Post new topic Reply to topic  [ 17 posts ]
Go to page 1, 2  Next
 Post subject: Isis or Octalink BB?
PostPosted: Thu May 31, 2012 2:18 pm
Back in '07 I changed to a compact chainset. I have tried Shimano Hollowtech & Sram with GXP external. Both of these chainsets have suffered from creaks, clicks & frequent renewals of the BB. I have now gone back to an FSA compact with the old style Octalink BB. I now have a quiet chainset & know from old that the BB will be good for thousands of miles.
My question is:- owing to the limited availability of compact/ Octalink chainsets, should I consider those which are Isis BB compatible? How does the Isis BB compare to Shimano re quietness & longevity?
Many thanks.
 Post subject: Re: Isis or Octalink BB?
PostPosted: Thu May 31, 2012 4:31 pm
I would avoid ISIS, I never got on well with them on my MTB's. If you want reliable creak free running get a square taper BB and crankset. TA still make square taper cranks and of course you an fit the 10 speed rings if you run 10 speed. JD whiskers still have stok of various square taper cranksets.
Octalink is a better BB in my opinion than ISIS as its bearings are bigger than ISIS (I think thats right). I presume you have had the preload on the shimano hollowtech BB set correctly and you have tried the higher pec shimano BB's too.
I personally cannot stand SRAM GXP. certainly for MTB's the sealing ust is noot good enough.
www.thecycleclinic.co.uk
PostPosted: Thu May 31, 2012 8:31 pm
the only reliable/durable/creak free BB/cranks are Hollowtech II, Square and octalink
PostPosted: Thu May 31, 2012 8:48 pm
Anything except Isis.
For certain parts stiffer is more important than lighter.
PostPosted: Thu May 31, 2012 9:30 pm
I have had good luck with my Zipp300 crank which is ISIS. :noidea:
"Let's plunge ourselves into the roar of time, the whirl of accident; may pain and pleasure, success and failure, shift as they will -- it's only action that can make a man."
PostPosted: Fri Jun 01, 2012 12:11 am
That is why Zipp has not made them since 2008 and they were way overpriced at something like $700. Isis is a weak design there are numerous posts on almost every bike forum about how bad Isis is. The bearings are too small in the design.
PostPosted: Fri Jun 01, 2012 1:35 am
Still doesn't take away that I personally have not had issues with it.
PostPosted: Fri Jun 01, 2012 1:47 am
your the 1 in a million its worked for, Honestly Isis BB's are really bad
PostPosted: Fri Jun 01, 2012 3:29 am
If you want to have the least problems with ISIS, get an FSA Platinum Pro MegaQuad Ti BB (Whew!). They are getting to be hard to find these days, and used to be expensive. But it was the most reliable ISIS BB due to the quad row of bearings. The Ti axle helped keep weight down to around 200-210 gms. One con of the Octalink was it required some preload adjustment and the weight, closer to around 230-250 gms. But their reliability was unquestioned.
One thing about the ISIS cranks, was they were light. The FSA light series weighed around 519 gms with both arms. And when they were being discontinued, you could get them for cheap (like $125). You can still get ceramic/Ti ISIS BBs on Ebay which weigh around 160 gms and so the weight on these setups rivaled anything available today.
PostPosted: Fri Jun 01, 2012 6:01 am
Which Octalink? I love the DA model... very light (180g I think) and if you take it apart and regrease it occasionally it lasts a very long time. So long I've yet to wear one out... but I have a couple of spares just in case. I have spare IRD carbon cranks too (540g)... so I should be set for awhile. Maybe by then there will be a real BB "standard" that actually works.
PostPosted: Fri Jun 01, 2012 10:37 pm
there was, it was 68 threaded with a Hollowtech II BB and crank
PostPosted: Sat Jun 02, 2012 5:12 am
I agree about the FSA ISIS BB. It's got dual row ball bearings. ISIS's problem was not enough room between the axle and the shell for decent sized bearings. The dual row bearings addressed that. I've taken them apart and the bearings are close to the ends of the axle. Token's ISIS BB has single row bearings that are farther in. No wonder they don't last as long.
Octalink left more room for bearings. DA BBs used a roller bearing in addition to some ball bearings. They are rebuildable and adjustable. Which, unless you periodically rebuild and adjust them, is a drawback. Most people these days expect their BBs to just work. Shimano still makes octalink BBs- the heavy but serviceable 105 and a track one which is similar to the Ultegra.
I'm not sure what problems you had with GXP but I have been very impressed with mine. I'd read bad things about it but my GXP BB spins much more freely than any of the Octalink or ISIS BBs I've had and makes no noise with the Red and Quarq cranks I've put in it. I think that Sram changed the GXP BB a while back. Perhaps they improved it since you tried it.
PostPosted: Sat Jun 02, 2012 6:42 am
I run ISIS on every single bike that I own currently and have never had a single problem. So that is currently 5 bikes 3 road and 2 MTB. I had more problems with my ZIPP VUMA QUADS than I have ever had with my FSA cranks and ISIS BB.
I will also agree that the FSA ISIS cranks are pretty damn light and I love the fact that I can remove the spider and run a single spiderless chain ring which reduces the weight of the cranks even more.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Sat Jun 02, 2012 5:03 pm
IME the DA Octalink lasts about as long between service intervals as the throwaway BBs last between replacements. Just opened mine up after a year (~8k miles) including many rides in rain, and it was surprisingly clean and fine. I cleaned and regreased it anyway, since it was apart, but it didn't need it. I *do* have a drain hole through my BB shell so water doesn't sit in there.
PostPosted: Sat Jun 02, 2012 6:19 pm
Are octalink BB's hard to come by? Are they particularly expensive? Just buy up half a dozen of them and ride your preferred BB to the grave
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], blacktalon, CSKeller, jdott and 50 guests
There are no new unread posts for this topic. BB90 with octalink - is this possible?
se245
10
301
Sun Mar 31, 2013 12:08 am
There are no new unread posts for this topic. BB86 to ISIS conversion? Anything out there?
pawnii
9
504
Tue Jan 29, 2013 12:57 am
pawnii View the latest post
It is currently Thu May 23, 2013 5:09 am
