Post new topic Reply to topic  [ 9 posts ]
PostPosted: Sat Jun 09, 2012 8:17 am
When I searched for some Nokon cables online, I saw that Nokon and a few retailers selling cable sets made specifically for shifting/derailleurs and sets made for brake systems. Then, I found other retailers who list them as one cable set for 'road brake or shifting'. Can someone shed some light on this? Aren't brake cables thicker than gear cables? :noidea:
PostPosted: Sat Jun 09, 2012 10:13 am
Yes, cables are différent, but Nokon is the same :wink:
I think the différence it's more for V Brake, for MTB
Nokon is a good gear only if you use the Powercordz liner:
Uploaded with ImageShack.us
Before, i use the Nokon liner, wich is black, it was a shit, then, with this Powercordz liner, no shift problem and it's verry fluid!
PostPosted: Sat Jun 09, 2012 1:11 pm
As far as I'm aware they used to have different offerings, but now they converged the two product lines.
Bikes: Raceur, Beateur
PostPosted: Sat Jun 09, 2012 3:01 pm
I use nokon outers and liners with kcnc cables ,superb shifting and braking. Take your time set it up right and it works without any issues.
PostPosted: Sat Jun 09, 2012 9:57 pm
As someone mentioned, they used to have different things in the packaging. For a time, Shimano derailleur kits wouldn't have the flexible noodle thing that the Sram/Campy kits did, but then they opted to converge everything into an all-in-one package. Now they'll come with 2x brake cables, 2x gear cables, and the appropriate inner liners for each. One note about the inner liners is that the derailleur liner seems to be slightly smaller in inner diameter than standard cables, so you have to use the supplied Nokon cables. I recommend not using their derailleur liner and instead using the supplied brake liner for brake and gear cabling, or get the Power Cordz/Jagwireliners that work a lot better.
PostPosted: Tue Jun 12, 2012 7:12 am
Thanks for the comments everyone.
PostPosted: Tue Jun 12, 2012 8:55 am
BeeSeeBee wrote:
I recommend not using their derailleur liner and instead using the supplied brake liner for brake and gear cabling, or get the Power Cordz/Alligator liners that work a lot better.
So you have tried the Nokon AND the Alligator links and found that the Alligator links offer even less friction?
It's not how much you spend on a bike it's how hard you can ride it.
PostPosted: Tue Jun 12, 2012 7:11 pm
Whoops, meant Jagwire, not Alligator. I found them to be better just by virtue of giving the cable a bit more room to move.
PostPosted: Wed Jun 13, 2012 2:02 am
I am using Nokon for a difficult TT bike application but the search for the ultimate is never ending :).
Users browsing this forum: astranoc, Bing [Bot], Google [Bot], ipaul, KLabs, rijndael and 43 guests
There are no new unread posts for this topic. Road shift cables with soldered ends
styrrell
9
681
Wed May 15, 2013 5:11 pm
Cosmo View the latest post
There are no new unread posts for this topic. are all brake cables the same?
maddog 2
12
906
Fri Jan 25, 2013 5:06 am
refthimos View the latest post
There are no new unread posts for this topic. Clarks Brake Cables
TomCastellani
Sat Oct 20, 2012 11:38 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Titanium brake and derailleur cables
tantra
Thu May 02, 2013 10:07 pm
NiFTY View the latest post
There are no new unread posts for this topic. Attachment(s) Yokozuna brake cables with 2012 SRAM Red Brifters
Cleaner
Fri Jan 11, 2013 9:34 pm
Elrey View the latest post
It is currently Sun May 26, 2013 12:47 am
Nokon brake cable, shift cable & cable sets - buy Nokon cheap
