu May 31, 2012 3:15 am
AC0 View the latest post
There are no new unread posts for this topic. 3T Ergonova Team Stealth & ARX Team + acetone
Anders
7
3269
Thu Mar 28, 2013 1:16 am
yongkun View the latest post
There are no new unread posts for this topic. Carbon seatpost flex (Seatpost sadlle mounting)
Burgunder
13
1715
Tue Oct 02, 2012 8:13 pm
Slowman View the latest post
There are no new unread posts for this topic. overtighened seatpost clamp. damaged seatpost.
odin99
9
696
Tue May 07, 2013 8:09 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. S5 Team or VWD
v70cat
43
2638
Sat Jul 21, 2012 12:56 am
jerade View the latest post
It is currently Thu May 23, 2013 6:59 pm
