Post new topic Reply to topic  [ 2 posts ]
PostPosted: Mon May 21, 2012 3:11 pm
Online
I recently went from an SL4 to a CAAD10 using the same 7900 brakes and same wheels/tires. I'm running HED Belgiums with Specialized Roubaix tires that are marked as 25s, but caliper out to 26.5, I noticed that when run at 105 PSI as I always run them, the tire will rub on the spring on the inside of the caliper when my weight is properly balanced. I'm trying to figure out if perhaps the CAAD just doesn't have as much rear brake clearance, or if perhaps something is off with my caliper. Any ideas?
PostPosted: Sat May 26, 2012 6:46 am
There is nothing wrong with your frame or the brake caliper. It is just bad luck. I can't even squeeze a 25c tire in my own frame that isn't a Cannondale.
Users browsing this forum: Bing [Bot], CarpetFibre, Exabot [Bot], Google [Bot], jmsp, rijndael, The Green Flame, TriRig and 42 guests
There are no new unread posts for this topic. SystemSix Brake Clearance Issues
gpeterson63
12
819
Mon Dec 03, 2012 11:57 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Brake Callipers and Fender Clearance
Thrillho
Fri Jul 13, 2012 8:43 am
durianrider View the latest post
There are no new unread posts for this topic. Carbon Brake Pad Compatibility Issues?
true
10
514
Fri Nov 09, 2012 11:33 pm
Zen Cyclery View the latest post
There are no new unread posts for this topic. c40 tyre clearance
bontie
16
854
Tue Jul 10, 2012 9:39 am
andyindo View the latest post
There are no new unread posts for this topic. tight clearance on fork blade...
chiltonp
Thu Aug 02, 2012 4:44 am
elviento View the latest post
It is currently Sat May 18, 2013 5:20 pm
