AX Orion question
pierre-san
by pierre-san
Hey Guys,
I can't adjust the back brakes any lower, 'cause they're as low as they go, but the brake pads are just hanging off the top of the brake track. Any suggestions?
I thought I could get to them with a file, and file away the slot in the brake arm, so the brakes could be adjusted lower. :noidea:
Thanks in advance.
Cheers,
Pete
wshiong
by wshiong
any photo ?
Passoni Mirror
Passoni Xxti
pierre-san
by pierre-san
Sorry they are a bit crappy.
rd
by rd
I definitely wouldn't modify the brake itself. Can you fit a set of pad carriers with the proper ball and socket adjustment so you can angle the pad down? That will buy you around 2mm if they will physically fit between the rim and the brake arm; or if the brake will open wide enough etc...
maverick_1
by maverick_1
@Pierre,
don't file the brake slot, or you'll end up with a damage Orion.
it's hollow inside as well (i presume)
bring this over to a YS Road at Okachimachi (tiny little shop), look for the head mechanic.
this guy is good, and the shop has loads small spare parts (Campy, Shimano etc), pretty sure there's some bracket, plate or something to lower down the calipers.
have him look at it and ask for the best possible solution.
let us know how it goes.
cheers!
wshiong
by wshiong
maverick_1 wrote:@Pierre,
cheers!
Bro,
Just some out topic qustions, do you have their email ( ys road ) i try to contact them but fail to find their email, all in japanese which i dont understand. :mrgreen:
Passoni Mirror
Passoni Xxti
thisisatest
by thisisatest
you need this:
im looking into where they might still be available...
elviento
by elviento
Wonder what that would do to the weight... if much then it negates the whole point of running AX.
thisisatest wrote:you need this:
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
pierre-san
by pierre-san
Hey Guys,
Thanks to everyone for chiming in. I have changed the pad holders to KCNC, and I also did a bit of filing! It's not perfect but good enough. I just got a set of Enve 3.4 Smart rims built up, so will be interested if it's better or worse with the different rim profile.
Cheers,
Pete
