Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Jun 12, 2012 11:31 am
I am having a slight problem with my Storck integrated headset.
I think I have the parts in correctly, but maybe not.
When I put enough pressure on the top cap to secure the fork, the headset is too tight and does not turn side to side freely.
Does anybody have a, expanded view of the headset and the way the pieces are supposed to fit?
I cant for the life of me figure out what the heck is going on.
HELP!
[img][IMG]http://i30.photobucket.com/albums/c308/topcarbon/sig_topcopy.png[/img]/img]
PostPosted: Tue Jun 12, 2012 1:02 pm
You might have missed a plastic washer or bushing such that the headset cap is touching the frame?
Cervelo R2.5
Cervelo P2c
Cervelo R3
Parlee Z3
Parlee TT
PostPosted: Tue Jun 12, 2012 1:07 pm
does the rubber gasket(o-ring) go above or below the cap?
PostPosted: Tue Jun 12, 2012 2:49 pm
As far as we know, and the way we install it, the orange seal goes between the frame/bearing and the top headset cap.....I have seen some people using it on the space between the fork and the lower bearings. Make sure the plastic shim that goes between the top bearing and the fork is installed and that the top cap has the inner part that rest against this shim. The outer section of the top cap must not touch the fraem/bearings, that's were the orange seal goes so you can rotate easily the fork.
www.royalbicycles.com
PostPosted: Tue Jun 12, 2012 6:01 pm
What headset is it? You should look at the headset's website for installation instructions and/or exploded diagrams. In my experience with 4-5 different frames, it's not the frame brand that is important, it's the headset brand.... but that said, they're all virtually the same with just minor differernces.
Or, just look at some diagrams for a few different manufacturers (i.e. FSA, Cane Creek) until you see one that makes sense for the parts you have or until you understand the general way the go together, in which case I think your particular headset will make sense.
Cartridge bearings, loose or caged? Same basic principles for both, just minor differences.
Maybe you could post a picture of everything you have? If you have already done that, I apologize, but I can't see it. I'll bet with a photo of all the parts you have, one of us can give you exact directions.
Also a couple of confusing things: the top cap is the coin-shaped thing above the stem with the bolt in it that tightens the headset. The cone spacer is the, cone shaped spacer that is just above the frame's head tube. Sometimes it's pretty short (~5mm), sometimes it's fairly tall (~20 mm). I get confused when people refer to that as the headset top cap, because it isn't. Like any other spacer, it simply transfers compression pressure from the top cap/stem down onto the headset bearings. The bottom of the cone spacer is usually designed to impart the pressure directly onto the top cartridge bearing, or onto the compression ring which inserts into the top bearing (cartridge or loose/caged balls).
If you have a rubber O ring, the ones that I've seen fit into a recess inside the cone spacer, causing a seal between the cone spacer and the fork's steer tube. Usually they don't come as a separate part, but are intalled in the cone spacer. So look there to see if yours is like that. There may be another location for it though, thus the need to find out what headset it is, and look at the exploded diagram... or post a photo of what you have.
The compression ring I referred to: There's sometimes, but not always a thin metal or plastic ring that slides over the steer tube, directly onto the top bearing, inserting into the top bearing inner bevel, or against the inner surface of loose or caged balls. It is usually called a compression ring, not a seal. But I really don't know what parts you or others are referring to - a photo of EVERY part you have (including the crown race!) would probably make this very simple.
There's usually nothing that sits between the lower bearing and the crown race or between it and the frame head tube's lower bearing seat. It just goes: crown race - lower bearing - lower head tube bearing seat, if that makes sense.
Good luck.
PostPosted: Wed Jun 13, 2012 12:16 am
There are a couple of different sizes of crown race for the Storck Acros headset. If your frame needs the "high" one and you have the "low" one, the fork will bottom out on the frame before the race contacts the bearing.
Users browsing this forum: Google Adsense [Bot], headwind816, Nismo4x4, rijndael and 49 guests
There are no new unread posts for this topic. How tight do you do up titanium skewers
verycreativeusername
9
1401
Tue Aug 07, 2012 3:35 am
wshiong View the latest post
There are no new unread posts for this topic. Elite Sior waaay to tight
WeightySteve
Fri Mar 22, 2013 11:31 pm
emike View the latest post
There are no new unread posts for this topic. tight clearance on fork blade...
chiltonp
Thu Aug 02, 2012 4:44 am
elviento View the latest post
There are no new unread posts for this topic. Attachment(s) Integrated Bars
RippedUp
16
1193
Tue May 29, 2012 10:13 pm
cerro View the latest post
There are no new unread posts for this topic. am i going to die? (chinese integrated bar/stem)
fivethirtyonepm
Sat Oct 20, 2012 11:38 am
artray View the latest post
It is currently Fri May 24, 2013 5:18 pm
