Post new topic Reply to topic  [ 8 posts ]
 Post subject: LOOK 695 ZED2 CRANK BB
PostPosted: Sun May 27, 2012 3:42 pm
I bought a new 695 iPack 2011. After every ride my bb is a bit loose. The LBS tightens the non drive side again and then it just happens again. I was told a must put "loctite" on. Could somebody help perhaps ? mgouws@um.co.za
PostPosted: Mon May 28, 2012 10:13 am
on the non drive, there a black round that you can tight a bit. once screwed, it shouldn't move at all...
be sure you pushed well on the drive side.
LOOK 695SR - DI2 - CORIMA AERO MCC/ZIPP 808
10 000km in the sand of Dubai... Hilly roads of RIO de JANEIRO and Mont VENTOUX in France
PostPosted: Tue May 29, 2012 10:18 am
Ptfe plumbers tape is your answer.....
I had to do mine along with the chainring bolts on my SR version.
God it's rigid!!!!
Hope this helps.
PostPosted: Tue May 29, 2012 7:13 pm
Did you put the plumbers tape on the thread on the non drive side before tightening the lock ring ?
PostPosted: Tue May 29, 2012 7:20 pm
I did yes.....
Put a 4-5 layers around the threads....
PostPosted: Tue May 29, 2012 8:49 pm
If you think the lock ring is backing off and letting the BB get loose then teflon tape can't help that situation. Are you even sure the lock ring is backing off? If the pinch bolt is propertly tight it almost can't back off. I have 3 Zed cranks and have never had this problem. Make sure all slack is out of the BB by preloading with lock ring then backing off about one eighth turn. There is a hole in the lock ring to help with tighting it and sometimes you have to crank down hard to get slack out of the bearings. When done you should feel a little play at the peddle when you rock back and forth.
PostPosted: Wed May 30, 2012 6:30 pm
The LBS tightened the BB earlier in the week and i will only ride it tomorrow morning to see how it is. I felt the lock ring yesterday and i felt that the little allan key bolt on the lock ring was lose. Then i tightened it by clinching it with my hand and turning it clockwise. Then i tightened the allan key. The crank feels a bit tight when i spin it around and halfway through the 360 degree it spins a bit more freely.I think the shop overtightened it on purpose a bit, because it might settle in on the ride and loosen a bit. Does this sound right ?
PostPosted: Wed May 30, 2012 7:55 pm
You should take the chain off the small ring so you can spin the crank. Tighten the lockring ring till the crank gets i little hard to spin then back off lockring one eighth turn at a time till the crank spins free all the way around. If you think lockring is backing off put a drop of white paint or nail polish on lockring and crank arm and, after ride see if lockring moved.
Users browsing this forum: carbon337, Comanche_man, Doyler, eric, Exabot [Bot], Google [Bot], Google Adsense [Bot], savechief and 83 guests
There are no new unread posts for this topic. 160 Crank?
wiRIDEfast
15
557
Sat Dec 29, 2012 12:20 am
54x11 View the latest post
There are no new unread posts for this topic. Which crank should I buy ?
Wadl
15
1002
Fri Sep 07, 2012 7:29 pm
Wadl View the latest post
There are no new unread posts for this topic. red chainrings on FSA crank
digiadaamore
Sat Jan 05, 2013 12:59 am
digiadaamore View the latest post
This topic is locked, you cannot edit posts or make further replies. Attachment(s) Ciamillo Crank V2
[ Go to page: 1 ... 6, 7, 8 ]
elfuinha
111
6737
Thu Dec 27, 2012 3:07 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. What chainrings / crank are these
jcumpstay
10
417
Fri Apr 05, 2013 3:28 pm
superb View the latest post
It is currently Mon May 20, 2013 10:51 pm
