Post new topic Reply to topic  [ 14 posts ]
PostPosted: Mon Jun 11, 2012 12:17 pm
Hey guys,
I've got a new frame on the way and it would help get me out on the road quicker if I can buy the wiring harness ahead of delivery!
I'd guess it's a internal harness but could any owners out there confirm this for me?
Thanks :beerchug:
PostPosted: Mon Jun 11, 2012 1:21 pm
The BMC Di2 frames are all interal and it's very neatly done. Are you planning Ultegra or DA?
Blog: http://glorycycles.blogspot.com/" onclick="window.open(this.href);return false;
Flickr: http://www.flickr.com/photos/glorycycles/" onclick="window.open(this.href);return false;
PostPosted: Mon Jun 11, 2012 1:28 pm
Thank you for the reply cwdzoot!
It's Di2, I'm transferring it all over from my Giant TCR ISP so it's just the harness I'm missing!
PostPosted: Mon Jun 11, 2012 2:05 pm
I am not sure of the lengths - I don't have a 57cm in stock but see the battery mount here:
It's the short battery mount internal wire kit you need.
PostPosted: Mon Jun 11, 2012 3:24 pm
Thank you once again :thumbup:
Frames just arrived, pretty good looking, can't wait to have it built up.
Weights for those who may be interested:
Frame 57cm (no hardware): 972g
Fork 338g
Seat post +15mm 195g
Headset inc top spacer 67g
Seat post clamp 19g
PostPosted: Mon Jun 11, 2012 9:14 pm
Does anyone know a shop that has the above internal Di2 harness in stock in the UK? I'm struggling to find one, they all seem to be sold out...
Or in the states if I can get a quick delivery?
Thanks guys!!
PostPosted: Thu Jun 21, 2012 11:23 pm
After some mixup on the wiring harness I am pretty much done building my SLR01, it's stunning!!
I am not quite finished, the steerer is still to cut to exact length, I had a full internal wiring harness coming after a mix up and I'm replacing the bolts with Ti.
As seen with my 808's & SRM Power meter it's 6.95kg!
Love it so far :mrgreen:
PostPosted: Thu Jun 21, 2012 11:33 pm
Hi I'm thinking about the Advanced SL ISP DI2 frame, did you have one?bwhat can you tell about it?
Thanks.
I am here: http://tapatalk.com/map.php?uhwfzz
PostPosted: Fri Jun 22, 2012 12:49 am
Specifically I had a large 2010 TCR Advanced SL ISP. I believe they have redesigned the frame this year but they have kept the same geometry (specifically the 72.5 degreed SP angle) which was my issue with it.
It was a very stiff frame, especially the front end, I believe this contributed to it's good handling and it was especially noticeable descending going into a fast corner when braking with the front as hard as possible and peeling into the turn with a lot of weight on the front to really get some good grip. The lack of deflection was awesome, I don't know if my new BMC can get near that. It's lighter and just by doing a very simple totally non specific pinching of the dropouts together both front and back I don't think it's going to be in the same league stiffness wise.
But as nice as it was to have that stiffness it was a pretty harsh frame although I believe what Giant say about about the ISP helping reduce this.
The detailing on my Giant was much poorer than the BMC. Frankly I've been astounded so far by the build quality of the BMC. (that I'm actually able to see, can't comment on actual structure and layup of the frame because it's obviously hidden). So much so that I'm going to buy a TM01 once they come back in stock in the UK. I've had a lot of experience with high end composite parts and honestly a lot of bike components don't come close to belonging in this category but the BMC is the most nicely finished frame I've seen to date and I'm hoping that care extends to the structural build quality as well.
I would recommend the Giant if you race and you are sure the geometry suits you. It is geared towards a huge amount of layback and the frustratingly old school seat clamp on my 2010 didn't allow a whole lot of adjustment. So again, just check the geo! I would recommend it for it's handling and peddling efficiency.
HTH
PostPosted: Fri Jun 22, 2012 10:12 am
HTH
What you mean about the degree of the seat tube which is 72.5...? That's causing a layback position which is uncomfortable? Plus the fact that the frame is very stiff..?
I'm riding currently Cento Uno 2010 also ISP and I found the frame very comfortable and stiff enough. I thought of changing to Advanced SL with an Ultegra DI2 but I still have difficulty to let go of the Cento Uno.
I am here: http://tapatalk.com/map.php?xhlgom
PostPosted: Fri Jun 22, 2012 12:00 pm
Sorry for the confusion. The seat tube angle is a problem because I couldn't get the saddle far enough forward. Nothing to do with the frame being harsh. 72.5 degrees is pretty much the lowest seat tube angle I could find compared to any other manufacturers bike. My point being it is unusual.
HTH
PostPosted: Fri Jun 22, 2012 1:44 pm
Thanks
Btw do you know, or anyone knows how the sticker kit that Shimano has for mounting the DI2 wiring externally on regular frame called.
Thanks
I am here: http://tapatalk.com/map.php?5rwlk2
PostPosted: Fri Jun 22, 2012 2:01 pm
WasFab wrote:
Thanks
Thanks
I am here: http://tapatalk.com/map.php?5rwlk2" onclick="window.open(this.href);return false;
Here is a link to the external wire covers for Di2
http://www.cyclesport.com/road-bike/SHI ... IRE-GUIDES" onclick="window.open(this.href);return false;
Grtz
PostPosted: Sun Jun 24, 2012 1:50 am
Thanks
I am here: http://tapatalk.com/map.php?cxskrg
Users browsing this forum: Bing [Bot], BmanX, Google Adsense [Bot], tommasini and 67 guests
There are no new unread posts for this topic. Team machine slr01, Tcr Advanced og Venge
Elrey
Fri Jan 18, 2013 5:06 pm
Elrey View the latest post
There are no new unread posts for this topic. 2011 BMC Team Machine bottom bracket
wadetheking
19
743
Fri Apr 05, 2013 4:04 pm
5 8 5 View the latest post
There are no new unread posts for this topic. Removing Di2 internal wiring harness
nelson
14
633
Fri Dec 28, 2012 2:49 am
maxxevv View the latest post
There are no new unread posts for this topic. Shimano 9070 internal battery harness
Bely
Sun Apr 14, 2013 12:19 am
There are no new unread posts for this topic. 3T Ergonova Team Stealth & ARX Team + acetone
Anders
7
3263
Thu Mar 28, 2013 1:16 am
yongkun View the latest post
It is currently Wed May 22, 2013 5:22 am
