Post new topic Reply to topic  [ 255 posts ]
Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 17  Next
PostPosted: Thu Sep 13, 2012 5:01 pm
cyclenutnz wrote:
Red Quarq is 789g on my scales (175mm GXP 53/39), Praxis rings on the way.
Annoyingly it is just the S975 crank with the spider positioned such that one bolt is hidden but not part of the arm. Which means taking the arm off to change chainrings - which rather defeats one of the advantages of the Mercury spider (that it doesn't care about changing rings and can fit a TT ring thanks to the smaller battery).
You don't have to take off the arm to change the chainrings. The nut behind the arm is knurled so it can't rotate when you loosen the bolt from the other side.
mate wrote:
Hi guys,
please tell me if Praxis 52/36 semi-compact rings will work with my SRAM RED QUARQ compact. The guy from Quarq sad yes, the guy from Praxis say no.
It will work, but your catch pin will be rotated 180 degrees from where it normally is.
PostPosted: Thu Sep 13, 2012 5:12 pm
Just installed Praxis 52/36 sub compact chain rings with 2011 Sram Red crank set and couldn't be happier. The shifting is precise and the power transfer feels much more immediate. Now using 52/24 gearing for 6% grade climbs which I never would have tried with red compact rings. Hope to add Quarq soon. Any suggestions appreciated.
PostPosted: Fri Sep 14, 2012 12:48 am
Dear Mate,
- If you are using a traditional 5arm crank, they will work perfect.
- The brand NEW 2012 RED has it's own new 4 arm mount with 5th mount in the arm. At this time, we do not market our rings for this crank due to the mounting.
- 2011 RED = Yes
- 2012 RED = No
Adam@Praxis
Praxis Works
Manufacturer
Santa Cruz County, CA
PostPosted: Fri Sep 14, 2012 2:23 am
AptosBigRing wrote:
Dear Mate,
- 2011 RED = Yes
- 2012 RED = No
Adam@Praxis
are you guys working on rings for the new RED?
PostPosted: Fri Sep 14, 2012 7:58 am
AptosBigRing wrote:
Dear Mate,
- 2011 RED = Yes
- 2012 RED = No
Adam@Praxis
Thanks Adam
You are saying that like that "It will work, but your catch pin will be rotated 180 degrees from where it normally is.", it wouldn`t work?
Matevz
PostPosted: Fri Sep 14, 2012 8:24 am
They do work, if you rotate them.
Praxis does not market them to work with the new exogram cranks, but they do work. See the difference? All you need to do is rotate the two chainrings a bit so that they are still oriented together/aligned but now match the crank arm hole pattern. You can file down the catch pin, it is really unnecessary but included "just because" - Adam has even mentioned somewhere that the length of that catch pin was made fairly standard and it can be filed down to make it fit for various arms.
Now, why are they not marketed to work? Because the whole Praxis concept is that with Levatime(tm), the chainrings have ramps and bits to perfectly engage your chain as you rotate the cranks with the most ideal situation of your power stroke in the rotation, and this is all based off of the traditional arm orientation that we've seen from past SRAM and Shimano, FSA, etc, crank arms. Technically speaking, the Levatime system will still work fine no matter what: if everything is rotated together, it will work. Will it work as absolutely perfectly to the utter millisecond that Praxis intended when they designed the chainrings? Maybe, maybe not, but the shifting is still phenomenal and you probably won't notice the difference. As a business it is not Praxis' intention to market that their product works when it isn't to the exact perfection that they intended - which, thankfully, Praxis is a very high-standard company. This also allows them to produce new sets of chainrings in the future which match the Exogram cranks (and, potentially, have an upcharge, but that's between them and your wallet to discuss). Marketing, look it up sometime.
So yes, you can use the current chainrings from Praxis with your Exogram cranks.
PERIOD.
and for those of you still asking: READ THE THREAD!!! THIS WAS ALREADY COVERED IN THIS VERY THREAD!!! WHY ARE YOU ASKING QUESTIONS WHICH HAVE ALREADY BEEN ANSWERED IN THIS THREAD?? READ, PLEASE, READ!!!!!
Exp001
PostPosted: Fri Sep 14, 2012 11:24 am
PERIOD.
That are the words I wanted to hear.
thanks
SORRY
PostPosted: Fri Sep 14, 2012 12:15 pm
Hey Prend, The rings should shift exactly as intended. They should have rotational symmetry of order two otherwise they would shift differently depending on which foot was forward. Ie flip them 180 degrees and they should look the same except with the pin hanging in the wind.
nb. I haven't actually seen the rings although I would find it odd if they weren't symmetrical in this way.
PostPosted: Fri Sep 14, 2012 12:21 pm
My Praxis 53t works perfect even along with a 39 Rotor Q Ring inner, shifts are solid and fast, next flex and perfect.
Curt Brown
2012 Cannondale Supersix EVO SRAM Red 10.8#'s
2012 Cannondale Super X 14.1#'s and dropping....
2011 Cannondale Carbon Flash 1 17.2#'s
1999 Cannondale F2000, SRAM XO 18.9#'s
http://cbevo.com/2012_cd_supersix_evo_31.html
PostPosted: Fri Sep 14, 2012 3:54 pm
Yes, I know, I'm running Praxis on my Exogram compacts. By stating something like "they may not work exactly perfectly but they'll work regardless" I'm still giving a nod to Praxis' marketing game while giving people a basically correct answer. :wink:
Exp001
PostPosted: Fri Sep 14, 2012 4:07 pm
Is the catch pin on the Praxis rings removable?
PostPosted: Fri Sep 14, 2012 4:13 pm
Not that I am aware of, it seems to be riveted in.
Exp001
PostPosted: Fri Sep 14, 2012 4:18 pm
Mine removed itself somehow, so you should be able to remove it if you wanted :wink:
PostPosted: Sat Sep 15, 2012 12:41 am
ANYTHING is removable, vise grips or dremel tool will work.
Curt Brown
PostPosted: Sat Sep 15, 2012 3:35 am
Prendrefeu - Thanks for basically writing what I can't. :thumbup:
Adam@Praxis
Praxis Works
Manufacturer
Post new topic Reply to topic  [ 255 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 17  Next
Users browsing this forum: Google Adsense [Bot], martroy and 55 guests
There are no new unread posts for this topic. Anybody have info/confirm on Campagnolo BB386 crank
maggierose
Mon Dec 03, 2012 9:54 pm
maggierose View the latest post
There are no new unread posts for this topic. Columbus Raw SL frameset info
gb103
Tue Jan 01, 2013 3:24 pm
gb103 View the latest post
There are no new unread posts for this topic. Info needed on BMC SLR01 headset....
boss155
Thu Jun 07, 2012 3:35 pm
Kneedragon View the latest post
There are no new unread posts for this topic. Any more info on the StageONE power meter?
AGW
Thu Sep 20, 2012 9:25 pm
AGW View the latest post
There are no new unread posts for this topic. Giant Tcr limited edition frame? any info
digiadaamore
9
1275
Wed Aug 15, 2012 10:13 pm
digiadaamore View the latest post
It is currently Thu May 23, 2013 1:53 pm
