Post new topic Reply to topic  [ 7 posts ]
PostPosted: Sat May 19, 2012 9:27 am
Do you guys ride carbon tubular wheels in the mountains any time or only with low carbon rims and in dry conditions?
I would like to use my Fulcrum racing speed XLR 50mm carbon tubulars in the mountains, but I also feel a bit worried when the weather is changing rapidly in the mountains. I can go save and use my Fulcrum racing zero's (I ordered them yesterday) in the mountains, but I love to ride my racing speed carbon tubulars and the lightest setup that I have for my bike.
What would you choose and why?
Specialized Tarmac S-works SL4
http://i891.photobucket.com/albums/ac11 ... 11af34.jpg
PostPosted: Sat May 19, 2012 11:28 am
Winds can be strong and shift rapidly through gaps and passes. This can be tough on deep rims like 50mm. Also, the braking on carbon rims leaves something to be desired in wet weather on descents. If you can choose the days you ride then this might mitigate the weather risk to a large extent. But if you ride events or races, you won't have this luxury. I like the shallow lightweight aluminum wheels for the mountains, like the Shimano 7900 C24 (or your zeros).
PostPosted: Sat May 19, 2012 11:57 am
Thanks....I have to take a close look at the weather forecast before each mountain ride but as you said, the weather changes fast in the mountains.
PostPosted: Sat May 19, 2012 1:36 pm
I do not like descending in the mountains with deep carbon rims. My limit is around 35/38mm but my favorites are my lower profiles carbon tubs. I find the deeper ones not as easy to "place" and if windy it can be just plain scary.
If potential hard rain is in the forecast I pull out the alum rims and switch pad holders.
I still have not found a carbon rim / brake pad combo that works well in the really wet.
PostPosted: Sat May 19, 2012 2:04 pm
Formerly known as PezTech
I ride the crap out of them...
Love the low weight of carb tubulars going up and love the aero on the way back down.
charles@pezcyclingnews.com
PostPosted: Sat May 19, 2012 2:06 pm
Mountains? in AZ :beerchug:
PostPosted: Sat May 19, 2012 2:44 pm
i wouldn't want any thing else wet or dry..
if its wet you just have to manage the situation differently, using both brakes, scrubbing/warming the rims. braking earlier and less aggressively and keeping the braking to when the bike is upright.. you can still push hard with good tire and pressure choices. also stay away from the swiss stop yellows.
not real nice in the wet or in general
http://fairwheelbikes.com/cycling-blog/ ... ee-z5.html
Users browsing this forum: Google [Bot], Google Adsense [Bot], MSN [Bot], rbrtwyn and 55 guests
This topic is locked, you cannot edit posts or make further replies. OK to use carbon wheels for every-day riding?
phlip
Tue Jul 03, 2012 11:06 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. A Steelist in the Mountains.
ticou
Wed Sep 12, 2012 7:32 pm
ticou View the latest post
This topic is locked, you cannot edit posts or make further replies. carbon wheels VS alloy wheels
joe77bike
Fri Jul 06, 2012 5:55 am
Frankie - B View the latest post
There are no new unread posts for this topic. Carbon wheels, out of the box trueness
Grimpeur
11
1341
Tue Jun 19, 2012 3:28 am
ayyyyy View the latest post
There are no new unread posts for this topic. Planet-X Pro carbon 50/82 wheels
bruno2000
Fri Aug 03, 2012 7:28 am
bruno2000 View the latest post
It is currently Fri May 24, 2013 4:14 am
