Post new topic Reply to topic  [ 3 posts ]
 Post subject: "De-Paired" hub
PostPosted: Sat May 26, 2012 5:17 pm
I'm not sure where this sits on the Idiot-Genius continuum.
Kind of like finding an old baggie of Benotto tape and building a bike around it...
I was stuck for a (reasonably priced/ reasonably light) 20 hole front hub but I wanted something with bearings larger than the 699 size that are popular with light weight Asian offerings.
I found a couple of these Rolf hubs for $10 on you'vegottobekiddingme-bay, and a $7 Dura Ace front spindle. I took everything to bits and had a local machine shop split the hub and turn a sleeve with spacing rib which I then used to reassemble the shell halves properly registered for standard lacing. I used a Loctite Speedbonder structural adhesive to accomplish this. The hub now uses 6802 sized bearings which are buttery smooth and can be adjusted for preload thanks to the Dura Ace spindle.
The weight is not Earth shatteringly light at 120gr, but I think it will be a more durable alternative to the Novatecs that I have been using. The original weight for the hub was 178gr.
I have built this into a Kinlin XR200 with CX Rays and brass nipples (tropical island :idea:) for a finished weight of 614gr.
As an added bonus to my inner scrooge, I was able to use the original spindles in building some bike storage.
File comment: Original shell
File comment: Paired holes.
File comment: Finished hub. The dust caps only add 2gr.
File comment: Finished Wheel
File comment: Fork mount for security rack.
G'night all,
Monkeyburger
http://ocdlikeme.blogspot.com/
 Post subject: Re: "De-Paired" hub
PostPosted: Sat May 26, 2012 6:56 pm
kinlin xr-200 with 20 spoke, i hope you are light
But amazing job, did you have a rear wheel to go with this one?
My 1998 Trek 5220 paint stripped 7.02Kg
PostPosted: Sun May 27, 2012 12:54 am
Ah yes, now we come to the Benotto in a Baggie...
The Rear is a Mavic 571 triplet laced to an XR200...870gr of Porcine Beauty :doh:
Re weight, I'm a solid 54Kg with a belly full of oatmeal, scrambled eggs and Bali coffee. Good point.
Bien Merci,
Monkeyburger
Users browsing this forum: Google Adsense [Bot], gospastic, HammerTime2, rijndael and 75 guests
It is currently Wed May 22, 2013 4:00 pm
