It is currently Fri Jan 19, 2018 5:09 am
PostPosted: Wed May 16, 2012 10:33 pm
Hi All,
I wonder if anyone can help me with this query...
I have been running 2010 SRAM Red on my race bike (Cannondale Supersix) but using the band on Force FD.
The Supersix is now dead and I have an EVO waiting to be built up. It requires a braze on rather than band on FD and I happen to have an Ultegra FD 6700 braze on in the shed!
Simple question...will it work perfectly or not? Only concern is functionality - it has to be perfect, not too concerned with aesthetics on this occasion...
Many thanks,
KH
PostPosted: Wed May 16, 2012 11:25 pm
If your question is about running the SRAM red shifters with Shimano Ultegra FD:
I had the SRAM Red Black shifters with Shimano 105 (5600 IIRC) and then with Shimano Dura Ace 7800 FD - the setup worked perfectly.
PostPosted: Thu May 17, 2012 9:19 pm
Thanks...will give it a go!
PostPosted: Sat May 19, 2012 5:24 am
Perfectly? No. Well...yes, but cable tension has to be absolutely spot on or else it'll rub. A 6600 would work perfectly.
PostPosted: Sat May 19, 2012 7:56 am
I've set one of these up before: our shop only had a 6700 derailer, and the bike needed to be done. It was as easy, if not easier to get the position right than with a sram derailer, though you may need to tweak the cage a little bit. Shifted under load perfectly. I would reccomend this setup as being at least on par with a force FD.
Granted, I'm starting to believe that front shifting performance has a lot to do with function of the frame's braze-on adaptor, and I'm willing to bend a derailer's cage until shifting is perfect.
PostPosted: Sat May 19, 2012 4:55 pm
I broke my Force FD in a race and the only other FD I had available was a 7800 Dura Ace. I found that it worked better than the original Force FD...
So I think it'll work just fine.
PostPosted: Sat May 19, 2012 7:05 pm
Many thanks to all who have replied, hopefully it'll save me £35! My mechanic is pretty handy so I'm confident he will be able to get this to work as you all have.
PostPosted: Sat May 19, 2012 7:31 pm
The pull ratio is exactly the same, and the FD doesn't have a clue what or who is pulling the cable. The only one of the three big ones FD that isn't fully compatible is the DA7900, which should use DA7900 brifters. Works perfectly fine with my 105 brifters though...
The Shivenge
There are no new unread posts for this topic. Caliper: Tiagra 4700 vs Ultegra 6700
WiryMike
Mon Feb 27, 2017 4:31 pm
hambini View the latest post
There are no new unread posts for this topic. Ultegra 6800 to Rotor 3DF 30mm on Giant TCR advanced 2 (2010)
chinoph
10
817
Tue Jun 13, 2017 8:14 pm
benp View the latest post
There are no new unread posts for this topic. Shimano SC-MT800 display compatible with SM-BTR2 Battery?
velobob
Thu Oct 26, 2017 8:42 pm
egebhardt View the latest post
There are no new unread posts for this topic. P.S.A: Shimano Ultegra 8000 Chainset
Ginsterdrz
7
1235
Tue Sep 05, 2017 10:22 am
jih View the latest post
There are no new unread posts for this topic. SRAM Etap crankset with BB30 compatible with Scott Addict SL (BB86)?
wootenlakeguy
Mon Feb 20, 2017 11:17 pm
grover View the latest post
Users browsing this forum: Allen254, Bing [Bot], donald, oldnslow2, pratt, tokyoturtle and 24 guests
