Post new topic Reply to topic  [ 255 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 17  Next
PostPosted: Tue Jul 17, 2012 10:40 am
Administrator
So with a ceramic bottom bracket ( regular bottom bracket as in 68mm threaded) and a ring transplant you could have a sub 600 gram crank and bb combination?
Also does anyone know what the q-angle is on the new Red?
CBRE We would all still like to know what modification had to be made to the ring to make it work? :beerchug:
PostPosted: Tue Jul 17, 2012 1:43 pm
Simple, remove catch pin on big ring, unbolt old rings and install Paxis rings, 10 minute job, 50 grams less.
Curt Brown
2012 Cannondale Supersix EVO SRAM Red 10.8#'s
2012 Cannondale Super X 14.1#'s and dropping....
2011 Cannondale Carbon Flash 1 17.2#'s
1999 Cannondale F2000, SRAM XO 18.9#'s
http://cbevo.com/2012_cd_supersix_evo_31.html
PostPosted: Tue Jul 17, 2012 9:30 pm
Does that mean that any standard 5 bolt rings will work on the new Sram Red crankset? Speaking of which, which BCD is yours?
One more question: how did you position the shifting ramps?
PostPosted: Tue Jul 17, 2012 9:42 pm
^^^^^ Yes.
Exp001
PostPosted: Tue Jul 17, 2012 10:07 pm
Yes, any 130bcd will work, mine are 180 out, works perfect, now about 1000 miles perfect shifting.
Curt Brown
PostPosted: Tue Jul 17, 2012 10:12 pm
Just got in the GXP version of the crank, compact.
Initial weights revealed remarkably light arms & spindle, competitively light 34t ring (that was already known from SRAM), heavy-ass 50t (as CBRE hinted with his finding of the 52t) and overall great quality.
Rough calculations on some components that are still arriving, based from documented weights, indicate a total crankset weight of ~590g (including BB).
I'll set up a thread when I have everything in, with scale shots.
Exp001
PostPosted: Tue Jul 17, 2012 10:16 pm
Not any 5 bolt will work. The outer ring has to be the same thickness: 4mm. Otherwise you will get runout issues.
PostPosted: Thu Jul 19, 2012 6:53 pm
Bump. I'm looking to shed some weight from my current R700 compact cranks (760g. w/o BB). My understanding is that by going with the 2012 Red compact cranks I would see somewhere about 520g. w/o BB? Assuming the GXP press-fit BB weighs about the same as my current press-fit Shimano BB this would result a weight drop of 240g :shock: Please let me know if I'm in the right ball park. My crank is a 170mm.
PostPosted: Thu Jul 19, 2012 7:01 pm
GXP Compact 172.5 (170 will be the same)
Arms (L+R+spindle) is ~ 402g
The 50T chainring from SRAM is rather heavy at 128g.
34T is 28g
Bolts are all aluminum, ~9g for the set
That should give you proper calculations, everything else you can look up.
If you play your cards right, you can go to ~580g complete (ready to ride including BB) without using CF chainrings.
GXP crankarms are heavier than the BB30 crankarms because the GXP uses a steel spindle. The BB30, being a larger diameter, allows for the use of alloy spindles. This results in a lower crankarm weight. I wasn't in the mood to change my frame though, and later on the GXP can be applied to other frames I have on hand, so I went with the GXP/BSA variety.
Exp001
PostPosted: Thu Jul 19, 2012 7:49 pm
prendrefeu,
Thank you for the speedy reply. So I added up the numbers and it looks like the complete crank minus the BB is 567g. That is more than 200g. lighter than my current crank 8) The price on the new Red crank is dropping and I can't see any other competition to the new Red crank in terms of value.
My future diet plan
BR-7700 to 2012 Red Aero Link 74g. savings
Ti spindle for my Speedplay X2 50g. savings
Total cost for the three changes is $700 for a total weight saving of 324g.
PostPosted: Fri Jul 20, 2012 12:55 am
Right on! :beerchug:
Exp001
PostPosted: Sat Jul 21, 2012 11:41 pm
Does anyone have weights for the GXP std, 53/39? Some good prices out there just now for the 2012 crank, so looking to see if it's worth upgrading from my old Red GXP std to 2012.
Thanks in advance
GJ
PostPosted: Sun Jul 22, 2012 8:17 pm
Will the praxis rings need to be rotated also on the 50/34 crank set?
PostPosted: Sun Jul 22, 2012 8:38 pm
Yes.
Exp001
PostPosted: Sun Jul 22, 2012 9:29 pm
Thanks in advance
GJ
I think BikeRumor weighed them at 588g, excluding BB, not sure of the length though.
Post new topic Reply to topic  [ 255 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 17  Next
Users browsing this forum: 12x23, Bing [Bot], eric, Majestic-12 [Bot] and 47 guests
There are no new unread posts for this topic. Anybody have info/confirm on Campagnolo BB386 crank
maggierose
Mon Dec 03, 2012 9:54 pm
maggierose View the latest post
There are no new unread posts for this topic. Columbus Raw SL frameset info
gb103
Tue Jan 01, 2013 3:24 pm
gb103 View the latest post
There are no new unread posts for this topic. Info needed on BMC SLR01 headset....
boss155
Thu Jun 07, 2012 3:35 pm
Kneedragon View the latest post
There are no new unread posts for this topic. Any more info on the StageONE power meter?
AGW
Thu Sep 20, 2012 9:25 pm
AGW View the latest post
There are no new unread posts for this topic. Giant Tcr limited edition frame? any info
digiadaamore
9
1271
Wed Aug 15, 2012 10:13 pm
digiadaamore View the latest post
It is currently Thu May 23, 2013 12:47 am
