Post new topic Reply to topic  [ 10 posts ]
PostPosted: Thu Jun 07, 2012 8:34 pm
Is it wise to mount a 22mm tire at the front and the 23mm corsa at the back?
Is the Veloflex corsa better then a Vredestein Fortezza Tricomp?
Specialized Tarmac S-works SL4
http://i891.photobucket.com/albums/ac11 ... 11af34.jpg
PostPosted: Thu Jun 07, 2012 8:47 pm
no matter, lots of folks do different sized tires for different effects. That small of a difference isn't likely to change much of anything besides the placebo effect. But if those are the 2 tires you have laying around by all means roll with it (pun intended)
PostPosted: Thu Jun 07, 2012 8:56 pm
No I am thinking of buying some Veloflex corsa clincher tires for my Racing zero's. So I have to choose the 23mm or the 22mm Corsa's. Which size shall I buy.
I also use the Conti Atack/Force combination (22mm and 24mm) and Conti 4000s 23mm tires on the Racing zero's.
PostPosted: Thu Jun 07, 2012 9:18 pm
Go for it! Whilst you are at it, post up some other questions for us to answer..... ham or turkey? White bread or brown? Put your right shoe on first, or your left? Life is full of tough decisions and WW is here to guide you;)
PostPosted: Thu Jun 07, 2012 9:22 pm
Hé, there could be a difference between 22mm or 23mm because most of the time a tires is actually wider then the size so I think I have a legitimate question. So let me ask the question differently. Is a Veloflex corsa 23mm really 23mm?
PostPosted: Mon Jul 02, 2012 5:27 pm
I've used Veloflex clinchers for a long time. They used to be marketed as 22mm, now they are 23mm. I'm not convinced the tire actually changed-I suspect they've been 22.5mm all along and they are just rounding in a different direction. I have not scientifically measured. Just going on my hunch as someone who rides these tires.
Either way, it's a great tire and does the 1mm really matter?
PostPosted: Mon Jul 02, 2012 7:10 pm
On one of my tubular wheelsets I am running a 22mm Extreme on the front and 23mm carbon on the rear. Seems fine. I tried an Extreme on the rear but a few rides in cut the sidewall, flatted and the tire was trashed. Not sure if it was just bad luck or the Extreme is that much less durable than the Carbon/Corsa. Happened over a rough patch in the road that my clincher veloflex corsas have been over many times.
PostPosted: Mon Jul 02, 2012 8:24 pm
I bought the Corsa clinchers a few weeks ago. I went with the 22mm version because I thought that 22mm is 23mm in reality.
1mm can make a difference by the way. I the tires roll very well and I use them with Michelin Latex tubes.
PostPosted: Mon Jul 02, 2012 8:42 pm
They are the same tire. I have both and have measured both are there is no significant difference between the two. Actually if I recall correctly my 22s measured wider. Something like 22.65 vs 22.49 or something like that (I just made those numbers up but that's how close they are).
PostPosted: Tue Jul 03, 2012 12:45 am
Tubbie Guru
Hi,
Should there still be a choice I'd put a Corsa 20mm on the front and a 22mm (or 23mm :mrgreen: ) on the rear.
I actually used to ride that combo with a set a Vredestein latex inner tubes and found it to be no different than say a 22/22 combo so I opted for the lighter combination which would also yield some smallish (read mostly insignificant for my kind of usage) aero advantage.
To my mind and given a decent set of wheels this is the closest to riding clinchers that ride like tubulars you'll ever come anyhow.
And yes, the Veloflex tyres are better than the Vred Fortezza Tricomp, much better even.
Ciao, ;)
Users browsing this forum: bratz, caballero, Google [Bot], Google Adsense [Bot], markyboy, Nismo4x4, thprice, ubernesss and 38 guests
There are no new unread posts for this topic. Vittoria Open Corsa EVO Slick or Veloflex Corsa 22
btompkins0112
Fri Apr 19, 2013 6:08 am
markyboy View the latest post
There are no new unread posts for this topic. Evo CX v Evo SC v Veloflex Corsa
finner
Fri Jun 15, 2012 10:41 am
finner View the latest post
There are no new unread posts for this topic. anyone use veloflex Corsa/Record 20???
mjduct
9
590
Sat Jun 16, 2012 9:57 am
Juanmoretime View the latest post
There are no new unread posts for this topic. veloflex corsa vs master
mrlogan
Wed Jun 06, 2012 11:38 am
mrlogan View the latest post
There are no new unread posts for this topic. Veloflex Corsa tread direction
chiltonp
11
718
Thu Jan 03, 2013 7:45 pm
dereksmalls View the latest post
It is currently Sat May 25, 2013 6:26 am
