It is currently Mon Mar 27, 2017 12:14 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Fri May 18, 2012 4:55 am
I have ridden a DA7900 drive train for between 1000 to 2000 miles I guess. I have now just replaced the chain & cassette. The big ring has taken most of these miles and I wonder if I should replace this now (I have a spare on the shelf)?
There is a like a small lip around the circumference of the big ring at the bottom of the teeth - Is this a wear indicator? There does not look to be too much wear, but it's difficult to tell, even compared against the new ring.
There does not seem to be too much new chain movement on the used chainring, but will not swopping be detrimental to chain and then cassette life?
What chainring life are others getting?
PostPosted: Fri May 18, 2012 5:17 am
1000mi?! Given proper care, you shouldn't have to replace even the chain. I take, admittedly, much better care of my bikes than most, but i get upwards of 4000 to 5000 miles on a chain - and 2 to 3 chains per cassette, and 2 to 3 cassettes per chainring set.
In short, what I mean to say is no - you shouldn't have to replace the chainrings.
PostPosted: Fri May 18, 2012 6:00 am
Great - I won't swop it out then.
PostPosted: Sun May 20, 2012 12:54 am
Good rule is change the chain every 2500 miles and the cassette every 10,000.
R2.5 / R3 / S-Works 29er (20 lbs) / S-Works SL4 Di2 (14.7 lbs)
There are no new unread posts for this topic. Which chainring is better with Shimano FDs: Sram Red vs Praxis
nemeseri
Sun Aug 28, 2016 5:44 pm
silvercivic27 View the latest post
There are no new unread posts for this topic. Round big chainring + oval small chainring = muscle adaptation issues?
Sacke
Thu Aug 18, 2016 3:09 pm
Marin View the latest post
There are no new unread posts for this topic. Wear rate of Look pedals
userfriendly
Thu Nov 24, 2016 4:10 am
userfriendly View the latest post
There are no new unread posts for this topic. Is it okay to wear Retro or out of date Pro Kit?
[ Go to page: 1 2 3 4 5 6 ]
tacos8910
76
4623
Fri Apr 15, 2016 8:19 am
L3X View the latest post
There are no new unread posts for this topic. Tire wear indicator
mvcap
Sat Feb 18, 2017 8:41 pm
Miller View the latest post
Users browsing this forum: Bing [Bot], cyclespeed, dj97223, si1ver and 32 guests
