Post new topic Reply to topic  [ 46 posts ]
Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Jun 29, 2012 8:55 am
nismosr: a friend of mine got his as well this week (fairwheel finally got their shipment!), has 2 rides on it thus far and he absolutely loves the setup. mentioned that his mechanic put a decent glob of grease on the spider eyelet/chainring interface to prevent squeaking/clicking that was going on immediately after install during day 1's ride. day 2 was nice & quiet. has praxis 50/34 on there.
i'll see the bike in a couple of weeks and will snap photos.
PostPosted: Fri Jun 29, 2012 1:09 pm
pictures, 130 standard 172.5mm
PostPosted: Fri Jun 29, 2012 3:27 pm
WTF... If you torque the bolts up to 6nm then there is no freking chance of any squeaking..
Normal grease + carbon interface= :noidea: *1000..
What happens if the said ( cheap ) grease ( it is a bike shop after all ) , has some form of solvent In it that disagrees with the epoxy used To bond the carbon? Last time I checked THM discourage any grease anywhere near the carbon interfaces... Carbon paste yes grease :roll: :unbelievable: :noidea:
I have the excact same setup with 3000+kms and not one click/squeak.
I do own a Torque wrench though..
http://fairwheelbikes.com/cycling-blog/ ... ee-z5.html
PostPosted: Fri Jun 29, 2012 3:30 pm
Oops Nismosr thats a banging looking set up you got going on there.. :thumbup:
PostPosted: Fri Jun 29, 2012 5:03 pm
who knows, don't get excited! i'm only relaying what my buddy told me since i didn't see it. presumably the mech. read the install manual. my buddy is not mechanically inclined in the least, he just takes the bike to the shop and assumes they'll do it right, and he in turn rides the bike (quickly when needed; he has a couple of state champ titles). for that matter maybe it was carbon paste that the mechanic put on there. :noidea:
i agree with you that grease on carbon may not be the smartest thing.
PostPosted: Fri Jun 29, 2012 5:08 pm
Nice crank nismosr!
What are the pros and cons between the regular THM Clavicula vs M3?
PostPosted: Fri Jun 29, 2012 10:18 pm
M3 is heavier, stock crank.
Regular Clavicula is bleeding edge light.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Jun 30, 2012 12:05 pm
They are both very nice. The Clavicula is more expensive and lighter. The M3 is more versatile because you can change the spider.
The Clavicula has a carbon fiber spindle and metal sleeves for the bearings. This can be a problem with some bottom brackets because the bearings do not line up with the sleeves.
PostPosted: Sat Jun 30, 2012 1:07 pm
I love those cranks. In the end I decided to stick with my vumaquads and I put the money I would have spent on a new crankset towards building a TT bike, which will help improve my fitness and riding a lot more than a new crankset! Maybe next year...
Speedplay is the devil.
PostPosted: Sun Jul 01, 2012 4:39 pm
sedluk,
Which bottom bracket does the clavicula has issue with?
PostPosted: Sun Jul 01, 2012 6:02 pm
I don’t think you can use the Clavicula with the Cervelo BBright Directfit which is on the R5ca. You can use it on any of the other Cervelo BBright frames which are more like a pressfit, I use it on my R5 VWD with a THM BBright bottom bracket. The THM BBright bottom bracket is like many bottom brackets in that it places the bearings outside the frame.
THM makes a BB30 bottom bracket with outboard cups. So maybe I don’t completely understand the BB30 bottom brackets. But I would assume that you would normally just press BB30 bearings into the frame and have spacers on the spindle on each side. So it looks like instead you can buy a full bottom bracket shell and have your bearings outside the frame and then you can use the Clavicula.
For some reason they list the Epic (Specialized) bottom bracket as compatible. That BB has spacers (8.5mm and 6mm) and it looks like the bearing would not line up with the metal sleeves on the spindle. For some reason they list that as compatible.
The M3 has an aluminum spindle so it is more versatile.
If other people know more, please share.
PostPosted: Sun Jul 08, 2012 12:01 am
Anyone knows, if the M3 crank will work with BB90, trek's???
has it been done before?
PostPosted: Mon Jul 09, 2012 9:59 pm
Not sure if that's going to work. You'd have to get a adapter to go from a 68mm BB width to 90mm and accept a 30mm diameter spindle. Your frame is essentially 22 mm to wide.
PostPosted: Tue Jul 10, 2012 4:10 am
the width is not the problem. it's that the bearing bore is 37mm, leaving no room for a bearing between that and the 30mm spindle. there are adapters for Shimano Pressfit to thm because pressfit is 41mm od, but even that is squeezing it to a less-than-ideal situation.
edit: i take it back. look at the lightning cranks site-they list something for bb90
http://lightningbikes.com/cranks/bb-cup-types.html
PostPosted: Wed Sep 26, 2012 7:00 pm
Does now anybody know if the THM, Zipp or the Specialized will work with bb90 Trek Madone?
Thanks for replay
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: cyclistcong, deermatt, Majestic-12 [Bot] and 45 guests
There are no new unread posts for this topic. Repairing Vuma Quad
monchito
20
2163
Sat Apr 06, 2013 10:15 am
latman View the latest post
There are no new unread posts for this topic. Anyone fitted a Zipp Vuma to a Cervelo R5?
GT3RS
Tue Mar 05, 2013 8:01 pm
GT3RS View the latest post
There are no new unread posts for this topic. How to fit a Zipp vuma crank into a Scott foil ??
diegoddm
Sat Jun 09, 2012 10:31 pm
Tomstr View the latest post
There are no new unread posts for this topic. THM Clavicula M3 - who's got them? please report
pawnii
13
1094
Thu May 16, 2013 10:12 pm
civdic View the latest post
There are no new unread posts for this topic. THM Clavicula Install
RudyMontana
Sat Dec 15, 2012 7:29 am
Geoff View the latest post
It is currently Sat May 25, 2013 5:23 am
THM Carbones Clavicula M3
