Post new topic Reply to topic  [ 11 posts ]
PostPosted: Thu Jun 07, 2012 12:51 am
Hello everybody, i have question. I'm starting a new build with a Scott frame and a Look HSC5 SL fork. I have a semi-headset but when i try to install it there is a gap above the crown (see foto). Is this normal or not and if so is it a problem besides how weird it looks.....
Thanks!
Klein q-pro xx
Colnago Master Olympic
Scott Cr1 Team '04 custom
PostPosted: Thu Jun 07, 2012 5:57 am
Thanks!
The HSC-5SL is designed for an "integrated 1 1/8" " head set. Not a 'zerostack' though. That's most probably the problem. I've had that fork before on my Look 585.
The diagrams from Canecreek on the various standards may help explain better:
http://www.canecreek.com/manuals/Headse ... ev%20E.pdf" onclick="window.open(this.href);return false;
Special note on PAGE 12 on the integrated crown race as similar to that of the HSC-5SL fork here:
http://www.canecreek.com/manuals/Headse ... nGuide.pdf
PostPosted: Thu Jun 07, 2012 10:23 am
Oke thanks for the info! Do i solve this by buying a diffrent headset or is a diffrent lower bearing oke? And if so were is it that i can buy one and should it be the 45*/36*?
Klein q-pro xx
PostPosted: Thu Jun 07, 2012 11:34 am
That's not the right bearing. It should sit much lower.
PostPosted: Thu Jun 07, 2012 12:27 pm
The bearing should have laser engravings on it. The correct one for the fork should have "36x45" on it. I would think yours is a "45x45" bearing.
However, as far as I recall, the Scott frame uses a zerostack hiddenset, so I'm not sure if such a bearing suitable for the headset exists ? :noidea:
Edit: As pointed out below, the bearing designations should be the other way around. 45x45 rather for the fork to fit.
PostPosted: Thu Jun 07, 2012 8:13 pm
Oke, thanks i Will look it up. I know it's possible cause i see a lot off cr1 with the hsc5 sl fork in it in the net. Just need to figure it out..... Someone here schold know a solution.
Klein q-pro xx
PostPosted: Fri Jun 08, 2012 5:06 am
the bearings of all zerostack headsets ive ever seen were 36x45. it appears the look takes a 45x45, as that alone would make the crown sit a lot deeper into the bearing. ive seen plenty of "hybrid" bearings, ones that are 41.8mm like campy but have a very shallow compression ring seat like I.S.. ive never seen one the other way around, though.
PostPosted: Fri Jun 08, 2012 5:56 am
Yes indeed ... you're correct. The Zerostacks seem to come with 36x45. So, if that's the case, the HSC%-SL fork should need a 45x45 bearing instead. (guess I remembered it wrongly with some other frame... )
The interchangeability of these bearings for fitting onto the Zerostack is something I've not tried. So no idea if they are there ...
PostPosted: Fri Jun 08, 2012 6:29 am
Partly to solve this problem some headset manufacturers make deeper cups for the bottom. I identified 3 "cup depth" from FSA, Cane Creek, no-name both in steel and aluminum. In this case, when assembling the bike, all I would do is exchange the bottom cup for a deeper one which provides an aestetically pleasing small gap.
PostPosted: Fri Jun 08, 2012 12:05 pm
Thanks peruffo came to the same conclusion last night. First i thought just change the bearing but they are not the same size. I think i am going for the hybrid version keep the top half of my own headset. Now i just need to find were i can get the bottom half of a headset with a deeper cup.
Klein q-pro xx
PostPosted: Fri Jun 08, 2012 12:16 pm
You only need a deeper cup, maybe from LBS's wastebin. I take the cups out of all damaged/discarded frames so I can play aroud with cup sizes. You need 36/45 bearings, and matching lower cone and top shim/aligner/cap.
Users browsing this forum: Google [Bot], Google Adsense [Bot], HammerTime2, Musiker and 71 guests
There are no new unread posts for this topic. DA Di2 problem or maybe not?
expan
Fri Oct 05, 2012 6:44 pm
expan View the latest post
There are no new unread posts for this topic. Red derailleur problem
Roeboe
16
773
Mon Oct 29, 2012 6:05 pm
Roeboe View the latest post
There are no new unread posts for this topic. problem with my seatpost fuji sst 3.0
jasonliliong
Wed Jun 13, 2012 4:41 am
drmutley View the latest post
There are no new unread posts for this topic. cervelo r3 clicking problem
apLe
18
1138
Tue Jun 19, 2012 3:39 pm
ricorob View the latest post
This topic is locked, you cannot edit posts or make further replies. ENVE CLINCHER problem
[ Go to page: 1, 2, 3, 4 ]
tigoose
48
4155
Sat Dec 08, 2012 5:21 am
Tinea Pedis View the latest post
It is currently Fri May 24, 2013 9:14 pm
