Post new topic Reply to topic  [ 33 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Mon May 21, 2012 6:55 pm
So to go to the next stage and to ask if anyone had this experience which I would like to know if it refers to chain need to be replaced.
I hear little noise when I stroke the pedal. It is only the left pedal and not always heard. It heard mostly when I put power down or getting out of my saddle but even then it is not as a rule so difficult to put the finger on the reason. I have changed pedals and still the same issue exist with the other set. I have checked the crank and crank arms but it seems steady with no movement and free play so I am wondering if it could be from tightened chain even though the feeling of this noise is like it under my left feet as I stroke.
Any suggestions?
I am here: http://tapatalk.com/map.php?zqttdd
PostPosted: Mon May 21, 2012 6:58 pm
What, exactly, if you can describe it, are you hearing?
Exp001
PostPosted: Mon May 21, 2012 11:25 pm
it is like a knock sound, every stock like a tick which I feel physically from the pedal underneath the shoe but as I said it is not always there, so there is no rule beside that its more appearing when I push harder on the pedal but as I said with my original post about this issue, I checked and kind of eliminated few things so I'm asking if it can be chain tightened too much, which need to be replaced.
I am here: http://tapatalk.com/map.php?32imw2
PostPosted: Mon May 21, 2012 11:33 pm
Only when pedaling on the left?
It's not the chain, it may be the bearings.
Exp001
PostPosted: Tue May 22, 2012 12:40 am
I've used both Sram 1091 and Shimano 7900 on my Red drive train. The 7900 might be a tiny bit quieter, but if so, it's virtually meaningless .... to me. The 1091 was perfectly acceptable to me. I have no experience with the KMC.
When I was buying the chains about a year ago, I was searching for the absolute cheapest online prices I could find, and I don't recall that there was a significant (maybe $5) difference between the 1091, the 7900 or the KMC 10SL which I was also looking at.
PostPosted: Tue May 22, 2012 6:47 am
I have tried several SRAM chains and Shimano chains. Shimano chains shift just as well, but as somewhat of a SRAM fanboy, I hate to admit it but Shimano chains last longer. IME, a SRAM PC 1070 only lasted ~3000 km; SRAM PC 1050, 1090R, and Ultegra 6600 chains lasted ~5000 km, and a Dura Ace 7801 chain lasted even longer.
One bike currently has a SRAM PC 1051 chain, not sure what changed from the 1050, but it seems to be lasting longer. I yearn for longer lasting chains so I am experimenting with other chains. My other bike is testing a Wippermann 10S8. It did not shift as well as the Dura Ace chain initially (on SRAM 1070 and Ultegra 6600 cassettes), but now it works just fine. My hope is that it will last longer and after ~2000 km it has not "stretched".
I can definately recommend either the Wippermann 10S8 or the (discontinued) Dura Ace 7801. KMC makes good chains, but I only have experience with their 9 speed and single speed chains. This may be superstition, but hollow pin chains have not lasted as long for me. After breaking a couple chains in the past, they are not a place I look to save weight. Shift quality and longevity are more important to me.
Regarding your left pedal noise, have you looked at both your shoe and cleat? The right member of one of my pairs of shoes is currently suffering a similar ailment.
PostPosted: Tue May 22, 2012 7:54 am
DWB, how do you clean your chains?
Cervelo S3 2011. Blinged 6.718 Kg
PostPosted: Tue May 22, 2012 2:57 pm
yes only the left pedal only when I push it down pedalling. Which bearings are you referring to,the BB?
I am here: http://tapatalk.com/map.php?muhayp
PostPosted: Tue May 22, 2012 2:59 pm
Regarding your left pedal noise, have you looked at both your shoe and cleat? The right member of one of my pairs of shoes is currently suffering a similar ailment.[/quote]
I have looked both cleats, I have changed cleats now I use Speedplay Zero and before when the noise started I used Xpedo TI look compatible and I thought the noise came from the pedal but eventually I changed to speedplay and same noise on same side continues. The cleats on the shoe are secured now and doesn't move!
I am here: http://tapatalk.com/map.php?avvbsc
PostPosted: Tue May 22, 2012 3:10 pm
On my FORCE drivetrain, I mix SRAM and Shimano cassettes frequently.
All 10 speed chains seem to work acceptably well: Sram, Shimano,.. including the KMC.
I think the DA 7900 chain does however shift just slightly smoother/faster than all of them.
Not enough that I am willing to pay retail for the 7900 though. I will run whatever I can get on a good sale. :wink:
I will up my budget a little for a 7900 though.
PostPosted: Tue May 22, 2012 3:14 pm
Yes.
Exp001
PostPosted: Tue May 22, 2012 10:56 pm
madmole,
I do not clean my chains often. Maintenance schedule is important for chain life though. I follow the Lennard Zinn philosophy and replace chains prematurely to conserve the cassettes. Chains are replaced with about 2 or 3 mm stretch over 10 links. When the chain is dirty I use Purple Power degreaser and a toothbrush to clean the chain, cassette, and chainrings with lots of water. Then for lubrication I use White Lightning and it takes more every 100 to 300 km, depending on the weather.
The chains breaking were other, isolated incidents a long time ago and not related to my maintenance schedule. I was just saying it happened to me before and will always make me prefer robust chains. On the other hand, I twisted a PC 1050 link while shifting under load. It was a freak accident and did not stop me from replacing it with another SRAM chain.
WasFab,
Running Speedplay Zeros as well. Today I took apart the right cleat of the offensive shoe, and sure enough one of the three adapter plate bolts was loose. After tightening it, the noise has gone away. However, in your situtation changing from the Xpedo pedals, this may not be the case with you.
PostPosted: Wed May 23, 2012 1:26 am
Real men use Wipperman.
/end thread
Mass Weenie
PostPosted: Wed May 23, 2012 4:13 pm
You Wippermann people are making me take notice, but wow over $100 for a chain? Cheapest I found was a little over $90 on ebay. If they last twice as long though it would seem worth it. I wasn't real impressed with the 3-4k or so miles I got out of my last KMC. It was off of my race bike though, so most of those miles were hard ones. This thread is reminding me I should check my chains on my bikes.
Cervelo S2(5888g)
Cervelo P3(7850g and dropping fast)
Trek 5200(7050g)
PostPosted: Wed May 23, 2012 7:14 pm
OK, this is probably way to simplistic, but I have to mention it. A small ticking sound, intermittent, but once per pedal revolution while left pedal is down..... which means right pedal is up..... could it possibly be the right crank arm brushing against the front derailleur cable? I've had that happen a few times before I figured it out. Doh!
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: 1415chris, Gazelleer, Google [Bot], Google Adsense [Bot], Miller, nfecyle and 48 guests
There are no new unread posts for this topic. chain drop on SRAM chain catcher
PoorCyclist
Fri May 10, 2013 4:38 am
timzcat View the latest post
There are no new unread posts for this topic. Attachment(s) Sram lever hoods advice replacing/keeping rubber hoods new
dallaghan
Fri Aug 10, 2012 8:33 pm
artray View the latest post
There are no new unread posts for this topic. Any way to repair campy 11 speed chain>
reemo
9
756
Thu Dec 27, 2012 2:26 pm
Wcl4 View the latest post
There are no new unread posts for this topic. KMC 11-speed chain wear question
goldmine848
33
1379
Tue Sep 11, 2012 10:05 pm
Calnago View the latest post
There are no new unread posts for this topic. SRAM 11 Speed
[ Go to page: 1 ... 15, 16, 17 ]
geedawg
247
18450
Fri May 24, 2013 11:16 pm
MichaelB View the latest post
It is currently Wed Jun 19, 2013 6:21 pm
