Post new topic Reply to topic  [ 255 posts ]
Go to page Previous  1, 2, 3, 4, 5 ... 17  Next
PostPosted: Thu Jun 07, 2012 7:26 pm
How much space is there between the crank and the ring? Not a huge worry, but if you throw the chain over will it wedge between the crank and ring (since the peg will be in the wrong spot due to the hidden chainring bolt)? Otherwise, seems to be the new budget ww BB30 crank.
PostPosted: Thu Jun 07, 2012 7:29 pm
I am curious about stiffness as well. Sounds like SRAM has made some needed improvements with the cranks. But for the cost, you can get a Hollowgram SI crank that will be the same weight all in. Not sure the Red is going to be as stiff as the Hollowgram.
"Let's plunge ourselves into the roar of time, the whirl of accident; may pain and pleasure, success and failure, shift as they will -- it's only action that can make a man."
PostPosted: Thu Jun 07, 2012 10:28 pm
prendrefeu wrote:
...on a scale.
Just because, you know, as someone who has been a member since 2003 would be familiar with, scale shots are required for verity on this forum.
Not going to pull the crank back off but here is the ring and my crank:
Curt Brown
2012 Cannondale Supersix EVO SRAM Red 10.8#'s
2012 Cannondale Super X 14.1#'s and dropping....
2011 Cannondale Carbon Flash 1 17.2#'s
1999 Cannondale F2000, SRAM XO 18.9#'s
http://cbevo.com/2012_cd_supersix_evo_31.html
PostPosted: Thu Jun 07, 2012 10:30 pm
The new Red crank is very stiff, much better than the 2011 Red unit, plenty stiff for me at 145#'s. Now the TA ring is fine for me but I would think a 200# sprinter type should get a set of Praxis rings, light and strong.
Curt Brown
PostPosted: Thu Jun 07, 2012 10:48 pm
Thanks for the photos.
The weight on that chainring. YIKES. :shock:
Exp001
PostPosted: Thu Jun 07, 2012 10:49 pm
Sounds like an easy way to shed a bit of weight! I guess we just have to find some rings that are the correct thickness at the hidden bolt location so we don't get runout issues. It probably won't be long before TA/Fiberlyte/etc make rings with movable catchpins so it'll work on this crank.
PostPosted: Thu Jun 07, 2012 11:11 pm
Though the Sram chainring is pretty heavy compared to others it does have some aero advantage.
PostPosted: Fri Jun 08, 2012 5:06 am
I have been trying to look for Hollowgram SI's or SL's but have not had luck finding them sub $500. And with SRAM being <400, that would be a good buy.
PostPosted: Fri Jun 08, 2012 8:37 pm
So, what do you think, why do SRAM put so much material into it?
wasting 64grams of aluminium?
PostPosted: Fri Jun 08, 2012 9:25 pm
Interesting. My Evo has Sram Red compact rings and when I replaced them with Praxis Works rings I weighed the Red rings together and came up with 138g.
PostPosted: Sat Jun 09, 2012 1:16 am
That's OLD Red, I Have the new 2012 Red.
Curt Brown
PostPosted: Sat Jun 09, 2012 1:19 am
I would not say wasting, the new ring shifts great and is the stiffest I've seen, but at 145#'s on an 11# bike I don't need them that stiff, thus the lighter ring(WW you know:)).
Curt Brown
PostPosted: Sat Jun 09, 2012 5:18 am
I am sure this isn't true, "Compatible only with SRAM Yaw Front Derailleur"
Thanks for sharing!
PostPosted: Sun Jun 10, 2012 5:20 pm
Formerly known as PezTech
The Yaw of the front der doesnt have as much to do with shifting as it does in dealing with chain line. The lift and more firm action is where the shifting benefit comes in
It's also off base to say the new cranks are "a lot" stiffer than the old ones. Theyre not. The old ones were pretty dang good. The thing that most folks are feeling is a much better ring design and a much improved front Der action. That said, I wouldnt hesitate to go to the new praxis rings and cut weight without giving much away (if anything at all) in shifting.
charles@pezcyclingnews.com
PostPosted: Sun Jun 10, 2012 8:51 pm
Your right on the crank stiffness thing, I don't think I could flex any crank at 145#'s! Im ordering the Praxis rings also.
Curt Brown
Post new topic Reply to topic  [ 255 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 17  Next
Users browsing this forum: Google [Bot], kya, MichaelB and 40 guests
There are no new unread posts for this topic. Anybody have info/confirm on Campagnolo BB386 crank
maggierose
Mon Dec 03, 2012 9:54 pm
maggierose View the latest post
There are no new unread posts for this topic. Columbus Raw SL frameset info
gb103
Tue Jan 01, 2013 3:24 pm
gb103 View the latest post
There are no new unread posts for this topic. Any more info on the StageONE power meter?
AGW
Thu Sep 20, 2012 9:25 pm
AGW View the latest post
There are no new unread posts for this topic. Info needed on BMC SLR01 headset....
boss155
Thu Jun 07, 2012 3:35 pm
Kneedragon View the latest post
There are no new unread posts for this topic. Giant Propel production pics and info
Ryan94
Fri Jan 18, 2013 3:38 am
Ryan94 View the latest post
It is currently Mon May 20, 2013 9:53 am
