Post new topic Reply to topic  [ 2 posts ]
PostPosted: Wed May 23, 2012 10:47 pm
Hey!
This is my first wheel build! ....so I am going slowly and would like any opinion on choices I have am making.
I weigh 165lbs (75kg) and will use this wheel for hard training on dry days.
I just purchased a NOS '97 Zipp 530 clincher 28 hole rim. I have a Powertap Pro+ hub with the 15mm axle.
The tech at Zipp told me to use Sapim CX - Ray spokes and build with max 85kgf DS and 45-50kgf ND
(rim is older style, '97 with carbon weave). Newer Zipps go 100kgf but not these old ones. The rim has never been laced.
First question: Spoke length 243.1 left, 241.3 is this correct?
I used a few online calculators but got a goofy number of 230 with many trys of the DT Swiss one.
What gives with them? It makes me nervous about my lengths, but I think I need 244mm and 242 Sapims.
The ERD is 525, carefully measured by me. The Powertap site has my hub
diameter as 70mm, flange distance nds left 33.9 and right ds 15.9mm.
2X lacing.
Second question: What is the best choice for nipple? Sapim aluminium Polyax?
Any comments or suggestions? How about my spoke lengths?
cheers
Casey
PostPosted: Thu May 24, 2012 12:24 am
Lace the DS 1x heads in unless it's Campy. If you lace it 2x on both sides, then the NDS will be ~47% of the DS tension... or 40kg if the DS is 85kg.
Users browsing this forum: alorast, Google [Bot], Google Adsense [Bot], martroy and 77 guests
There are no new unread posts for this topic. Would like opinion on Zipp/Powertap wheel build!
Casey86
Wed May 23, 2012 10:52 pm
Casey86 View the latest post
There are no new unread posts for this topic. powertap in a sram s80 wheel
109er
Tue Jul 03, 2012 2:00 pm
audiojan View the latest post
There are no new unread posts for this topic. Shimano Powertap wheel idea
PoorCyclist
10
762
Thu Jun 14, 2012 10:29 pm
PoorCyclist View the latest post
There are no new unread posts for this topic. Old powertap pro with mavic open pro wheel setup
8mann
Thu Aug 09, 2012 6:46 pm
8mann View the latest post
There are no new unread posts for this topic. Powertap G3 build - thoughts?
sawyer
14
1386
Mon Jun 18, 2012 4:44 pm
legs 11 View the latest post
It is currently Thu May 23, 2013 7:53 pm
