Post new topic Reply to topic  [ 83 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Great photo of rider
PostPosted: Fri Jun 01, 2012 4:02 am
Clearly, BB30 and Zipp are at fault for this! :lol:
PostPosted: Fri Jun 01, 2012 4:29 am
No need to get worked up over this. It's a regular warranty claim. Most manufacturers would be better served to be more generous in those less clear-cut cases. The guy is a CFO, so it's not like it makes a huge difference to him.
Frankly judging from the photos, there could be several possibilities. Unless each of us was a carbon particle resident in that right chain stay at the time it snapped, none of us will know for sure.
PostPosted: Fri Jun 01, 2012 4:43 am
Oh! I thought this thread was about changing subject names. :lol:
r o y g b i v
PostPosted: Fri Jun 01, 2012 11:25 am
Murphs wrote:
Photo sequence (don't ask for more, there aren't any):
Well, this last shot shows the stays "sprung back" to a degree once torque loads were been removed, and also the r/mech still on it's hanger (so definately NOT a mech in the wheel).
Looks very much like QR/axle failure - wheel pulling out and to the right under high torque load - stays flexed beyond limit then failing. This would be apparent from tear fractures on the inside of both stays. If it's a frame failure at fault, there should almost certainly be compression/crush failure evident on the chainstay (seatstay could have failed as a result and still show the internal tear failure). Cracking on a chainstay prior to these photos would have to crush to fail (shortening the stay and locking the wheel) as the stays are under compression loads, but the frame would feel "soft" long before catastrophic failure. Obviously without detailed photos or examination this still cannot be proven and is just my theory from over 20 years as a composite structures developement engineer (before semi-retiring to shop ownership).
@Walkercycling - No offence meant, sorry if any was taken, and I certainly didn't call you a liar (although re-reading my post I can see how you may feel it was implied - unintentionally I may add).
PostPosted: Fri Jun 01, 2012 1:00 pm
breezerboy wrote:
I didn't include the posters names as it wouldn't mean anything being from another forum.
I have the same username on both forums :lol:
PostPosted: Fri Jun 01, 2012 3:16 pm
From the looks of those pics, it appears to me that the QR skewer came out of the wheel...and that could have caused the problem.
The dropout that we can see doesn't seem to have any damage, and if the wheel was clamped on both sides by the skewer, breaking a chainstay or seatstay would not likely cause the wheel to come out of the frame like that...unless the QR broke or came out in the failure (which is unlikely IMO).
My guess is that this is user (or mechanic) error and that Specialized will likely cover it under warranty regardless...
PostPosted: Sun Jun 03, 2012 4:34 am
Awesome photos. Especially the second one where he gets both wheels parallel and stays up, and the guy on his right is going "dude, you broke your bike".
I'm totally perplexed though - if both seat and chainstays snapped, how is not eating bitumen? Without anything else to go on, I'd have to give credit to Specialized for making a frame that still supports a rider on half a rear end with both stays busted.
PostPosted: Sun Jun 03, 2012 4:07 pm
breezerboy wrote:
Quote:
Just so you guys know, the rider in the picture had a mechanical issue earlyer befor this happened ... not sure if he had the wheel swaped or just looked at but from what i have herd the wheel fell out of the dropouts or pulled out and thats when the frame broke, probably due to the quick realeas not being tight enough
Quote:
I was behind him on the first lap. Whenever he got on the power the wheel would jump to the drive side for a second and then back to its normal spot again. I thought he had a buckle in his Zipp but when he pedalled easy or coasted it was dead straight.I also noticed his gears jumped around at one stage.
I moved up and told him I thought his wheel axle was broken, as it certainly wasn't he QR. After that I stayed ahead of him as there was something seriously wrong with his bike and I didn't want to be behind it.
Obviously issues were there before the failure, but he kept riding anyway. OK, so it was a race, but you certainly can't say the rider was blameless in the severity of the failure.
Did the mechanical cause the failure, or was it a symptom? Who knows, but without more details or further inspection you cannot say this is a "frame failure", just as I cannot say it was rider error/poor build.
This was apparently a JRAWIPWTB*
* Just Riding Along While Ignoring Problems With The Bike
PostPosted: Thu Jun 07, 2012 11:36 am
If anything, that photo sequence make me want to BUY a SL4.
Cant be that poorly designed/built if you can get the rear wheel that far out of shape and not have the whole rear end shear off :unbelievable:
PostPosted: Thu Jun 07, 2012 12:28 pm
I'd like to know if it was a qr failure. It never occurred to me that you could bend the stays like that with chain tension, but of course you can.
I might just upgrade the qr in my rear wheel.
r o y g b i v
PostPosted: Thu Jun 07, 2012 10:11 pm
Specialized have replaced the frame.
PostPosted: Thu Jun 07, 2012 10:13 pm
^ Good for them. Figured they would do that, as it as that is not a battle worth fighting.
"Let's plunge ourselves into the roar of time, the whirl of accident; may pain and pleasure, success and failure, shift as they will -- it's only action that can make a man."
PostPosted: Fri Jun 08, 2012 11:46 pm
2 thumbs and 2 toes up.....someone in Merida's factory in taiwan was smoking pot when that batch was made. :lol:
"Light bike? Its still about the engine!".
PostPosted: Sat Jun 09, 2012 3:52 am
Same thing happened to me on a steel frame. Qr failed during a sprint and bent out the seat and chain stays exactly like that. Luckily I stayed up and skidded to a halt (shredded right through the tire). Mechanic was able to bend it back into place but I didn't feel comfortable riding it after that.
PostPosted: Sat Jun 09, 2012 4:16 am
^ Not sure but did this ever happen with old-school horizontal dropouts? Presuming of course the QR head doesn't come off, doesn't seem like you'd ever see one side of the wheel pop completely off with the old dropouts. I could be wrong...
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: Bing [Bot], Crashtest, Google [Bot], nigel379, rijndael and 76 guests
There are no new unread posts for this topic. SNG Brakes, more information? (Changed title)
Roeboe
19
1056
Sun Oct 28, 2012 8:09 am
Roeboe View the latest post
There are no new unread posts for this topic. Have Zipp changed the curve on their traditional bars?
iscarrr
Wed Mar 20, 2013 7:41 pm
corky View the latest post
There are no new unread posts for this topic. Great idea ...why has no one thought of this
artray
10
1050
Sat Dec 22, 2012 4:27 pm
Geoff View the latest post
There are no new unread posts for this topic. Bryton Rider 50
Fig84
Fri Jun 29, 2012 11:59 am
weeracerweenie View the latest post
There are no new unread posts for this topic. Frame help - small rider
Martin.F
9
535
Tue Jun 19, 2012 2:16 pm
strobbekoen View the latest post
It is currently Mon May 20, 2013 8:16 pm
