Di2 frames - will a EPS cable fit any Di2 frame??
ParisCarbon
by ParisCarbon
Hey all,
Never had electronic before, but looking.. in particular at the Cannondale EVO frame/fork.. but the question I have is will the EPS connection fit the same hole as the Di2? the EPS wiring seems to clip together?? Is the Di2 like this as well? Or do I need to be concerned about particular frames being able to fit particular wires??
Thanks
CharlesM
by CharlesM
yep
The real trick is trying to find space for battery/brainpack.
It's like mounting a Mini Cooper to your frame...
Sybarite
by Sybarite
The EPS will fit the EVO Di2. The 35mm apart battery mounting holes just behind the bottle cage mounts on the down tube are also used for EPS. You need to get the short battery mount for EPS.
ParisCarbon
by ParisCarbon
Perfect.. thanks for the info guys... now Im impatiently waiting to see if I can actually get a Di2 EVO frame... Cannondale only offers them as a complete, so finding someone who is willing to rip one apart for me is not bringing any luck.. if anyone knows a shop with a 58 willing to part out, PM me please!!!!
