Post new topic Reply to topic  [ 14 posts ]
PostPosted: Sun Jun 10, 2012 5:35 pm
Ok, after reading tons and tons about the hollowgrams, I finally took the plunge and bought a set of SL's for the new Evo frame I got. Now I would like to get some advice from the experienced people here. What is the best set up I can do to make sure I don't have problems like creaks,etc ? Do I just follow the cannondale manual to the letter ? Do I put blue loctite on the spindle/bearing interface ( won't that give me trouble removing the crank when I need to) ? Really excited to start my build but want to make sure I get it right. Thanks in advance for any inputs.
PostPosted: Sun Jun 10, 2012 6:37 pm
Oh, one more thing. What loctite number is the blue loctite ? Thanks.
PostPosted: Sun Jun 10, 2012 6:57 pm
Loctite 242.
PostPosted: Sun Jun 10, 2012 7:28 pm
Follow mostly to the letter. I would do green (I believe it's 600 something) on bearings to frame interface and grease bearing to spindle
PostPosted: Sun Jun 10, 2012 8:26 pm
Do not put blue on spindle to bearing interface. As stated, lube the spindle and freeeze it before installing to make installation easier.
And if you have an Evo frame I will assume bearings are already installed so don't need to do anything there. The issues you have read of are for standard BB30 frames more then Pressfit 30.
PostPosted: Sun Jun 10, 2012 8:39 pm
Freeze it as in put it in the freezer ?
Thanks all for the inputs so far.
PostPosted: Sun Jun 10, 2012 10:07 pm
Yup. It shrinks it ever so slightly, makes it easy to to put into the bearings.
PostPosted: Sun Jun 10, 2012 10:21 pm
Ahhh cool. Thanks so much
PostPosted: Mon Jun 11, 2012 4:08 am
Loctite 242 is a thread locker. If you need to fix a loose press fit then you need the correct Loctite compound such as 642.
PostPosted: Mon Jun 11, 2012 4:47 am
loctite 609 is what is commonly recommended, and it's what cannondale suggests- for loose fits on pf30 cups or between the bearing and frame on standard bb30. i use it on the spider-to-arm spline shape as well. i actually prefer 603, but if it's green, and it starts with a "6", youre in the right area.
PostPosted: Mon Jun 11, 2012 10:19 pm
How do I check if the PF30 bb is slipping without riding it ? I pressed in the PF30 BB myself but I didn't put any loctite between the bearing to BB shell interface. Now I am wondering if I need to take them out again and put loctite 609 on and re-press.
thanks
PostPosted: Tue Jun 12, 2012 2:45 am
If they pressed nice and tight then you are fine. The loctite is for instances where the shell is poorly sized and the pressfit shell presses to easily.
PostPosted: Tue Jun 12, 2012 6:25 pm
I know that Cannondale recommends Loctite 609 tp bond in the BB30 threaded adapters as well as for its alloy SRM PF30 bb assembly, but will Loctite 609 or similar retaining fluids do much good with standard PF30 bb (SRAM, FSA) which use delrin plastic shells?
PostPosted: Wed Jun 13, 2012 4:29 am
yes, if a loctite primer is used. 603 technically doesnt require a primer, but i use it anyway
Users browsing this forum: Bing [Bot], deek, Google [Bot], Rippin, russianbear, VMac, zatarregaza and 59 guests
There are no new unread posts for this topic. New Hollowgram Spidering
quaman26
Sat Oct 13, 2012 7:26 pm
VNTech View the latest post
There are no new unread posts for this topic. Hollowgram vs. Exogram
timzcat
Sat Sep 01, 2012 8:54 am
logy View the latest post
There are no new unread posts for this topic. hollowgram srm hours
paulclay
20
1117
Thu Feb 14, 2013 9:54 am
Dammit View the latest post
There are no new unread posts for this topic. Hollowgram sl on super 6 evo
logy
Wed Dec 12, 2012 7:27 am
There are no new unread posts for this topic. Hollowgram on BB386 frame
Ainsy
Mon Jun 11, 2012 5:58 pm
ms6073 View the latest post
It is currently Wed May 22, 2013 3:41 pm
