Post new topic Reply to topic  [ 14 posts ]
PostPosted: Thu May 24, 2012 11:00 am
Hi All...
Recently I have had 2 catastrophic Zipp (188) hub failures, and below is some pics of the damage caused to my left chainstay. The bike is a 2010 Cervelo S3. On both occasions, the drive side spokes pulled out of the failed hub, resulting in the rear wheel wedging hard into the left chainstay, completely fouling the back wheel. In this area, the chainstay is back to bare carbon. There is no obvious cracks, so i am assuming i should just seal the carbon with a resin sealant, or epoxy, or similar? Suggestions? Or should i suggest to Zipp they replace the frame (jk 8) )
Edit:
Before anyone asks, I'm 80 to 85kgs, and average about 240 to 250w on my normal 3hr flat training ride (ie I'm no 100kg power beast)
Zipp 404 Zedtech
Zipp 303
Chainstay Damage:
Wet day (road grime++!)
PostPosted: Thu May 24, 2012 11:11 am
No problem if the carbon is intact not grinded down, paint is paint.
Experimental Prototype
PostPosted: Thu May 24, 2012 11:51 am
that kind of looks like sustained tire rub?
Clean it and put a frame protector sticker over it and it should be fine.
PostPosted: Thu May 24, 2012 12:53 pm
As long as you're not seeing any loose, frayed fibers, which I don't see in these pictures, you should be fine just touching it up with some clear nail polish.
Nasty fail on that hub, you're lucky worse did not happen.
It only hurts if you think.
PostPosted: Thu May 24, 2012 2:42 pm
chain stay looks fine. put a sticker on it and forget about it.
PostPosted: Thu May 24, 2012 3:01 pm
PostPosted: Thu May 24, 2012 4:19 pm
I had the very same mark on my trek , just the clear. I dont think you would get a new frame . I mean Cervelo are not known for the liberal use of there frame warranty policy . I think if the chainstay had snapped and you were now in traction in a hospital bed you might have a chance of a new frame.
PostPosted: Thu May 24, 2012 4:33 pm
And have you heard from Zipp yet?
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Thu May 24, 2012 5:59 pm
That's a quite frighting hub failure. Eeeek! Especially because the exact same failure happened more than once, in the same place. I'm sure you're probably not the only one.
PostPosted: Thu May 24, 2012 6:39 pm
The wheel's failure sucks! But the frame is still fine, don't worry IMHO.
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
PostPosted: Thu May 24, 2012 10:25 pm
Wow thats a nasty hub failure and straight pull hubs are meant to reduce of wheels going wrong. I hope you have better luck with your new wheels.
www.thecycleclinic.co.uk
PostPosted: Fri May 25, 2012 4:49 am
Have seen this happen w new Zipp Firecrests with the hub flange breaking off. I can't bring myself to buy a pair having seen too many cracked rims/hubs without their being crashes involved. Who replaces/fixes the damaged frames caused by Zipps failures?
PostPosted: Fri May 25, 2012 5:05 am
If Zipp decides to say Mea Culpa, could you get them to reimburse your frameset also?
http://www.wvcycling.net/
PostPosted: Fri May 25, 2012 8:05 am
thanks for the replies guys,
my frame appears ok, but who would be happy with the gouge out of their chainstay because of the shite 188 hubs Zipp use?!?! not me....
after having it looked at by the local cervelo dealer, i will just cover/seal it with some clearcoat and hope it doesnt happen again... it shouldnt happen again, as long as i stay away from Zipp 188 hubs it would seem...
i am waiting on replies from Zipp USA, and the local (Australian distributor) Echelon Sports.
Will post up reponses...
Thanks for the interest guys, and also the BIG DEAL reponse! lol
Users browsing this forum: bicicleta, CarpetFibre, cyclistcong, HammerTime2 and 78 guests
There are no new unread posts for this topic. Chainstay damaged near dropouts
ketsana
Tue Apr 30, 2013 1:32 pm
ketsana View the latest post
There are no new unread posts for this topic. Chainstay protector recommendations
skiezo
9
504
Wed Mar 06, 2013 9:46 am
Kjetil View the latest post
There are no new unread posts for this topic. Damage to carbon frame?
tcramer
10
1322
Fri Jun 22, 2012 12:15 am
ticou View the latest post
There are no new unread posts for this topic. Firecrest / Enve Smart chainstay clearance
12x23
15
1133
Sun Sep 16, 2012 12:05 am
12x23 View the latest post
There are no new unread posts for this topic. Advice on Hollowgram set up
quaman26
13
668
Wed Jun 13, 2012 4:29 am
It is currently Mon May 20, 2013 3:54 pm
