It is currently Tue Oct 17, 2017 8:02 pm
Post new topic  Reply to topic  [ 283 posts ]  Go to page Previous 115 16 17 18 19 Next
PostPosted: Tue May 28, 2013 10:58 am
I have been trying to install a 50t Stronglight CT2 chainring on my compact 170mm BB30 Exogram cranks. I've filed the hidden arm and it fits in the curve, but i still need to press the chainring on the crankset to get it to fit. When i install the bolts and all, the chainring ends up beeing uneven where the hidden arm is (closer to the frame). So the chain will run a bit to the left and right in the cage. Anybody had the same problem?
Tumblr
Instagram
Kaptajn Webstore
PostPosted: Tue May 28, 2013 2:22 pm
I had the exact issue with mine and I was conviced it was something wrong with the crankarm. I took it to the bike shop and, to my embarrassment, they fixed it in 5 minutes; the interface between the crankarm and the chainring was not clean, and all they did was to remove the chainring, clean both parts and reinstall - problem solved.
It sounds as if you filed down the crankarm; I suggest you to file the chainring down instead (i.e. round the corners).
PostPosted: Tue May 28, 2013 4:33 pm
I've already tried cleaning both parts, and the original Sram chainring fits like a glove, but the Stronglight just need at little pressure to settle, but then when fastened with the bolts it's uneven.
And don't worry i filed the chainring and not the cranks :D
Tumblr
Instagram
Kaptajn Webstore
PostPosted: Tue May 28, 2013 9:46 pm
I had to file the hidden arm of the chainring on my Praxis rings, but other than that, no problems. 1,500km so far and no issues.
PostPosted: Sat Jul 13, 2013 6:34 pm
So can anyone confirm that Stronglight chainrings will fit SRAM Exogram?
I have 34 and a 51 110BCD that I would want to fit.
PostPosted: Wed Nov 13, 2013 1:25 am
prendrefeu wrote:
They do work, if you rotate them.
Praxis does not market them to work with the new exogram cranks, but they do work. See the difference? All you need to do is rotate the two chainrings a bit so that they are still oriented together/aligned but now match the crank arm hole pattern. You can file down the catch pin, it is really unnecessary but included "just because" - Adam has even mentioned somewhere that the length of that catch pin was made fairly standard and it can be filed down to make it fit for various arms.
and for those of you still asking: READ THE THREAD!!! THIS WAS ALREADY COVERED IN THIS VERY THREAD!!! WHY ARE YOU ASKING QUESTIONS WHICH HAVE ALREADY BEEN ANSWERED IN THIS THREAD?? READ, PLEASE, READ!!!!!
OK I'm new (to this forum anyhow) and have just read through (twice) the 18 pages of this thread. Here is what I'm seeing if I'm reading the info correctly.
- they work if you rotate them 180 (pin in the wind)
However the 2 main pictures posted show the pin in the wind but just above or just below the crankarm (not 180 rotation)? So with this I would like to "clarify" the following..
1. They work if you rotate them 180 (pin in the wind)
2. They work if you rotate them (pin in the wind) either just above or just below the crankarm
3. They work if you file down the pin so you can install in the regular rotation with the pin behind the crankarm
Thanks in advance
PostPosted: Wed Nov 13, 2013 5:22 am
1. Yes, 180° work perfect, as-Praxis-intended (ie, their "shift" system)
2. Yes, it will work, but not absolutely-as-Praxis-intended perfect.
3. This last one... it won't install that way on a Exogram crank because on the back of the arm there is a mounting hole, but the pin is located in between mounting holes. So yes, you can file it down since the pin won't be put in use, but it won't be behind the Exogram crank arm. That's not possible.
PostPosted: Wed Nov 13, 2013 5:49 am
Thanks so much, I will order some up while I wait for the official SRAM ones. I know they'll be heaiver but I like the look.
PostPosted: Wed Mar 05, 2014 11:56 am
Administrator
I'm bumping this thread with a question. Is anyone now making aftermarket rings designed to work with the hidden bolt Sram cranks?
RESIDENT GRUMPY OLD MAN.
PostPosted: Wed Mar 05, 2014 12:02 pm
Is there a need? Even my Osymetric rings can be used as intended on the sram red cranks, so there shouldn't be any reason why any round chain rings can't go on it.
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Wed Mar 05, 2014 1:42 pm
I know that the Extralite Octaramp RC2 rings work with the new crank.
6.24kg CAAD10
PostPosted: Wed Mar 05, 2014 1:54 pm
:| but you don't have the same cranks...
PostPosted: Thu Mar 06, 2014 1:11 am
Hi
TA Specialites Hegoa (53/39) work fine on mine.
Cheers
GJ
PostPosted: Thu Mar 06, 2014 10:24 am
My Sram 39 T gear is only 29 grams (130 mm).
PostPosted: Wed Mar 26, 2014 9:44 pm
Out of curiosity, anyone using the Praxis/Red crank configuration with Di2? I'm tempted to go this route if there's no problem with it.
There are no new unread posts for this topic. Post deleted. Please read the rules.
skokjef
Tue Oct 25, 2016 2:34 pm
skokjef View the latest post
There are no new unread posts for this topic. Ax Lightness - no more! -Not so much, read page 2 respond by Nils
[ Go to page: 1 2 3 4 ]
wheelsONfire
50
7694
Mon Jul 10, 2017 3:17 pm
tharmor View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
956
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. Crank arm size
WhyZ
Sat Feb 18, 2017 10:20 am
Kayrehn View the latest post
There are no new unread posts for this topic. 130 BCD crank w/ 52/36 chainrings?
jbaillie
9
1299
Sat Jan 28, 2017 3:35 pm
mythical View the latest post
Users browsing this forum: agfu, baldy, beanbiken, dim, Ltyarbro42, Pschnei3, Yahoo [Bot], Zakalwe and 41 guests
